Samsung UE**ES8000 Owners Thread Part 5
Thread Closed
Old 15-07-2012, 8:35 PM   #31
mwjdavies's Avatar
Thanks: Gave 85, Got 47
How do you view the camera from a phone?
Is this via a webpage or app (iOs or android?)
Many thanks
Old 15-07-2012, 11:02 PM   #32
Thanks: Gave 0, Got 3
Just ordered a Samsung E551 sound bar and a Panasonic 320 blu ray player to go with the new 55ES8000.
Hope it all works well together.
Old 15-07-2012, 11:57 PM   #33
Limited Member
Thanks: Gave 0, Got 2
Originally Posted by sutton8 View Post
Well my eyes would be drawn to it regardless of where. It would be on my mind. Though I recently sold a monitor with a stuck pixel bottom left which really annoyed me yet the guy who bought it couldn't care less. Different tolerances I guess but I'd be mad if I had one on a 2500 TV
As to the chances of an improved replacement set then it is clearly a risk. I got lucky with my second set which I am keeping until OLED are cheaper. Some people have changed four or more which takes time but is worthit if you want your proper monies worth.
The only time I've been bothered with a stuck pixel was when I had a portable archos player :P Though I guess for the money spent, expecting a tv with perfect pixels isn't too much to ask.
Watched a couple of films as it got dark tonight and can settle for the picture apart from the painfully obvious light bleed cutting across the black border and picture from the top right hand corner of the screen. I saw that someone figured out how to fix problems with the screen by unscrewing the back panel and slightly loosening certain screws. This give them a perfect and uniformed screen. Not something I'm willing to try at the moment.
Likely to be phoning John Lewis tomorrow and see if I can get a replacement. It's a bit of hassle, though it should be worth it in the long run. Fingers crossed.
Old 16-07-2012, 12:05 AM   #34
Have you tried the youtube fix?
Old 16-07-2012, 12:07 AM   #35
Limited Member
Yeah, I tried that earlier on. First of via the YouTube app on the tv, then I figured I could put the video on loop if I downloaded it to my computer and streamed over my network. I think it was on for over an hour. Could try it again tomorrow.
Old 16-07-2012, 7:09 AM   #36
Thanks: Gave 22, Got 105
Originally Posted by mwjdavies View Post
Many thanks
Using skype todo a video call, the mrs worked it, she knows her fidlly tech
So had a few hours gaming, 1080p/60hz checkerboard 3d on a active is a much cleaner/sharper image than my beloved passive's.
Seeing as how i have 3dvision working then this tv is floating my boat, i found blur due to pixel response time is more than acceptable, especially compared to a lg 760t, input lag is allso ok with a pc labeled input.
3d films are a pleasure to watch allso , interpolation is nce and smooth, sure there's the usual artifacts but i find them tobe suppressed quite good, i'm happy enough considering i've allways slated lcd active, smasung have come along way since that c750.
Crosstalk performance is actually pretty good, not the best but i seen nothing last night gaming that would hurt my viewing pleasure, i'll just have to deal with teh small amount of xtalk here and there, i miss my ld920 allready, 3d xtalk monster muncher it was
I've seen better colour's, for a premium tv the colours suck alittle, but then that does'nt really affect me, as long as i have 3dvision at 1080p/60+60fps i'm over the moon, checkerboard rules the roost over interleaved.
The glasses are'nt too bad, i need to raise my tv up as i find the glases/my head needs to be straight at the tv instead of my usual head leaning slightly forwards for the 3d performance to work best, tilting head slightly up or down introduces xtalk, there is a very small windows to hit that pefect spot, i found wearing my glasses over my eardrums made the glasses angle up slightly which combatted my forward tilting head, neck posture and lifted my head up, looks like it's all about neck posture for me
There is alot more xtalk than passive but oh well, i'm happy enough, and if i was'nt happy i'd know, but then all i care about is getting that magic 1080p/60hz with 3dvision and having a good enough gaming image with no obvious flaws that are seen every minute.
Old 16-07-2012, 9:10 AM   #37
GokuSS4's Avatar
Thanks: Gave 251, Got 126
Replacement coming tomorrow, better get that box ready again >.<
Old 16-07-2012, 9:42 AM   #38
Anyone use fancy HDMI cables with these sets? Make any difference?
Old 16-07-2012, 9:50 AM   #39
Thanks: Gave 7, Got 4
I remember when I got my self apparantly this great HDMI cable and I paid £69.99 for it and used it up against my old £4.99 and there was no difference whatsoever.
Expensive HDMI cables are the biggest waste of money IMO.
Old 16-07-2012, 10:00 AM   #40
Thanks: Gave 46, Got 128
Yeah I use Amazon Basics High Speed for all my AV and PCs. They are under a tenner dependent upon length. Given that I am only sending a digital signal less than two metres they more than suffice. If I was sending a signal 20 metres or more then i'd give the cable a bit more thought.
Old 16-07-2012, 10:06 AM   #41
I watched the 3D version of Clash of the Titans and the Xtalk was so bad that I never bothered again for months. Though recently I watched the Wimbledon final in 3D and a couple of other BDs and there was no problem, so perhaps the earlier experience was due to the poor version. The bigger problem for me was clouding given that the 3D settings turn the backlight right up and also switch on more of the processing options. Since I watch so little 3D I have never bothered investigating the settings. Would never even bother with the 2D to 3D conversion. Last year my Samsung plasma was useless at that.
