Toshiba X3030D Settings and Calibration
Old 27-07-2008, 9:05 PM   #601
RockySpieler's Avatar
5,882, Level: 18
Points: 5,882, Level: 18 Points: 5,882, Level: 18 Points: 5,882, Level: 18
Thanks: Gave 92, Got 137
Re: Toshiba X3030D Settings and Calibration
Even with the dark screen, can you still bring up the service menu?
If so write down ALL the settings and post them here.
The folowing were posted in this same thread.........try searching for some others.
Originally Posted by CoolSpy View Post
No clue if this was your settings, but here are my factory settings....
Type Addr Data Binary
Opt1 0055H 39H 00111001B
Opt2 0056H 00H 00000000B
Opt3 0057H 20H 00100000B
Opt4 0053H 83H 10000011B
Opt5 0058H 07H 00000111B
Opt6 0059H 00H 00000000B
Opt7 005AH 00H 00000000B
Opt8 005BH 00H 00000000B
TVOP 0054H 10H 00010000B
ID 02FEH 22H 00100010B
BWID 37FCH 00H 00000000B
BDHIT 37FDH 00H 00000000B
RCUT 224DH 00H 00000000B
GCUT 224EH 00H 00000000B
BCUT 224FH 00H 00000000B
RDRV 224AH 83H 10000011B
GDRV 224BH 78H 01111000B
BDRV 224CH 86H 10000110B
BRTC 2020H 03H 00000011B
COLC 2046H A8H 10101000B
UVTT 207FH F5H 11110101B
CNTX 2005H 86H 10000110B
VOLUX 1224H 7FH 01111111B
PLLW0 1100H 14H 00010100B
PLLW1 1101H 03H 00000011B
PLLW2 1102H 0FH 00001111B
PLLW3 1103H 05H 00000101B
PLLW4 1104H 14H 00010100B
PLLW5 1105H 04H 00000100B
Old 27-07-2008, 9:17 PM   #602
5,882, Level: 18
Originally Posted by tvdavid View Post
Hello
The screen wont come on at all and there is no backlight on so I cannot see this.
Can you shine a light onto the screen, does this help?
Old 27-07-2008, 9:32 PM   #603
5,882, Level: 18
I have got a light but still cannot see anything.
Sorry I am out of ideas, I am not aware of a button combination for factory settings reset, could be worth googling.
Old 28-07-2008, 11:29 AM   #604
3,800, Level: 14
Points: 3,800, Level: 14 Points: 3,800, Level: 14 Points: 3,800, Level: 14
Thanks: Gave 27, Got 21
What noone wants to tell you is that if you've knackered the tv by fiddling in the service menu you might be looking at buying a new tv.
Your only chance would be to deny everything and claim on the warranty. A Toshiba service engineer could probably fix it but if you tell him you were messing in the service menu you might as well say you had the back off and were playing with the soldering iron.
Hopefully whoever is coming round knows what to do.
I strongly suggest you just say the set suddenly stopped working.
Old 08-11-2008, 2:18 AM   #605
5,882, Level: 18
For HTPC users with the 42X3030D, I was reading about 48Hz display LCD TV's, and it gave me another nudge to try and get Powerstrip timings working.
1280x720@48Hz and 1280x720@47.952Hz.........
These timings seem to work ok, I've got XP SP3, S939 X2 4200 and HD2600XT (via DVI>HDMI), 4GB RAM ('ish). I'm using reclock with MPC-HC (only overlay works without tearing, EVR & VMR9 no good).
The 47.952Hz is meant to be for 23.976fps*2, it works well, although I've only just set it up and more watching is required.
For both these timings Powerstrip's OSD (CTRL-ALT-O), and Reclock's display properities report these as 48.0Hz (correct to 1 decimal place), however when I go into Powerstrip's advanced timings it has the 48.000Hz and 47.952Hz respectively.
With 23.976fps material I am using the 47.952Hz refreshrate, with 23.976fps LOCKED with reclock.
I appreciate this is Dutch to most people, but it may help somebody.
