Samsung service menu help needed quickly
Old 29-07-2012, 11:29 PM   #1
Hi i was messing around with the service menu for my samsung tv and somehow i managed to flip the screen upside down and the colours are quite pixelated need help asap as it is our down stairs tv and so we havent got a tv to watch now.
Old 29-07-2012, 11:32 PM   #2
Also if a picture with the model info is needed i can upload it
Old 30-07-2012, 6:17 AM   #3
Curly99's Avatar
Thanks: Gave 773, Got 1,887
If you post the model number then I can move it to the correct forum for your TV, helps you get the help need for your type of TV.
Curly
Old 30-07-2012, 1:50 PM   #4
GGTVBD's Avatar
Thanks: Gave 230, Got 322
Obviously not needed that quickly...
Old 30-07-2012, 11:02 PM   #5
Won't let me upload me a picture but these are the details.
Model: LE32C350D1W
Model Code: LE32C350D1WXXU
Type No.: LE32C350
Old 30-07-2012, 11:07 PM   #6
Orson's Avatar
Thanks: Gave 483, Got 509
<<< Thread moved >>>
Old 31-07-2012, 12:05 AM   #7
Cheers for the replys and moving the thread appreciate the help.
Old 31-07-2012, 9:22 AM   #8
GGTVBD's Avatar
Yet another example of messing with service menus.
Last edited by Orson; 01-08-2012 at 4:23 PM. Reason: Remove irrelevant information
Old 31-07-2012, 7:13 PM   #9
GGTVBD's Avatar
You either need a decent TV engineer or a service manual, which could be obtained from www.chsinteractive.co.uk
Last edited by Orson; 01-08-2012 at 4:25 PM. Reason: Remove irrelevant information
