AVForums - Free Audio Visual electronics advice and information
AVForums.com twitter page AVForums.com facebook page AVForums is a member of CEDIA. THX certified reviewer.  Click for more information. AVForums reviewers are ISF Certified.  Click for more information.
Forum List Register Blogs Information Social Groups Search Today's Posts Mark Forums Read
Go Back   AVForums.com > Forums > Video Electronics > TVs > LCD and LED LCD TVs
Latest popular product pricesPowered by
Samsung LE32C530
LG 42LD450
Samsung LE40C650
LG 22LD350
Samsung LE32C530
LG 42LD450
Samsung LE40C650
LG 22LD350
Samsung LE32C450
Sony Bravia KDL-40EX503
Samsung LE40C580
LG 32LD450
Sony Bravia KDL-32EX403
Samsung LE32C650
 More...Prices updated September 9th at 7:30am and include delivery.
LinkBack Thread Tools
Old 29-11-2008, 6:09 PM   #691
Thanks: Gave 103, Got 611
Re: The JVC LT-26DX7 and LT-32DX7 thread
Originally Posted by Petherro49 View Post
GaryB thank you very much for your advice on that. The set has certainly been untouched since I bought it, supposedly new fom the TV dept of a major department store - I had returned an unrepairable Philips 9616 and paid the difference. I wonder if this is an ex-diplay or returned set? The store no longer has the same department so I suppose the answer will be to find a JVC specialist. I doubt if the extended warranty will cover it.
Assuming that whoever covers the warranty is still around, it's certainly worth a try. They won't have any way of knowing how it was caused and it could just be a normal fault, so you should contact them and just say that the HDMI inputs aren't working and leave the rest to them.
GaryB is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookShare on Twitter
Old 30-11-2008, 1:39 AM   #692
Its a best first option, I will give it a try. PS3 is fine through component but without HDMI may suffer disc restrictions later. Fantastic tv otherwise.
Petherro49 is offline
Old 08-12-2008, 8:57 PM   #693
To update, I decided to let a reputable local Panasonic/JVC specialist have a look and he found the problem to be a missing foam cover, at a light source near the HDMI ports if I understand correctly. Either missing since new or opened & lost before I got it. I suspect the latter - maybe a set returned for "repair" because of the Sky HDMI problem? Anyhow I will never know and have asked for the part to be fitted. HDMI now working with a temporary repair (black stick tape).
Old 21-01-2009, 9:01 PM   #694
No signal recorded from LT-32DX7 when it's switched off
Not sure what's changed with my LT-32DX7/JVC PVR setup but switching off the JVC, when recording from the internal Freeview tuner, causes the JVC to blank the recording. I set the Pioneer recording & it records the program up to the point of switching off the JVC. They're connected using Scart from Ext2.
Any ideas?
palsapal is offline
Old 18-07-2009, 6:00 PM   #695
Thanks: Gave 3, Got 0
Does anyone know the three or four digit code for setting up a Sky+ (HD) remote control with a LT-26DX7 ? Want to get the volume control etc to work with the LT-26DX7.
I've tried all of the JVC codes I can find on various web pages and none work as yet. If anyone has actually had success making this work, I'd love to know which code you used. Thanks.
dangermain is offline
Old 18-07-2009, 7:13 PM   #696
I can answer my own question (see above):
The code is 0053 when using a Sky+ HD remote.
jvc, lt26dx7, lt32dx7, thread
Optimised for Firefox
AVForums.com is owned and operated by M2N Limited
Copyright © 2000-2010 M2N E. & O. E.
