ideal tv size if sitting about 10-11 feet away?
Old 09-10-2007, 5:15 PM   #1
chauzer
Posts: n/a
what would be the ideal size for an LCD if i'm sitting 10-11 feet away?
thanks
Old 09-10-2007, 5:27 PM   #2
RAINS's Avatar
Thanks: Gave 52, Got 33
Re: ideal tv size if sitting about 10-11 feet away?
Depending on what you feed eat..... i would say 32"-37"
Old 09-10-2007, 5:34 PM   #3
Thanks: Gave 14, Got 4
I would say around 36in to 42in
Old 09-10-2007, 5:36 PM   #4
Thanks: Gave 5, Got 361
32" is way too small. 40" perhaps upto 46" if you watch a lot of 2:35 films.
Old 09-10-2007, 5:42 PM   #5
jason g's Avatar
Thanks: Gave 4,341, Got 1,971
ive got a sony 46x2000 and am about that distance, seems ok to me.
Old 09-10-2007, 5:50 PM   #6
ChrisGgr's Avatar
Thanks: Gave 897, Got 1,654
40" minimum.But maybe the 46" fits also
Old 09-10-2007, 7:06 PM   #7
fallows's Avatar
Thanks: Gave 3, Got 13
40'' minimum...42'' maximum...any bigger and you will get pixelated screen (remember you are supposed to be x3 times the screen size away)
rich1068 (09-10-2007)
