The Official LG UK 2012 TV Range
Old 21-02-2012, 6:26 PM   #61
Thanks: Gave 569, Got 635
Originally Posted by Bwlmog View Post
Thanks is there a particular reason why the 42LM640T is missing from your price list?
There could be, i'll need to check in the morning, sorry.
Old 21-02-2012, 6:59 PM   #62
Thanks: Gave 0, Got 7
Also seem to be missing 55LM669T
Old 21-02-2012, 7:17 PM   #63
Thanks: Gave 1, Got 12
I've been looking for a replacement set for my 60 inch 6 series Samsung. I bought the TV when the tuner on my LG 55LW650T packed up at Christmas just a few days after I bought it. I loved the set but it was in short supply so I went for the Samsung. A real mistake it doesnt show 3D in HD and the crosstalk is just awfull. I'm waiting for a refund at the moment and having had the larger screen I'm reluctant to drop down in screen size. I'm confused though, Your price list shows a 65LM620T but the excel sheet shows a 60 inch version. which version will you be supplying? Will the 60 inch+ screen sizes be available in April? I'll make do by bringing the bedroom TV downstairs if I dont have to wait for months
Old 21-02-2012, 8:12 PM   #64
Thanks: Gave 29, Got 14
I'm too interested in the 65LM620T
Old 21-02-2012, 9:17 PM   #65
Thanks: Gave 13, Got 5
Woo woo! Confirmation of the 65LM620T from @LGBlogUK when I asked:
@mrszymon There sure is! the 65LM620T will be available to buy in the UK soon!
I WANT I WANT I WANT!! :-)
-simon
Old 21-02-2012, 11:25 PM   #66
Thanks: Gave 6, Got 15
What's the difference between the LM660 and the LM670?
Old 22-02-2012, 3:29 PM   #67
Thanks: Gave 27, Got 11
Hi any update on the 42LM640T?
Old 22-02-2012, 3:59 PM   #68
Does anyone have the exterior dimensions of the 65LM620T?
Old 23-02-2012, 2:28 AM   #69
see pdf: EDI #65LM6200
Old 23-02-2012, 7:21 AM   #70
Originally Posted by meyerovb View Post
You all got the short end of the stick... the 55LM6700 I just pre-ordered cost £550 less than the what lg just announced above. Then again, I do have to pay for my own health care...
Interesting where did you order the TV from and is it the European spec ?
Old 23-02-2012, 4:20 PM   #71
Updated features spreadsheet with Final UK model numbers
LG 2012 TV Range | LG Blog
Old 23-02-2012, 4:37 PM   #72
thanks for the link but it does say TBD for the dimensions of the 65LM6200
Old 23-02-2012, 5:38 PM   #73
Hi any news on the 42LM640T you said you'd check on the price two days ago but I've heard anything since.
Old 23-02-2012, 8:17 PM   #74
Why are you scaring the crap out of me??? 670 is missing a dot in the cinema screen column! I just pre-ordered the thing.
Why are the 640 and 660 not available in the USA? I only see the 670/760/860/960 on J&R and Adorama
What's up with the colour column, filled in for 660 and 670 but none of the other cinema screen ones.
Grrrrrr.... sorry! the 670 is 110% Cinema Screen, i know this cos I took one out of a box this afternoon! i'll get the spreadsheet changed AGAIN!!
Old 23-02-2012, 8:20 PM   #75
its likely to be AROUND £899
Old 23-02-2012, 9:20 PM   #76
Thanks, any idea when the full specs will be available for this TV including dimensions?
Old 23-02-2012, 9:45 PM   #77
March 1st, on our website, maybe a couple of days before on blog/av forums.
Bwlmog (23-02-2012), J4CK DANIELS (25-02-2012)
Old 24-02-2012, 5:25 PM   #78
From what I can tell:
The 6700 has a non-brushed metal silver rounded bottom border.
Photo: 6700 full screen
Photo: 6700 bottom bezel
The 7600 has a non-brushed? metal black flat bottom border:
Photo: 7600 full screen
Photo: 7600 bottom bezel
The 8600 has a brushed? metal silver flat bottom border with a clear glass border beneath that.
