Sony EX523/EX524/EX723/EX723 Owners Thread - Bravia 2011 Edge LED Models
| Post Reply |
| | #391 |
| New Member |
Bought a 55EX723 from JL recently and happy with it so far. Having just returned a panasonic 50GT30 for green tinge, buzzing, fan noise and phosphor trails, just didn't make me smile and was I so aware of these issues while trying to watch stuff. Sure the sony isn't perfect, but no tv is, and I can live with the minor stuff on the sony. Not played with many setting yet, just disabling overscan cropping on all sources, dropping the sharpness and disabling other stuff. Streaming works really well from serviio on my desktop via homeplugs too going to look into a sleeker solution soon, nas or hp micro server.Also going to look into a speaker upgrade, q acoustics q-tv2x looks ideal (for me) but too small for a 55" TV |
| Quote |
| Advert Log in or sign up to remove |
| | #392 | |
| Senior Member | Quote:
Some 4:3 programmes do tend to have small black borders, top and bottom (which along with the correct side borders) is a little off-putting, but I've found it depends what channel (on freeview for example) you are using/recording - most 4:3 stuff on my set doesn't have the black borders top and bottom. Is this on all 4:3 stuff - have you experimented on quite a few programmes/channels? | |
| Quote |
| | #393 | |
| Limited Member | Quote:
It was only the odd program that had bars top & bottom, so not a big problem. It just had me wondering about Overscan now that there is a mix off SD & HD Freeview as my SD only Freeview Panasonic default is Overscan On, but I knew for HD Overscan should be Off. I will leave it off for their TV and they can always use Zoom if necessary. | |
| Quote |
| | #394 |
| Member |
Hello all, I have the chance to purchase a 46EX723 at a heavily discounted price via my father inlaw who works for sony and them having a staff sale soon. I had a read through this thread and many others and was just after a firm opinion of whether this will be a good purchase or would another similar size tv from another manufacturer be better as from reading through the thread many of you have had other brands and also many of you seem to have issues with these models. Cheers for any advise. Jon |
| Quote |
| | #395 | |
If it's a really good price, then yes, essentially it IS a good TV. I had 2 of them last year - but sadly they both had to be returned due to excessive clouding on each one. So, perhaps, something to think about, although clouding to some degree or another seems to be present on an awful lot of edge lit LED/LCD sets these days - and certainly not just Sony. It's not one of the brightest edge lit LED sets out there, but having said that, properly set up, the images, even SD, can look very good indeed. Beware though: This TV's major downfall, is undoubtedly the 3D element. Whilst not having played around with this myself (I have a big fat ZERO interest in 3D!!) most reviews pick up on the fact that it is VERY poor, with an awful lot of cross-talk etc... Something to think about if you are interested in the 3D element... Other than that, if you are being offered this set at a decent price (does it come with a 5yr warranty too?) then it is certainly worth considering... | |
| Quote |
| | #396 | |
| Member | Quote:
I guess i just need to have a look around and see if anything is going to compare at that price point. Cheers Jon | |
| Quote |
| | #397 | |
| Quote |
| | #398 |
| Member |
I recently bought a 40EX723 from Amazon, manufacture date 10/2011 and it has a T400HW04 v1 panel which I assume is A-MVA. I was surprised as I read online that most of the 40 inch use Samsung panels. I was considering returning it to Amazon but the panel has virtually no backlight bleed / no clouding or other problems and I'm generally quite happy with it. I guess its not worth the risk of trying to exchange it for a different one? |
| Quote |
| | #399 |
| Member |
I took delivery of my 46EX723 today and have to say i'm most impressed, there seems to be no clouding or backlight bleed at all. Picture looks great in SD and HD, and also blu-rays look stunning and that is with all standard settings, i'll have a play with some of the settings others have posted during the week. Think i've got a good one as seems to be quite hit and miss from all the reading i've done over that past couple of days! If anyone would like pics of a 'good' one let me know. Jon |
| Quote |
| | #400 |
| Member |
My portable HDD was briefly used with an EX723 to record Freeview programmes. It's now been deregistered so it can be used with a PC again. The PC recognises that hardware has been plugged into the USB port, however, the drive doesn't appear in Windows Explorer. This being so, I cannot reformat the HDD for use in the PC, as the PC doesn't 'see' the HDD. Help!!! |
| Quote |
| | #401 |
| Member | On Windows use Disk Management in Administrative Tools > Computer Management. Remove all the partitions that are on the drive and create a new one.
