Originally Posted by ciscosurplus Sorry are you saying Samsung won't support a switch? I wonder then what will they support? Tech specs say Ethernet (LAN). To support Ethernet I can't see what else it could connect to? even routers have a series of switch ports build in and behave exactly like a switch.
If this is true what does the port support?
Can you clarify what you mean? |
The reply I got from them said "Please be advised that TV's only, may not support a network switch". From this I infer that not all Samsung TVs will work when connected to a switch but that other Samsung devices will (a Samsung BD player is connected to the switch and works fine). The same switch has supported various AV components, including a Panasonic TV, with no problem.
It was suggested that I connect a router to the switch (which I already had connected) and use a port on that or wireless. Wireless reception is patchy due to the router being through a couple of walls. A temporary 20m patch lead from the router to the TV, bypassing the switch, works fine. It's just the TV through the switch which is a problem. The switch is a netgear GS105 and I can't change port settings on it.
Now got another problem too
. On BBC Freesat channels the "red button" graphic keeps coming on and going off and each time it appears and disappears (several times a minute) the brightness/contrast changes very noticeably. This is only a problem on Freesat, not on Freeview. Anybody else seen this?
