LG 32Lv355u will it play mkv files from usb
Old 02-02-2012, 3:50 PM   #1
Thanks: Gave 7, Got 1
Hi all,
Before i purchase this tv i would like to know if it will play mkv films of my Usb, the specs say divx hd im getting confused because the tv specs on the shops website only saying divx hd and not divx hd plus? divx website says divx hd plus does play mkv, but does not clearly say if divx hd will also play mkv.
Thanks for your time all
Old 02-02-2012, 4:19 PM   #2
Thanks: Gave 569, Got 635
If you visit our website you can download the manual to check all the compatible file formats for our TV's
here is the link
LG 32LV355T Televisions - 32" Full HD LED TV with freeview HD - LG Electronics UK
click on the 'support' tab.
Old 02-02-2012, 5:42 PM   #3
Thanks alot for that will have a look now
Just looked and yes it plays MKV Wooop wooop
Old 03-02-2012, 7:03 AM   #4
It should play MKV files, but LG tvs have a lot of limitations. At least, I'm a bit dissapointed to the media player. If MKV has internal subtitles or audio tracks, you cannot select what to show/play. TV always selects the first ones, and usually they are not the right ones. So often you end up listening some dubbed audio track in wrong language. LG also doesn't support DTS audio, so you cannot hear audio in many videos. Also some other audio formats have problems. These are some issues, you should consider.
Old 15-02-2012, 8:00 PM   #5
Damn it i wish i read the post Robroy i have currently had the the Tv tonight and found out the damn audio is not working on playback, the picture is playing perfect though so im going to see if i can convert the audio on the films i have.
Please does Anyone know how to convert my current film sound files to one of these files
Audio format my TV will play : Dolby Digital, AAC, Mpeg,
MP3, LPCM, HE-AAC, ADPCM, WMA
