TVs with MPEG4 HD tuners
Old 12-11-2008, 5:00 PM   #1
2,766, Level: 12
Points: 2,766, Level: 12 Points: 2,766, Level: 12 Points: 2,766, Level: 12
Thanks: Gave 4, Got 13
Hi all,
I am moving to NZ where they have Freeview HD broadcast using MPEG4.
Are there any TVs available in the UK that I can buy which will work with MPEG4 HD signals? I think the Sony W4000 series does but does anyone know of any others?
Thanks,
benwolf
Old 12-11-2008, 5:27 PM   #2
17,134, Level: 31
Points: 17,134, Level: 31 Points: 17,134, Level: 31 Points: 17,134, Level: 31
Activity: 13.6%
Activity: 13.6% Activity: 13.6% Activity: 13.6%
Thanks: Gave 205, Got 346
Re: TVs with MPEG4 HD tuners
AFAIK there are no TV's sold in the UK as yet with MPEG 4 HD tuners. The Sony Website makes no reference to one in the tech specs of the W4000 or any other model as far as I could see.
Old 12-11-2008, 6:15 PM   #3
audiphile76's Avatar
11,707, Level: 25
Points: 11,707, Level: 25 Points: 11,707, Level: 25 Points: 11,707, Level: 25
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 50, Got 309
Sony V4500 series, Sony W4000 series, Sony W4500 series, Sony Z4500 series, Sony X4500 series, Samsung A556 and Samsung A676 Series all have the MPEG-4 capabilities.
Old 12-11-2008, 6:16 PM   #4
79,103, Level: 68
Points: 79,103, Level: 68 Points: 79,103, Level: 68 Points: 79,103, Level: 68
Thanks: Gave 68, Got 306
Originally Posted by audiphile76 View Post
sony v4500 series, samsung a556 and samsung a676 series all have the mpeg-4 capabilities.
Not in the UK.
Benwolf, try having a look round Pixmania.com. They normally supply French TV's, so they should have MPEG-4 tuners in.
http://en.wikipedia.org/wiki/Freeview_(New_Zealand)
Old 12-11-2008, 6:21 PM   #5
11,707, Level: 25
Activity: 2.7%
Originally Posted by ziffius View Post
not in the uk.
Oh!, thats disappointing! Here in Finland all the above series have the MPEG-4 playing capabilities. Maybe the OP should order one from pixmania.com instead.
Old 12-11-2008, 6:34 PM   #6
79,103, Level: 68
Here's a big list of all the French models which have MPEG-4 HD tuners in TV LCD/Plasma +90 cm, recherche avec lcd, hd ready 1080p, hd tv 1080p, tuner mpeg4/hd
Be careful of the Sony's as it's hard to tell which have the MPEG-4 tuners in. I think ours is the 40W4000U, the 40W4000E seems to have the MPEG-4 tuner in, but i'm unsure about the 40W4000AEP but it looks like it doesn't.
Old 12-11-2008, 6:46 PM   #7
17,134, Level: 31
Activity: 13.6%
Surely thats because in Finland DVB-T is Mpeg4? -its mpeg2 in the UK until next year when some HD multiplexes will be in Mpeg 4. A HD TV will have to be able to decode both then but as yet AFAIK no manufacturer is offering this in the UK
Old 12-11-2008, 7:16 PM   #8
79,103, Level: 68
Thinking about it, if you want to buy from the UK instead of France there might be a couple of sets that have them in. I think the LExxA756, LExxA856, and LExxA956 have them in as they still have the MPEG-4 decoding hardware in to play MPEG-4 files over USB/ Ethernet. I don't know if you would have to flash them with the French firmware though. I've no idea if you could use the NZ firmware on them with a bit of renaming of the files as they normally get the Asia models. I'm sure there were a couple of other manufactures TV's that could play MPEG-4 files over USB too.
