| Re: Which LCD TVs allow sharpening to be completely disabled?
OK, I've spent quite a bit of time evaluating the aforementioned TVs, and here are my findings:
As I said before, the Sony KDL-32V4000 applies obvious sharpening to SD input sources, even when the sharpness control is set to "Min". I find that totally acceptable so I returned the TV. (Thank goodness I bought it from John Lewis, who have a decent returns policy.)
The Pioneer KDL-32V looks fantastic with SD sources. And so it should - it costs a small fortune. Unfortunately, the screen has a glossy finish (as with so many laptop screens these days) so it's pretty much unusable in a room that gets any sunlight. No good to me, then.
The Panasonic TX32LZD85 seems not to apply sharpening to its Freeview output at the lowest sharpness setting. However, YellowSphere is completely correct - the quality of the upscaling is absolutely appalling. It looks almost as if the signal is being converted to composite video and back to digital again. And with the SCART inputs, it is obvious that sharpening is being applied even with sharpness set to minimum. I am absolutely flabbergasted that a supposedly top-flight TV set can make such a dreadful hash of displaying SD sources, and that this fact appears to pass virtually without comment in forums and product reviews. For shame!
The Sharp LC32D65E, on the other hand, does appear to disable sharpening as soon as the sharpness control is turned down to -6 or so. In fact I cannot detect any further change from -6 down to -10. Also, the quality of the upscaling is excellent - the picture looks almost as good as my old Sharp P50 540 line PAL-optimised TV. It would not surprise me to learn that the scaler is the same one used in Pioneer TVs. The picture looks as good via SCART input as it does with the built-in Freeview tuner. Top marks!
The Sharp does have some downsides, however. The onboard software is not too great. In particular, the Freeview EPG is so awful as to be virtually unusable. The viewing angle is not the best - you basically have to be right in front of the TV to get good colour response and contrast. The built-in speakers are not particularly wonderful either, sounding rather thin. However, even with all these faults I am keeping this TV, because at least it delivers a decent picture with SD. I can always use an external Freeview box and amp/speakers. Also, the price I got it for (£433 with 5-year warranty) seems like very good value indeed for a 1080p TV.
Reason: Correction - wrote TX32LXD85 instead of TX32LZD85
