Samsung UExxD8000 Owners Thread *Part 8*
Old 24-06-2012, 1:52 AM   #31
Thanks: Gave 66, Got 22
Well Martin Dawes returned my repaired TV on behalf of JL today... Brand new screen fitted.....
Left it on all day.... All seemed ok until this evening in a darkened room. I watched a Blu ray and the amount of clouding is ridiculous... It's everywhere... I want to just ask for the new model one but it seems they are just as bad.......
Beginning to wish I waited a few years till technology was better
Old 14-07-2012, 3:48 PM   #32
gd2 gd2 is offline
Thanks: Gave 2, Got 18
Ask to use the John Lewis Happy returns policy and get either an exchange or refund if within 1 year. I did and they are doing this for my D8000
Old 18-07-2012, 2:18 PM   #33
Thanks: Gave 3, Got 6
Flickering on patterns and Firmware 1024.1
1. Something that's annoyed me for ages - when watching a BD or HD TV, I get something like an interference pattern on checked patterns (things like a tweed suit or tartan). Think the technical term is a Moiré pattern.
Does anyone have any tricks to get rid if this, I'm thinking Sharpness is too high.
2. Anyone who has installed 1024.1 - did it change all your settings? If so, I suppose I'll have to go through and photo them all.
Any help much appreciated as usual.
Old 18-07-2012, 7:20 PM   #34
chrishi5's Avatar
Thanks: Gave 0, Got 3
yes it will change your settings
ShuggMcGlummfer (18-07-2012)
Old 21-07-2012, 2:58 PM   #35
Thanks: Gave 12, Got 61
ITV Player App downloaded today - and says it needs a firmware upgrade.
I'm on 1024 which seems to be the latest - but still says it needs a firmware upgrade.
Any ideas?
Old 21-07-2012, 3:06 PM   #36
Urien Rheged's Avatar
Thanks: Gave 446, Got 499
Any ideas?
It did the same on my D7000. I think a lot, if not all, are experiencing it.
Old 21-07-2012, 3:56 PM   #37
saguk1234's Avatar
Thanks: Gave 115, Got 121
Which ultra slim wall mount is used for the UE55D8000?
Old 22-07-2012, 3:50 AM   #38
Thanks: Gave 42, Got 52
This one: http://www.johnlewis.com/231454431/Product.aspx
I have a Brand new one for sale in the Classified section of Forum, maybe we can do a deal?
Old 22-07-2012, 4:21 AM   #39
Thanks: Gave 11, Got 21
Does anyone else see this problem... black and white checked shirts or things like tennis nets, basically black and white squares are something the TV can't handle as it kind of blurs.
Any ideas?
New firmware to use it out tommorrow!
ozsat (22-07-2012)
Old 22-07-2012, 5:33 PM   #40
Restricted Member
Thanks: Gave 60, Got 13
oooh hope it finally fixes that horrid light gray video issue with samsung apps (like Plex)
Old 23-07-2012, 12:19 PM   #41
This is the same thing as I posted back in #33, but it looks like we are the inly ones with the prob.
Old 23-07-2012, 6:06 PM   #42
Called Samsung today and they believed ITV Player should be working on D8000 - they got me to reset Smart Hub - but still doesn't work.
However, YouTube will now no longer remember that it has been activated - and I have to 'activate' everytime I use it.
Any idea whatis causing this?
Old 23-07-2012, 6:18 PM   #43
Restricted Member
no new firmware yet Where did you hear this?
Old 23-07-2012, 7:08 PM   #44
Seems I'm not the only one - https://productforums.google.com/for...be/JbX2gzbL5K4
Old 26-07-2012, 9:09 AM   #45
UE55D8005 pros and cons
I've had this puppy on gaming use for half a year, but decided to take it upstairs for the olympics. So, few thoughts and questions:
Good stuff:
- it's a computer with all kinds of stuff! I managed to set up VOD service and PVR with external USB (3.0) powered HDD
- With TVMobili, it connects automatically to my MAc and somehow found all pictures and videos. Don't know what happened after I installed TVMobili, but all was there, which is brilliant.
Annoying stuff (are there solutions?):
- the guide won't show program information as I surf through channels. Now, if there is a commercial break on I really can't tell which program is running and have to be accessing Info and Guide all the time. Really annoying, I guess in Korea they don't channel surf, but only watch TV when something worth watching is on.
- what's with all the useless information on screen: ' CI+ card, Successfully authenticated' every time I turn my TV on. And then 'Allshare device connected' every time I start my Mac. Also, the mute icon is always there when in mute. Yes, it's on mute, thank you and now go away!!