Photo: 8600 full screen
Photo: 8600 bottom bezel
Please let me know if my observations are correct. Thanks for helping out!
Old 25-02-2012, 9:26 PM   #79
J4CK DANIELS's Avatar
Thanks: Gave 130, Got 242
I really wish that LG would do a cinema screen design WITHOUT that smart crap.... i'd really love to get one but don't want to pay the extra. the LM640 is looking awesome, i put money on that one being the best seller this year for LG
Old 27-02-2012, 7:04 PM   #80
Amazon.com list a few Models, some of them 300$ under List Price.
Amazon.com: LG Cinema Screen 55LM7600 55-Inch Cinema 3D 1080p 240 Hz LED-LCD HDTV with Smart TV and Six Pairs of 3D Glasses: Electronics
Amazon.com: LG Cinema Screen 55LM6700 55-Inch Cinema 3D 1080p 120 Hz LED-LCD HDTV with Smart TV and Six Pairs of 3D Glasses: Electronics
Old 28-02-2012, 10:59 PM   #81
Thanks: Gave 0, Got 55
I plan to wall mount my 55LM7600, and have bought a Peerless SUF651 mount that will keep it 5mm from the wall. This mount works fine with the 55LW6500, however I just noticed the backing of the LM series have an extra horizontal housing extending out from the table mount attachment area. You can see this here, here, and here. Are these horizontal spacers/brackets removable to give the tv a flat profile as it's official 1.3" depth suggests? Or are they housing components, and if so how could you give the tv spec a 1.3" depth dimension?
the lw540 had the same sticking out bit on the back and i'm pretty sure it is the speakers so wouldnt be able to be removed... i was looking at trying the 540u after my 550 was written off but the bottom bit put me off as like you i have my led screen mounted with one of the wire mounts and it just didnt seem like that would allow the screen to sit flush to the wall and would of needed spacers which defeats the object of that type of mount!
Old 01-03-2012, 9:46 AM   #82
Is there a particular time today that the specs go live on your website?
Old 01-03-2012, 9:51 AM   #83
The Italian LG Site has the new Models, but not the LM760 ??
Tv LED 3D, Tv Cinema 3D, Smart Tv, Nano Full LED, TV Plasma e TV LCD, 3D di nuova generazione | LG Tv Audio Video
Old 01-03-2012, 6:46 PM   #84
UK site now updated to show the new range and specs.
Member 300569 (01-03-2012)
Old 01-03-2012, 7:14 PM   #85
Thanks: Gave 33, Got 19
42LM860V' dimensions ?
Old 01-03-2012, 7:26 PM   #86
Not sure why they are missing, i'll give the boys in Digital div. a nudge tomorrow! Sorry!
Old 01-03-2012, 7:36 PM   #87
Can you nudge them to post the manuals? I can literally go to J&R right now and pick up my 6700, but I still can't see it on the usa web site...
Sorry, the US operates totally differently to us (EU) the manuals should be online very soon (they come from the service dept. not marketing)
Old 01-03-2012, 9:59 PM   #88
The 47LM6700 and 55LM6700 are in Stock at amazon.com, thats very fast ;P
Amazon.com: LG Cinema Screen 47LM6700 47-Inch Cinema 3D 1080p 120 Hz LED-LCD HDTV with Smart TV and Six Pairs of 3D Glasses: Televisions & Video
Any chance to get some Models in March in Europe ?
Old 01-03-2012, 10:12 PM   #89
41.9" x 27.6" x 10.4"
http://edinw.com/Spec_Sheets/LG_LM8600_SPEC.PDF
This is just comical...
47LM8600 41.9" x 27.6" x 10.4"
Thanks, but no 42" model in that document...
Old 02-03-2012, 2:09 AM   #90
In the wild...
Official LG 47LM6700/55LM6700 "Passive 3D" Owners Thread - 2012 - AVS Forum
J4CK DANIELS (02-03-2012), roguejackal (02-03-2012), UltraDad (02-03-2012)