| Quote |
| Thanks from: | russ331 (06-03-2012) |
| | #403 | |
What settings are you using, just out of interest? | |
| Quote |
| | #405 | |
| Member | Quote:
Hope this helps, let me know if it doesn't. Edit: bugger!!!!!! Didn't see the other posts!!! I too use Easeus, good piece of software. | |
| Quote |
| | #406 |
| Senior Member |
I received my 40 inch EX723 yesterday and I'm very impressed by it. It replaced my two year old Samsung LE40B550 and the level of detail in games and online is a big improvement over the Samsung. I only use the Sony as a PC monitor and have it plugged into the HDMI connection from a mini-display port cable running from my graphics card. The reason I opted for this set is because of the review on HDTVtest where it states that the Sony has very low input lag and reproduces colours very accurately and vividly. I have to agree with that statement: it is smoother than my old TV and colours are richer and more detailed in games like Skyrim, for example. Also, the fact that I can get a lot of content through the internet menu (free LoveFilm account for 3 months; Eurosport; BBC iPlayer; and so on) is very pleasing. I can upload pictures, songs and videos from my USB flash drive which is a bonus. When I first turned the set on I got a fright as it seemed very dim, and no matter how I configured the Picture Settings it didn't brighten the screen. Then I discovered the additional screen settings via the Home menu and thankfully I was able to turn off a setting that was automatically dimming the screen. Immediately the screen became as bright as I'd hoped it would be! I also had to disable a setting that caused the set to automatically change its settings whenever I went to watch a YouTube video. Now the set retains the settings I've input regardless of the situation. I'm very pleased with the Sony KDL40EX723. Edit - The only frustration I have with the set is that black levels aren't as deep as my old Samsung. I'm sure I'll be able to improve the black levels by calibrating the colour and greyscale settings. Does anybody have any settings I can try out that'll improve on my black levels? I wish HDTVtest would post the settings they input into their set in order to get the colour balance and greyscale settings right. Actually, I just found some information about that on their Facebook page. Last edited by Stockholm; 09-03-2012 at 11:51 AM. |
| Quote |
| | #407 | |
| Quote |
| Thanks from: | Stockholm (09-03-2012) |
| | #408 |
| Senior Member |
Hi Paul, Thanks for the suggestion re. my settings. I went over them again during a session of Metro 2033, a particularly dark game, and I recalibrated them to produce deeper blacks. I turned the backlight down to 6 and the brightness to 60. I've left the contrast setting as is, Max, and I'm very happy with the levels of blacks now. I also picked the relevant settings in the advanced menu that produced deeper blacks. As it stands just now the black levels are indeed superior to the old Samsung I was using. Thanks again. |
| Quote |
| | #409 | |
| Prominent Member | Quote:
![]() Personally i would have brightness to around 50, i have my Sony 46HX823 set to 48, this is based on using the spears and munsil benchmark blu ray. Any higher and i would be over exposing dark areas of the screen ie showing detail that i shouldn't be seeing. What scene setting are you using? Aaron | |
| Quote |
| | #410 | |
| Prominent Member |
Well here is the Flatpanels hd review. Sony EX720 review - FlatpanelsHD Here are there settings. Maybe the EX needs higher brightness. Quote:
| Quote |
| | #411 |
| Senior Member |
Hi Aaron, I'm using the set as a PC monitor via a mini display port to HDMI cable. As such the set only allows for Graphic mode which causes a lot of options to become unavailable for reconfiguration. I just tried brightness at 50 and I don't really notice much difference on Windows 8, but admittedly it's most white and blue rather than black or the like. In advanced settings I've changed the RGB Gain channels to values like -2 -1 0 etc and it looks better than it did before I changed them. I'll try the values suggested in your post above. Thanks |
| Quote |
| | #412 | |
![]() Just purely as a 40inch computer monitor? ![]() | |
| Quote |
| | #413 | |
How's your set Aaron? Still all ok? | |
| Quote |
| | #414 | |
