Originally Posted by s.t.s bump
I am struggling here guys  can anyone recommend a free coms program that will do what I want. the only things I have found don't seem to work as *I* expect them to (which is not to say they don't work, just I don't understand how to use them) |
I think you'll find a google search for "Tera Term" will give you what you need.
When connecting to a device which has a serial (RS-232) port, not only should there be instructions relating to the commands it supports, but also the appropriate settings for establishing a connection (baud rate, data bits, parity, stop bits and, on occasion, flow control). These settings will often be presented in a format like this:-
9600-8-n-1, or 9600, 8, n, 1
(9600 baud, 8 data bits, no parity, 1 stop bit)
The terminal client (like Tera Term) will present you with fields to complete for these settings after which there will be a "connect" option (or similar). After you connect to a serial device it is often necessary to "wake it up" - that is when you connect, the terminal client will say that you are connected, but you find yourself staring at a blank screen. Hit the enter key a couple of times and see if anything happens. From there it's a case of entering the commands you have at your disposal to see what happens...
Beyond this, I'm not sure there's any more I can advise you on if the instructions for this TV aren't obvious. Alas, not all devices will give you an positive response to acknowledge what you are doing - or in some cases wont give you a response if the command you are entering is incorrect, it will only acknowledge properly formatted commands. Sometimes this is because the connection settings aren't quite right (in which case you can only experiment, by selecting slower baud rates - though the 8,n,1 settings are pretty consistent), or the RS-232 connection is designed more for engineers and repairers who will know what do do with the connection because they have a service manual.
