| Need Help installing a 2nd LCD TV off single aerial
I know, I know, this is should be really easy. But I'm having a nightmare with this.
I'm installing a 2nd TV in my house. I had one downstairs, receiving its DTV signal from an antenna in the loft, connected with coaxial cable with standard RF plugs.
I bought some standard 75 Ohm coax, and some RF connectors and a splitter, and cut the original cable about 3m away from the antenna, and installed the splitter and the new section of cable.
My problem is this: The signal on the new LCD TV is so bad, that it can't find any channels. It can't be the way I fitted the RF plugs or that I'm 'overloading' the one antenna, because the signal on the downstairs tv is still fine. I have checked/refitted RF plug on the new length of cable 2 or 3 times.
Here's what I've tried:
1) tried new TV downstairs - found channels instantly - so new TV is OK.
2) used a connector to link the upstairsTV direct to the antenna, signal is still rubbish. A combination of this and the above rules out any problems between the antenna and the splitter, and the splitter itself.
Can cable be 'bad' straight out of the shop? It's not PF100 or anything, because I don't have satellite. I've been told that 75 Ohm cable is fine for the job, and my connections appear to be OK.
Anyone got any more troubleshooting tips or advice on co-axial cable installation? What the hell is going on?