- Rovi has for some reason a limit on how many timed recordings I can make. Why on earth?! I would like to get all good stuff from Canal+ First HD to my HDD and watch them as I like, but noooo.
Problems and issues
- well, biggest problem is that about every fifth time the TV tuner somehow misses the signal, even with 100 on both signal quality and strength. This is really annoying, if PVR misses recording due to this 'feature'. Maybe the TV is too busy with all the announcements on CI+ modules and connected equipment...
- yes, it bleeds light visibly in three corners and lower left area. This is not nice with 2000€ TV. With good setting it is better, but still visible in darker scenes.
Conclusion
Good TV, but amazingly stupid features. Hopefully they will be fixed with future firmware. Every TV has its faults, and at the end of the day I do like my Samsung
Old 26-07-2012, 12:39 PM   #46
Thanks: Gave 6, Got 14
1025.1 firmware out today.
ITV Player now works
ozsat (26-07-2012)
Old 26-07-2012, 2:17 PM   #47
Thanks: Gave 1, Got 0
Thanks for the update shout
I can see from the thread what the patch addresses but they really should think about going back to the old way when they would give more detail about what the new patch addresses.
Old 26-07-2012, 4:13 PM   #48
Yeh!
ITV Player now working
Youtube - still not remembering authorisation
for a while my tv kept going in 3D mode on SkyHD - never did that before - but seems OK now
Old 28-07-2012, 1:26 PM   #49
Thanks: Gave 4, Got 1
Downloaded the .Exe file from Samsung put it straight on a USB stick but the Tv says it can not find the file any ideas?
Old 28-07-2012, 1:27 PM   #50
Restricted Member
you have to run the exe on pc and extract the files to usb
mikerobertson (28-07-2012)
Old 28-07-2012, 1:38 PM   #51
Many thanks thought as much the joys of having a Mac.........
Old 28-07-2012, 1:41 PM   #52
Restricted Member
IIRC I think you can use Winrar (or whatever unzipping equivalent on the mac) and extract the files from within that too.....its just a self extracting exe whatchamacallit
yup defo can just tried it. So a Mac alternative should work
USB should have in the root
T-GAP8DEUC/image/<approx 21 files>
Old 28-07-2012, 6:54 PM   #53
Thanks worked a charm update all ok.
Old 14-08-2012, 7:59 AM   #54
Thanks: Gave 2, Got 4
Hi guys, hopefully someone can answer this question which has been bothering me.
I am using this TV in conjunction with an Onkyo 608 Amp
I am using the ARC on the HDMI and when watching a video via DLNA with a DD 5.1 audio track the tv can be switched via the tvs sound menu from PCM to DD to output the DD back through to the amp using ARC, this also works for DTS, except i choose DTS instead of DD ( obv )
Now the annoying part is that i need to keep going back into this menu!
So, if i've just chosen DD, then next time i go to play a DTS audio, it reverts to PCM, so i need to go back into the settings again! there is no auto setting to switch between DD and DTS
Now, i assume there is no fix for this? maybe i can contact samsung to add an auto feature, but i doubt they will bother lol
Now here is my question.
i do this as i believe the PCM option only outputs 2.1 ( i could be wrong here, i am unable to check as the amp OSD is not visible when using ARC ), the amp simply shows PCM fs: 48khz on the front display
Is the PCM outputting 5.1? or 2.1? at this point?
Does anyone know?
Thanks for reading
Jay
Old 01-09-2012, 7:05 PM   #55
Hey,
Should micro dimming be off or on?
Old 22-09-2012, 3:25 PM   #56
Has anyone ever got the rovi epg to work i set it up and its blank all time?
Old 24-09-2012, 8:47 PM   #57
PAUL7331's Avatar
Thanks: Gave 83, Got 36
Anybody got any decent 'picture perfect' settings for this tv?
Old 27-09-2012, 5:09 PM   #58
You tried the "Samsung D7000 / D8000 - Settings & Calibration thread"? Samsung D7000 / D8000 - Settings & Calibration thread
Old 12-10-2012, 3:31 PM   #59
Originally Posted by davedowie View Post
Secondly, the tv has twice gone through a cycle of switching itself off then back on again about 7 or 8 times randomly. Can't find much about this except for a video on youtube! No solution given though.
Exact same issue here, latest firmware, doesn't seem to be any pattern to the issue, the TV will remain on after a couple of attempts to switch it back on....
Old 17-11-2012, 1:43 PM   #60
Thanks: Gave 5, Got 19
Had no problem with my set since i got it at the turn of the year, up until this morning when the screensaver came on by itself, i went into the menu and noticed the auto protection time was set to off. It as since come on again, so i'm abit unsure what else to do, the current software i'm using is 001021
