1080 p lcd tv as a computer monitor ?
Old 11-08-2008, 3:36 PM   #1
2,382, Level: 11
Points: 2,382, Level: 11 Points: 2,382, Level: 11 Points: 2,382, Level: 11
Thanks: Gave 7, Got 16
Been thinking of getting a sony 40 inch tv(1080p 1920*1080) as a monitor just wonder if anybody has used there tv as a pc monitor .Would be nice to hear from ya
Forgot to add my g/card has hdmi out but dont think it has sound on the hdmi out
Old 12-08-2008, 11:50 AM   #2
3,739, Level: 14
Points: 3,739, Level: 14 Points: 3,739, Level: 14 Points: 3,739, Level: 14
Re: 1080 p lcd tv as a computer monitor ?
I have a Samsung 40" tv and have been using it as a computer monitor for the past year - it is so good I would never go back to an ordinary computer monitor. I have it connected to a Dell laptop and use a wireless keyboard and mouse. At a resolution of 1080p I use the zoom function of the browser as text is too small at the default size on web pages - would be OK if I sat closer.
My laptop is quite old and so I have to use the vga input on the tv. As the Dell doesn't support 1920 x 1080 as standard I use Powerstrip to give me this resolution in win xp. If you have a more modern pc you could probably use dvi to hdmi or hdmi to hdmi and not have this problem.
Good luck
Old 12-08-2008, 11:58 AM   #3
2,086, Level: 10
Points: 2,086, Level: 10 Points: 2,086, Level: 10 Points: 2,086, Level: 10
Thanks: Gave 13, Got 39
Hi mate,
I use a Samsung LE52F96BD as my monitor in the front room (52" 1080p) and have no problems at all, the picture is crystal clear with no scanning issues or anything else. I sometimes have to increase text size with some web pages (as I sit 10ft or so away from the screen) but thats not an issue. I set my graphics card to 720 @ 50/60Htz (ATI 3650 HD card) for normal PC usage (this increases the size of icons) and set it to 1080p/24Htz when I'm watching HD/Blu-Ray from the HD/Blu-Ray drive or *legally* downloaded films.... I use a DVI-HDMI adapter for picture and a seperate phono lead for basic sound. I also have a wireless keyboard/mouse to limit clutter in the front room and clone a second screen in the spare room (19" no-make screen).
I couldn't be happier with this set up to be honest and I don't see any trade off with using my TV as a monitor, if anything it brings a lot of benefits. You may want to check that there are no known issues with using Sony's as monitors (I don't know of any). I assume you have an LCD 3/4000??
I hope that helps and if you have any particular query about my set up let me know.
Ashley
Old 12-08-2008, 12:00 PM   #4
5,331, Level: 17
Points: 5,331, Level: 17 Points: 5,331, Level: 17 Points: 5,331, Level: 17
Thanks: Gave 5, Got 7
I too am looking for a suitable set...
Have you tried 1280x720, if not, could you? and let me know what it is like quality wise..?? Im thinking of 1080p screen as they are not much more expensive than the hd ready screens I was looking at, but that res woul dbe way too small for my bad eyesight...
Which sammy do you have?
Old 12-08-2008, 12:01 PM   #5
4,127, Level: 15
Points: 4,127, Level: 15 Points: 4,127, Level: 15 Points: 4,127, Level: 15
Activity: 5.3%
Activity: 5.3% Activity: 5.3% Activity: 5.3%
Thanks: Gave 5, Got 269
I use my 1080p 50" plasma as a pc monitor sometimes and have just brought a T240HD which is 1080p also which i use everyday.
Old 12-08-2008, 2:26 PM   #6
3,739, Level: 14
My Samsung is the LE40M8. I can use 1280x1024 - this is supported by the Dell, and it looks pretty good. In fact if I'm using word I often switch to this resolution, then in excel I put back to 1920x1080 to give me more space to work with. Zooming in the browser (Firefox or IE7) is no problem - use Ctrl and the mouse wheel. Picture is softer in 1280 x 1024, but still good.
Old 12-08-2008, 2:30 PM   #7
3,739, Level: 14
Sorry - misread your post - yes I can use 1280x768, but doesn't look as good. I think it might look better on a set designed for 768, but I think it is worth to go and get a set that supports 1080p.
Old 12-08-2008, 3:57 PM   #8
4,127, Level: 15
Activity: 5.3%
Not the best pics but...
1080p
720p
It doesnt look it but the text is very sharp and readable at both 1080 and 720p
Old 12-08-2008, 5:34 PM   #9
JDM121
Posts: n/a
Barrel distortion.
Old 15-08-2008, 9:13 AM   #10
2,382, Level: 11
Thanks for the replys anybody do any gaming on pc if so would be nice to here how they handles . I use my pc to watch hd dvd films on my plasma but the picture does not fit well and looks a little blured the films do that annoying wide screen thing where the picture does not fill the top and bottom . also does this on my pc monitor .
Old 15-08-2008, 12:58 PM   #11
3,394, Level: 13
Points: 3,394, Level: 13 Points: 3,394, Level: 13 Points: 3,394, Level: 13
Thanks: Gave 0, Got 8
Yes it very good gaming if you set 1920x1080 @60mhz (1080p) as I used plug from PC to Samsung F86 40" - it very clean and much wider, I set my tv as Just Scan as it prefect size - very smooth and very colourful
Old 18-08-2008, 8:45 AM   #12
2,382, Level: 11
do you get any lag when gaming ?
