Go Back   AVForums.com > Video Electronics > LCD Televisions
Today's price checkPowered by
Samsung LE-32B450C4
Panasonic Viera TX-L37G10E
Toshiba Regza 32AV615DB
Sony Bravia KDL-40W5500
Samsung LE-32B450C4
Panasonic Viera TX-L32X10
LG 22LH2000
Samsung LE-40B530P7
LG 37LH3000
Panasonic TXL19X10
Samsung LE-37B550
 More...Prices updated November 24th at 8:30am and include delivery.
Old 28-12-2005, 12:18 PM   #1 (permalink)
Samsung LE26R41BD - worth buying component leads over RGB scart ?
Just bought one of these for my son's bedroom
Played around with the picture settings as per comments in this forum.
Getting reasonable Freeview Picture and quite good DVD (but nothing like as good as the picture on the 36 inch Tosh CRT that I have downstairs)
The DVD is connected via RGB Scart lead. Is it worth trying component leads. The 36 inch Tosh is connected via component (prog scan) but I think I would have problems telling by just looking at the picture between the component prog scan and RGB scart. Although I can tell immediately the difference between RGB and composite.
I don't think the leads on the Tosh will fit the Samsung, - is it worth buying some ? Can you notice the difference ?
PeteB is offline   Reply With Quote
Old 28-12-2005, 3:15 PM   #2 (permalink)
AVF Hardware Reviewer
David Mackenzie's Avatar
Thanks: Gave 872, Got 1,116
Yes. SCART is an outdated connector and can only carry Interlaced, Standard Definition video.
A Progressive Scan DVD Player with Component output will give far better picture. The difference isn't quite the difference between Composite and RGB - the difference is one of overall clarity instead of picture interference.
Hardware Reviewer
ISF Certified
AVForums TV | Read me rant
AKA Lyris. My personal opinions are not those of the AV Forums or any other related website.
David Mackenzie is offline   Reply With Quote
Old 29-12-2005, 11:15 AM   #3 (permalink)
thanks- tried it - i think there is an improvement - I'm getting to quite like the picture on LCD from DVD - it definitely grows on you
Old 29-12-2005, 12:54 PM   #4 (permalink)
Thanks: Gave 11, Got 17
The difference between conponent and rgb scart is not that great. I run both into my LE32R41B and from 2yards away there is no noticeable difference. My wife prefers Scart because of the auto-switching. I prefer Component because I know it's better - even though I cannot notice any difference unless I am very close (too close).
Orwella is offline   Reply With Quote
Old 30-01-2006, 10:15 AM   #5 (permalink)
Thanks: Gave 176, Got 563
I connected the HD850 to the LE32R41BD using HDMI and it looked worse than my old DVD player connected to my old CRT TV using scart RGB. I haven't connected the player to the Samsung with RGB to really compare yet.
mjpartyboy is offline   Reply With Quote
buying, component, le26r41bd, leads, rgb, samsung, scart, worth