Old 16-07-2012, 10:10 AM   #42
GokuSS4's Avatar
I was playing Assassins creed revelations yesterday in 3D, it looked ok but even though it was playing in 720p according to the tv when I pressed the info button there is a huge difference when going to 2D 1080p.
Old 16-07-2012, 10:52 AM   #43
Just ordered 3 of these cables, seem to tick the boxes...
1m HDMI Cable - Blue genius
Old 16-07-2012, 11:17 AM   #44
GokuSS4's Avatar
1440p and 2160p
Is my ES8000 already obsolete?? I thought I bought the best where can I get a 2160p tv from??
Old 16-07-2012, 12:45 PM   #45
Originally Posted by GokuSS4 View Post
1440p and 2160p
Don't worry plenty of time yet.
2160p - Wikipedia, the free encyclopedia
Old 16-07-2012, 1:20 PM   #46
Limited Member
Holographic Versatile Discs and Blu-ray Disc may be used for 2160p video, since it theoretically has a storage capacity of up to 10 Terabytes
Wow. Imagine streaming that video content via LoveFilm over a 3Mb/s connection :P
Old 16-07-2012, 3:56 PM   #47
Thanks: Gave 64, Got 88
I, too was anxious about 4k2k, but then I read this....
http://m.techradar.com/news/televisi...g-time-1065703
GokuSS4 (17-07-2012)
Old 16-07-2012, 10:54 PM   #48
mwjdavies's Avatar
Just got Disney WOW disc.
Ran the pixel flipper for 3 hours, and even before I started to look at the calibration segments, I immediatley noticed a massive improvement in the clouding.
So thanks to Arenaman for planting that idea in my head to try that :-)
Still got a way to go on the calibration side, only done the basic settings section so far, advanced and expert to go! Haha
Old 17-07-2012, 7:35 AM   #49
Thanks: Gave 0, Got 6
Where did you get the Disney wow blu ray from ?
Old 17-07-2012, 9:38 AM   #50
Dave_nt's Avatar
Thanks: Gave 4, Got 20
It's on amazon as an import. You can download the manual from Disney to see what it covers.
Old 17-07-2012, 1:48 PM   #51
Just got a Panasonic 320 from eBay delivered £136, should be a nice match for the ES8000 when it arrives next Tuesday.
Old 17-07-2012, 2:10 PM   #52
GokuSS4's Avatar
Is it a movie or does it fix clouding? Kinda confused on why its import only? How much and asny UK sellers?
Old 17-07-2012, 2:18 PM   #53
Dave_nt's Avatar
It's a calibration disc with a 'pixel flipper' section which I guess is the same as the YouTube videos previously posted. No idea if it fixes clouding. Says new from £13 on amazon. Presume there will be a uk release at some point.
Old 17-07-2012, 2:29 PM   #54
GokuSS4's Avatar
Can someone please post up a picture of the back of the tv for the connections dvi audio in, ext (rgb) and headset mine looks like its missing connectors got 2 holes that look the same and well it doesnt look right :-(
Edit: Found an image here: http://www.hdtvtest.co.uk/news/samsu...1205301790.htm
Mines looks the same so I guess normal? :-/ well lets plug it in and see how this replacement is, strange thing is the scellotape on the box was very very old and box was a bit dusty and tatty as if it was from an extremely old batch however the glasses are the latest 4100 series so very odd.
Old 17-07-2012, 2:51 PM   #55
Thanks: Gave 43, Got 18
Had my tv for 2 weeks now, from john lewis , i have recieved the price match amount back into account fine, but on site still says order processing no where to click for reciept so can print out and claim for the galaxy tab,
just phoned them and they say will post one out next few days, think i got till sept till this offer closes
Old 17-07-2012, 3:05 PM   #56
Still liking it lombard? Mine comes next Tuesday.
Old 17-07-2012, 3:12 PM   #57
ya, i settled on standerd setting as seems more vivid then movie settings without having to increase backlight, during day its amazing the blacks etc, at night in pitch black room blacks are grey but thats the draw back with lcd i guess, also abit of touching on right bottom hand corner when viewing movie with borders in pitch black room , during the day the blacks look great and colours are really good
Old 17-07-2012, 3:36 PM   #58
Thanks. Hopefully I will not be bothered with the grey blacks as I never watch a film in pitch black, always have low lighting on.
Old 17-07-2012, 4:17 PM   #59
Two issues/questions
As my settings might be wrong somewhere i would like to ask you the following:
1. Did anybody experience some sort of flickering while watching moving scenes e.g. soccer games - and it is visible only where more detail is present - the stands and the fans. When the camera stops moving the flickering stops. Maybe there is a different term instead of flickering. HD Sat Receiver is connected through AVR.
As this happens also with my camera recordings (60p/60i) especially when there is greenery and a lot of sun/brightness, I was suspecting that it has something to do with the refresh rate.
I play my camera recordings via PS3 and through the AVR.
I experimented with the judder and blur settings but in both cases if I stop the flickering I lose detail or something else in the other hand.
2. What do you use in order to adjust R/G/B - the white balance menu or the 10p menu.
Could you please tell me the difference.
Thanks in advance
MG
Old 17-07-2012, 4:57 PM   #60
Thanks: Gave 75, Got 64
I find using the Eco sensor works a treat.bright during the day and when sitting in the pitch black room the screen brightness adjusts perfectly.
Mine is set to bottom out at 4
Thread Closed