1280x720@48Hz
PowerStrip timing parameters:
1280x720=1280,448,40,208,720,5,5,20,71136,528
Generic timing details for 1280x720:
HFP=448 HSW=40 HBP=208 kHz=36 VFP=5 VSW=5 VBP=20 Hz=48
VESA detailed timing:
PClk=71.14 H.Active=1280 H.Blank=696 H.Offset=432 HSW=40 V.Active=720 V.Blank=30 V.Offset=5 VSW=5
Linux modeline parameters:
"1280x720" 71.136 1280 1728 1768 1976 720 725 730 750 +hsync +vsync
1280x720@47.952Hz
1280x720=1280,448,40,208,720,5,5,20,71065,528
PClk=71.07 H.Active=1280 H.Blank=696 H.Offset=432 HSW=40 V.Active=720 V.Blank=30 V.Offset=5 VSW=5
"1280x720" 71.065 1280 1728 1768 1976 720 725 730 750 +hsync +vsync
"1280x720" 71.072 1280 1728 1768 1976 720 725 730 750 +hsync +vsync
Old 08-11-2008, 7:31 PM   #606
5,882, Level: 18
I was unhappy with the reported refreshrate by Reclock, so I did some more digging, and you have to clean-up out the video timings database, if you change your settings, once done I got both Reclock and Powerstrip to agree on the refreshrate (Powerstrip has a camera icon beside the refrehrate on the main page).
Unfortunately they both agreed on 47.948Hz, so a minor adjustment gave me better framerates. There is still some drift 47.949Hz to 47.953Hz as I watch, but I have read on avsforum.com that ATI's HD series do not have stable clocks.
These timings are for 47.957Hz, which Reclock, and the Powerstrip Refreshrate Camera both report as my target 47.952Hz:-
1280x720=1280,448,40,208,720,5,5,20,71072,528
Old 10-11-2008, 12:04 AM   #607
5,882, Level: 18
These are the timings for 1920x1080@47.957 (Reported as 47.952 by Reclock), looks ok, watching Clone Wars at the moment, the space ships seem to glide smoothly. I am using the PC aspect ratio option on the 42X3030D settings. I have been here before trying 1080p48, with my Nvidia 6800GT, and I was unsure if the TV was downsampling to 1080p24 and telecin'g to 1080p60, but I think this looks smoother.
1920x1080=1920,528,44,148,1080,4,5,36,142431,528
Generic timing details for 1920x1080:
HFP=528 HSW=44 HBP=148 kHz=54 VFP=4 VSW=5 VBP=36 Hz=48
PClk=142.43 H.Active=1920 H.Blank=720 H.Offset=512 HSW=44 V.Active=1080 V.Blank=45 V.Offset=4 VSW=5
"1920x1080" 142.431 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
Old 13-01-2009, 8:10 PM   #608
1,097, Level: 7
Points: 1,097, Level: 7 Points: 1,097, Level: 7 Points: 1,097, Level: 7
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Hi, i have been very stupid by changing the service menu settings on my TV and didnt note down the defaults.
Could someone kindly post the default service menu settings? or do i just go with 'Rockeyspeilers' quoted settings?
My GF is going to put me in tommorow soup if she finds out!
Please only helpful posts, remember we've all made mistakes :D
Old 15-01-2009, 9:39 AM   #609
Sephiroth0000's Avatar
4,005, Level: 14
Points: 4,005, Level: 14 Points: 4,005, Level: 14 Points: 4,005, Level: 14
Thanks: Gave 142, Got 76
Im sure that everyones service setting is going to be different. Putting in someone else's settings may damage it even further.
Old 10-04-2009, 10:38 PM   #610
4,641, Level: 16
Points: 4,641, Level: 16 Points: 4,641, Level: 16 Points: 4,641, Level: 16
Thanks: Gave 106, Got 5
Any word on an update to the software problems?
Old 01-11-2010, 9:16 PM   #611
Bloodzeed's Avatar
3,267, Level: 13
Points: 3,267, Level: 13 Points: 3,267, Level: 13 Points: 3,267, Level: 13
Thanks: Gave 510, Got 230
is it just me some of you guys have the Backlight very low why i set that to low most of my games are
way too dark. So i have might around 55
Old 17-06-2011, 6:08 PM   #612
Excuse me for the necro,
But I attempted pm'ing relevant posters within the thread with no luck first.
I have the 37" panel. And well. was wandering if anybody ever figured out optimum service mode settings for it?
Sadly, I am currently unemployed. So cannot afford expensive kit to work out my own settings beyond test cards.
I use my panel ONLY as a pc monitor. And do find the settings make a much bigger impact of usability than just with video content.
Old 25-09-2011, 11:09 PM   #613
1,713, Level: 9
Points: 1,713, Level: 9 Points: 1,713, Level: 9 Points: 1,713, Level: 9
Thanks: Gave 0, Got 2
What sound settings are people using and what exactly is "Stable audio"?
No matter what I do the unit sounds horrible and muddy. In comparison my Sammy LEA656 sounds like a top notch hifi and that's saying something.
Also is there a way to detune the tuner? We only use it as a PC Monitor.
