The LG LW550T 3D LED Thread Part 9
Old 04-07-2012, 9:28 PM   #1
RottenFox's Avatar
Thanks: Gave 2,090, Got 3,672
Discussion continued from here:
http://www.avforums.com/forums/lg-fo...rt-8-a-17.html
Old 04-07-2012, 9:49 PM   #2
Thanks: Gave 1, Got 10
Round up of some useful functions,
Save channels on usb memory stick:
1- insert usb memory (format FAT 32) in usb port 1
2- keep ENTER button pressed untill setup menu ends and the info bar shows at top of page, then press "1" "1" "0" "5" "OK"
3- choose "TV-LINK LOADER" and either "Recieve from USB" or "Send to USB"
Downgrade Firmware:
1- Download "GP3_EU_BB_[Special_ChangeOldKey]_C0_RevNo59622_V09.00.00_ota_V2_SECURED.epk" firmware
2- Place it in an LG_DTV file on the usb stick (FAT32) and stick it in lg usb port 1
3- When the TV recognizes the FW, press ok to flash and let the TV finish the flash completely and restart
4- Download a favourite previous firmware and place it in the LG_DTV file on the usb stick and insert in usb port 1.
5- It'll tell you the fw 9.00 is newer. Highlight option in menu and press favourite key 7x times and a new menu appears asking whether you want to update to fw on usb stick....choose which firmware if you have more than one on the usb memory....
Downgrade Firmware ALternative:
1- put firmware "GP3_DVB_EU_BB_MP_2Q_C0_RevNo56681_V04.04.11_usb_V 2_SECURED.epk" (same link as above) in an LG_DTV file on the usb stick (FAT32) and stick it in lg usb port 1.
2- When the TV recognizes the FW, press ok to flash and let the TV finish the flash completely and restart
3- YOu can now flash newer firmwares, start with 05.01.10...
coalfield (08-12-2012)
Old 05-07-2012, 4:01 AM   #3
LG CINEMA 3D – telewizor LG LW570S - wszystko o serii LW 570S - Strona 185 - HDforum
The firmware above will re enable the service menu options. It worked for my LK950s. It will also allow a forced firmware upgrade via the previous method. Highlight Option in the menu and press Fav 7 times. If you do force a firmware update you must make sure the firmware is compatible with your tv model.
Old 05-07-2012, 8:31 AM   #4
looks like the eastern European lg forums are way ahead of us here in avforums...now we just need an English translation...
Witam
Prawdopodobnie powrót do dowolnej starej wersji softu wg kol z Rosji
Cytat tłumaczone przez gogle
"Jeśli czytasz moje posty, jak poinformowali, należy wiedzieć, że skoro oprogramowanie ..... 05 rollback do starego firmware i oprogramowania jest zablokowana. Aby przywrócić wykonać następujące czynności:
1. 09.00.00 Pobierz specjalny program (do serialu LW wyłączeniem 4500, z drugiej serii osobisty niezaznaczone), który zwalnia blokadę firmware Telly byle firmware, link mogę napisać wcześniej.
2. Sformatować dysk flash do FAT32.
3. Utworzenie folderu LG_DTV.
4. Skopiuj ten firmware folderu 09.00.00
5. Włóż kij do telewizora.
6. Włącz telewizor.
7. TV będzie oferować zaktualizować firmware, trzeba się zgodzić.
8. Poczekaj, aż TV proshetsya i ponownie uruchomić komputer, wyjmij kij.
Następnie pobrać swój ulubiony stary firmware, i działać jak opisane wcześniej. Jeśli spróbujesz zainstalować starego oprogramowania, bez konieczności instalowania 09.00.00 następnie zostanie podany do Tele błędu i pozostanie na Oprogramowaniu prezhnm Telly Teraz, gdy już uruchomiony."