How you getting on with yours? I still really think brightness 55+ is just to high, and the test patterns i have used support this. 48 is the sweet spot, i would go 50 but then i know it isn't quite right. I have tried 55+ even 60 but it just looks plain washed out. On the pluge low and high test pattern (for setting brightness) 60 just shows all the bars and the checkered pattern that you are not supposed to be seeing even just over 50 is the same just not so severe. I appreciated it is personal preference but if you had the test pattern in front of you that i have i don't think you would disagree with me. If the image is to dark i would raise the backlight setting. Also i have contrast set to 97, 98 and the white bar on the end of the test pattern disappears into the white background (which means contrast is to high) 97 and it is visible. Sorry for my rant but i just get very passionate about it. ![]() Aaron | |
| Quote |
| | #415 | |
Thing is, if I have my brightness setting down to 48-50, the picture (well dark pictures or pictures that have dark "areas" picked out within them) just looks overall too dark, blacks look crushed and you can't pick out as much detail - as I say, this happens on scenes that maybe are generally a little darker than others....I've tried brightness at 50 and for some things it is fine, but others - well - I am just constantly feeling the image is too dark. I've had three of these now (well 2 x EX723 and my current NX723 which is exactly the same panel and processor) and they are all the same, hence why I mentioned at the start that maybe the image is generally a little duller than yours? Anyhow, glad you still loving your set! Mine is great (even with brightness on 58!!!!!! ) Started to watch some HD stuff on it (via BBC iplayer and the built in internet You Tube function) and it looks amazing. Not tried out the 3D yet, as I still have no interest what so ever! | |
| Quote |
| | #416 |
| Senior Member |
Perhaps an image rendered by an Nvidia graphics card and sent to the screen differs in terms of brightness and colour representation than it would do from a digital source such as Sky HD and the like? I tried to lower the brightness to 50 and below and it is just too dark for my liking. However, I've kept contrast at 97 as you suggested Aaron and I lowered Gamma to -1. I have film mode off (what does it do anyway?) and turned colour up slightly to 55. Sharpness is set at 60 as text looks very blurred at 0 to about 30, for instance. 60 looks nice from where I'm sitting. Above that, however, and it looks terrible. Edit - Oh yeah, I changed it from Neutral to Cool as it emphasises the whites and brightens things up a tad. Warm 2 contained too much yellow and Neutral had a similar tinge of that colour. |
| Quote |
| | #417 | |
I have to say the new 3D glasses have got my curiosity going about trying 3D i am sad to say, weather or not i pursue that is another matter. Hands-on with Sony's 2012 3D glasses | CES 2012: Home Theater and Audio - CNET Blogs Glad you are enjoying your set mate. Take care, Aaron | |
| Quote |
| | #418 | |
Everywhere i read 20 is the sweet spot with regards sharpness where higher adds artificial sharpening and lower adds softening. Guess this model could be different but it has been the same in 2 Sony reviews on here. I personally find cool to cold i am playing with color temp neutral as i fancy messing around with the settings a little. Although i know Warm2 is the most accurate setting. Aaron | |
| Quote |
| Thanks from: | Stockholm (10-03-2012) |
| | #419 |
| Senior Member |
I had the mini display port to hdmi cable connected to HDMI 3 on the back of my 40EX723 but then I read on the Sony website that there is a dedicated PC HDMI slot on the back of the set. So I changed the cable from HDMI 3 to HDMI 4, which is the slot that I believe is the dedicated PC/HDMI one. Is there any tangible advantage to using the PC/HDMI slot 4 over HDMI 3, 1 or 2? The only things I've noticed so far is that I needed to recalibrate my preferred settings again and now the TV momentarily goes black and appears to change when I visit certain sites like YouTube. I disabled this on HDMI 3 and as far as I can tell I've disabled the necessary settings again yet it still appears to want to change the settings, even though it doesn't once it establishes the picture. It's quite annoying and I'll be heading back to HDMI 3 if there is no other benefit to using PC/HDMI 4. Thanks |
| Quote |
| Post Reply |
LinkBack URL
About LinkBacks
