Samsung R86/87/88 Owners Thread, ~Settings/Discussion *Part 2*
Old 03-05-2010, 2:08 AM   #211
Thanks: Gave 3, Got 13
Conected my xbox360 via hdmi I have a few questions.
1) anyone using the hdmi xbox elite settings (setting in original thread)
if yes how are they.
2) is it ok to use expaned referance level on this tv
thanks
Old 03-05-2010, 9:47 AM   #212
Firmware upgrade question
is it possible to get it upgraded by Samsung engineer if so how much does it cost.
also guys could you post what version you have thanks
Old 20-05-2010, 1:51 PM   #213
Thanks: Gave 33, Got 77
Has anyone on here used a Harmony remote with this TV, specifically to access HDMI3 from an activity, if so, please could you tell me how you did it
Old 21-05-2010, 1:29 PM   #214
Thanks: Gave 4, Got 4
R88 - HDMI Black Level option not available
I have an R88 and am trying to apply the SKY+HD Settings as per the part 1 post and I am unable to select the HDMI Black Level option as it is greyed out. Any Ideas?
Old 26-05-2010, 3:07 PM   #215
lunker's Avatar
Thanks: Gave 12, Got 10
Thought I'd share my recent findings.
It wouldn't switch on over the weekend so I started with the basics, I switched it off for 24 hours and tried it again but still nothing.
So then I raised a call with Samsung the guy said it sounded like a known issue (sorry if it has already been cover on this thread)
He asked for the serial number, model type or version and he will put it down as "making a clicking sound and not switching on"
The best bit is the repair is going to be free. My TV is over three years old and well out of warranty.
Telephone number for Samsung is 0845 726 7864
Hope this hasn't already been covered and helps someone.
miguel_havier (27-09-2010)
Old 26-05-2010, 3:26 PM   #216
I've heard this a few times with Samsung, a friend got a brand new model in replacement for a broken 3yr old Samsung.
Old 19-06-2010, 5:08 AM   #217
I found this thread (well, the first one) hoping to find some good settings for PS2. The wii and PS3 settings work great for those, but I've tried using the wii settings for the PS2 and it didn't seem to help in comparison to the default settings.
There wouldn't happen to be anyone still around that would care to share their PS2 settings would there?
Old 20-06-2010, 7:25 PM   #218
Yemeth's Avatar
Thanks: Gave 787, Got 1,048
Its been so long since ive posted in this thread.
Ever since ive had a 360 and my R88, ive been using it at optimal resolution 1:1 1360x768.
I got a new pc recently and wanted to use its HDMI so I was forced to use standard 720p on another HDMI connection for my 360 (the dvi one being used by my pc now).
At first, i didnt like the settings, like the first time i connected it to standard non native resolutions of 720p and 1080i. Blackbolt360 posted some 720p hdmi settings before, but i didnt like them at all.
I have now come up with settings using standard 720p hdmi on my 360 that are almost identical to the clean, crisp and authentic 1:1 dvi/hdmi connection displayed from my 360.
Mode: Standard
Contrast: 69
Brightness: 65
Sharpness: 0 (or up to a max of 10 if its too soft).
Colour: 50 (can add or take away a bit to taste)
Tint: 50/50
Colour Tone: Cool1
Backlight: 8 (or taste)
Picture Size: Just Scan
Digital NR: Auto
DNIe: Off
Game Mode: Off
Energy Saving: Off
HDMI Black Level: Low
360 Dashboard Settings: *Found in Settings > Display
Display Discover: Disabled
Reference Level: Expanded
Colour: Source
Enjoy.
Shindig (22-07-2010)
Old 21-06-2010, 10:17 AM   #219
Has anyone got a PC/HTPC connected to their R88, if so what resolution do you set for the PC?
Old 22-06-2010, 2:25 PM   #220
Yemeth's Avatar
I do.
If you are connected via VGA or HDMI #2, then choose 1366x768 OR 1360x768 for the best pic.
If you are connected to HDMI #1 or '#3, then you will need to choose 1280x720 + Just Scan in the picture options.
Old 16-07-2010, 7:22 PM   #221
Colonel Burton's Avatar
Thanks: Gave 42, Got 11
Originally Posted by Yemeth View Post
I do.
So which would be the better choice? cheers
Old 16-07-2010, 11:58 PM   #222
Use HDMI 2 if you're connecting a PC
Colonel Burton (17-07-2010)
Old 17-07-2010, 8:07 AM   #223
fir 360 should i use Optimal Res or 720p
Old 17-07-2010, 9:26 AM   #224
Yemeth's Avatar
Optimal Resolution if you are using HDMI #2
720p with Just Scan if you are using HDMI #1 or #3
EDIT: Also, look a few posts down. I have posted really good settings for 720p for the 360.