Old 05-07-2012, 10:38 AM   #5
translation
Probably back to any old firmware version from Russia by kol
Quote translated by the goggles , "If you read my posts, as reported, you should know that since the software ..... 05 rollback to the old firmware and software is locked. To restore the following steps: first 09.00.00 Download a special program (excluding the LW series 4500, with a second series of personal unchecked), which releases the lock as long as Telly firmware firmware, the link I post earlier. second Format the flash drive to FAT32. 3: Create a folder LG_DTV . 4th Copy the firmware folder 09.00.00 5th Place stick to the TV. 6th Turn on the TV. seventh TV will offer a firmware update, you have to agree. 8th Wait proshetsya TV and restart the computer, remove the stick. Then download your favorite old firmware, and operate as described above. If you try to install the old software without having to install 09.00.00 then be communicated to the Tele bug and will remain on the Software prezhnm Telly Now that you've started. "
Old 05-07-2012, 11:18 AM   #6
In simpler terms,
1- Download the said "GP3_EU_BB_[Special_ChangeOldKey]_C0_RevNo59622_V09.00.00_ota_V2_SECURED.epk" firmware
4- Download a favourite previous firmware (05.07.10 or 05.08.05 ?), place it in the LG_DTV file on the usb stick and flash it as above
5- Enjoy...
Who's going to be the first to try it....?
Will the language be Russian by default after flashing?
Old 06-07-2012, 1:33 PM   #7
Firmware rollback
Does anyone know if it is possible to change the firmware name/version so the TV sees the file a new version? Just a thought
Old 06-07-2012, 2:00 PM   #8
No, I've tried and of course it didn't fool the TV....
The only way seems to be the above, there is a long thread in russian on the downgrade and I'm sure there's lots of info there but no one here has tried the downgrade yet...
Old 07-07-2012, 5:20 PM   #9
42lw5500ze
Heloo
i have tried mentoined procedure at least 10 times reverting all posible combination,so conclusion downgrade is posible i have 4.04.11 lower and it worked even in this version downgrade.
what i have notice,when i use lower version youtube is not working it asks for update other isues i have no notice.
Procedure is described before ,before any ver flash u must be on 9.00.
Old 07-07-2012, 6:14 PM   #10
When we flash GP3_EU_BB_[Special_ChangeOldKey]_C0_RevNo59622_V09.00.00_ota_V2_SECURED.epk
are we then on 9.00.?
which is the default language after reboot, English?
Old 07-07-2012, 6:36 PM   #11
Yes then you are on ver 9.00 and
all setings remain untouched.
Old 07-07-2012, 7:40 PM   #12
Thankyou roki199
I confirm it works....
is the magic downgrade to firmware 9.00
Once you've downgraded to 9.00 you can install any older firmware you want.
Now I need the good firmware from last winter which supposedly had the best iplayer and youtube compatibility...
EDIT: FIXED
After flashing 9.00 put the firmware of choice in the LG_DTV file and insert into usb port 1.
Highlight option in menu and press favourite key 7x times and a new menu appears asking whether you want to update to fw on usb stick....presto
Now I've got fw 05.01.10
Thanks to the guys in the Polish forum for this fix...
Old 08-07-2012, 10:28 AM   #13
Ive gone back to 05.11.08 because some smart tv apps wouldnt work with fw 05.01.10...
Old 08-07-2012, 5:14 PM   #14
wad wad is offline
Thanks: Gave 0, Got 6
glad we did`nt update after the last time with it taking hrs and what not just wont do it any more tv is fine as it is.
Old 09-07-2012, 10:05 AM   #15
Firmware rollback
Anyone know a good place/reliable source to download these for my 550T-ze
or if they are compatible, thanx in advance
Old 11-07-2012, 8:23 PM   #16
Thanks: Gave 3, Got 36
use the links provided at the site, from here, downgrade to 4.x and first version you get asked to update to is 5.1.10 and you can take it one by i guess.
Old 12-07-2012, 12:35 AM   #17
wad wad is offline
21:9 screens
is there a lg 21:9 format tv in the lg range?