Old 17-07-2010, 10:11 AM   #225
Cheers Dave
Old 17-07-2010, 11:39 AM   #226
I am using HDMi 2 Port so I should use Optimal Resolution & try your settings below..right (currently using Game Mode Default)
1) With Optimal the picture goes darker is that normal.
2) How do you find the black levels (do they crush)
3) Display Discover: Disabled - Is turning this feature of important
Mode: Standard
Contrast: 69
Brightness: 65
Tint: 50/50
Colour Tone: Cool1
Digital NR: Auto
DNIe: Off
Game Mode: Off
Energy Saving: Off
Old 17-07-2010, 7:23 PM   #227
Yemeth's Avatar
Mode: Standard
Contrast: 69
Brightness: 65
Tint: 50/50
Colour Tone: Cool1
Digital NR: Auto
DNIe: Off
Game Mode: Off
Energy Saving: Off
No. Dont use Optimal Resolution if you want to use these settings. Use 720p, and if you have a PC or want it connected via HDMI, reserve HDMI #2 for it. Otherwise, you can use HDMI 2 if you want 1360x768. Turn Game Mode On. I cant tell you exactly what else to have what set to (like sharpness etc.) as I dont use Optimal Resolution anymore.
What is causing the picture to go darker could be HDMI Black Level. play with that option, but this is just speculation on my part.
Old 17-07-2010, 9:08 PM   #228
The above was just some questions I had
I am currently using your above settings for my 360 via HDMi on Port 2 and 720p
just wondering why do you choose Source over Auto is it better for the TV
Old 18-07-2010, 5:48 PM   #229
Yemeth's Avatar
no reason really. didnt make a difference imo.
ive replied to your pm as well.
regards
Old 20-07-2010, 1:27 AM   #230
chaggs1's Avatar
Thanks: Gave 6, Got 20
Bit of a silly question but why use 720 with your xbox 360 through hdmi when the tv can out put 1080i?
Old 22-07-2010, 7:54 PM   #231
Thanks: Gave 2, Got 4
I do like those settings! Thank you
Mode: Standard
Contrast: 69
Brightness: 65
Tint: 50/50
Colour Tone: Cool1
Digital NR: Auto
DNIe: Off
Game Mode: Off
Energy Saving: Off
Colour: Source
Enjoy.
Old 22-07-2010, 8:08 PM   #232
Yemeth's Avatar
Im happy you have liked them
Old 31-07-2010, 10:12 AM   #233
I had to turn on Display Discovery to get audio on DVDs working with my TV. HDMI cable, new xbox360 slim.
Mode: Standard
Contrast: 69
Brightness: 65
Tint: 50/50
Colour Tone: Cool1
Digital NR: Auto
DNIe: Off
Game Mode: Off
Energy Saving: Off
Colour: Source
Enjoy.
Old 19-08-2010, 1:13 PM   #234
Yemeth do you have a PS3 if so what setting do you use.
also is its best to have sharpness on 0 for HD Gaming.
I really like your 360 settings just wondering for my PS3
Old 22-08-2010, 4:43 PM   #235
Thanks: Gave 16, Got 27
I've had this telly 'R87' for nearly 2 years now and it really is good and my settings are as follow:
Mode. Standard
Contrast. 80
Brightness. 50
Sharpness. 30
Colour. 50
I'm actually selling my telly now now in the classified sections.
Old 22-08-2010, 4:44 PM   #236
on the PS3 XMB I am getting banding anyway to fix this would doing the service menu thing in the original thread fix it....
Old 24-08-2010, 8:37 AM   #237
I done the changes in the service menu that was advised in original thread
http://www.avforums.com/forums/lcd-t...iscussion.html
Is turning Dynamic Contrast On important has it makes the screen brighter but I prefer it off
Old 24-08-2010, 8:51 PM   #238
Well you usually turn it off as you say, its why to bright (for most people)
Old 25-08-2010, 1:20 PM   #239
does anyone know if the settings changed in service menu will change for all inputs automatically
or do you have to change each input manually.
Old 25-08-2010, 5:02 PM   #240
Thanks: Gave 835, Got 283
Hello!
I've just got the Foxsat HDR currently it is hooked up via HDMI 2 as the Xbox is on HDMI 1. Is there any way to get the TV to change automatically from one back to the other when either is switched on or off? At the moment I have to manually change between the 2 HDMI channels.
Also, does anyone have any optimal settings for the Foxsat that they recommend?
Thanks in advance!
Steve