Old 14-07-2012, 7:54 PM   #18
Thanks: Gave 7, Got 4
Hi all. I'm looking for some advice/guidance. I picked up a 47inch 550T just before Christmas with the Sky offer. I've been really pleased with it. However, over the last two months I've witnessed a deterioration in the picture. It started with banding, especially with football. Then a judder developed when bright pictures with the camera panning around. This has got so bad that on screen channel idents will flicker and move all over the top corner. Ramsey's Prison cooking is unwatchable with its bright white kitchen. To add to it all, the top right corner is becoming noticeably lighter than the rest of the screen.
How do I best go about resolving this seven months after purchase, is this a retailer issue or best directed to LG?
Any guidance would be appreciated.
Old 14-07-2012, 8:18 PM   #19
Phone LG service and explain the problem, they are very good.
Theyll send a repairman to your house.
I recently had my screen replaced by LG on my kitchen table..
ontwofronts (14-07-2012)
Old 16-07-2012, 4:13 PM   #20
Limited Member
I'm currently trying to decide between this tv and the 42lm615t.
I'm not sure if I'll use Smart TV so important things would be:
-3d and 2d quality
-input lag
Thanks in advance!
Old 17-07-2012, 1:24 PM   #21
LV550W Record HDMI input?
Is there possible to record HDMI input to Harddisk(usb) if i downgrade?
Is it possible at all?
Old 17-07-2012, 2:33 PM   #22
You can only record from DVB-T freeview or DVB-C cable. And you can only playback on the TV you recorded it, not other LW550Ts or any other means such as pcs...
Old 18-07-2012, 12:28 PM   #23
Limited Member
I just bought this tv yesterday. Now I have a huge problem.
I connected my PS3 pressed power button until the second beep so it does video reset.
It gives me the usual HDMI device was detected do you want to use it?
When I press yes screen flashes after that no signal. Well I do a second reset and select no.
Then I go to PS3s display settings and find out that whenever I choose 1080p the signal disappears. 1080i works fine I get 1080p on two other LG TVs with the same cable so that is not the prob.
I updated the tv to 05.12.05 before I tested the PS3 could the firmware give the issues?
EDIT: I found that after you select that you want to use the hdmi device you need to chance input to anything else than your PS3 then change back. It will work that way. However I still need to do this every single time I launch a game because I can't get signal before I do the input switch.
Old 19-07-2012, 9:21 PM   #24
Could anyone confirm if "GP3_EU_BB_[Special_ChangeOldKey]_C0_RevNo59622_V09.00.00_ota_V2_SECURED.epk" will work on 42LW550T?
Old 19-07-2012, 9:49 PM   #25
yes, use the links and info above...
Old 19-07-2012, 10:34 PM   #26
i can confirm the same issue seen here, currently on 4.1.10, so i guess it on all editions of the firmwares available.
Old 19-07-2012, 11:27 PM   #27
wad wad is offline
we had issues with the ps3 and the tv took a few days to work it out and now no issues. we are now using a 1.3 hdmi cable plugged into hdmi1 set to console and all works, soon as the ps3 is turned on the tv changes to hdmi 1 and game mode, also simple link works too, none of that works before using hdmi 2 3 or 4 and we ditched the 1.4a cable what cost 70 quid and use cheapo 1.3.
Old 21-07-2012, 9:38 AM   #28
Thanks: Gave 0, Got 5
Did I read that correctly?, you paid £70 for a cable???
Old 21-07-2012, 10:05 AM   #29
He ditched it, probably took it back.
The only hdmi cables I've ever bought cost me €2.99 in the sales and I've never had any problems with them.
Old 21-07-2012, 11:57 AM   #30
wad wad is offline
yes and no the cable was thrown in with the tv deal, 69.99 they cost to buy and not even 1m long 80cm, yes they are a rip off, so did we pay for it in one way yes in another no. I buy the cheap ones biggest one I bought was 5m and cost 5.99 gold plated too rest are 2m and 2 to 3 quid.
