Panasonic Viera TV USB HDD PVR: Supported drives & PC access to recordings?
Old 19-01-2011, 5:30 PM   #61
Limited Member
Originally Posted by kgroenwald View Post
Is it possible to partition drive to use it with G20 and also have some other data on it on different partition - I know that TV is registering drive and format whole partition to ufs but is it possible to then delete this partiotion, create smaller one ufs and also on remaining drive space fat32 ot ntfs for example. If yes - which tool is good for that? gparted is not able to create ufs partition ...
Well, I tried to reduce UFS partition size, never found a tool able to make the job. I'm not sure the TV will recognize again the drive if you delete the partition and create a smaller one.
Old 22-01-2011, 12:25 PM   #62
I came across this and have been having similar problems.
I've just joined this site to throw in my two pennys' worth, but I'll probably have to start my own thread for all my problems!
Anyway, with regards to reusing a USB HDD after the TV has had its way with it this is what I did.
I put all my videos on my HDD and plugged it into the TV. The TV would not let me use the HDD without formatting it. So I formatted it and then tried to put the videos back on. No joy as my PC did not recognise it. As has been covered in this thread the HDD can only be used for recording nd playback off the telly.
Anyhow, I wanted to use the HDD with my laptop, but the laptop would not format it for use with windows. With a bit of trial and error I did fix it.
This is how I resurrected it:
Right click on My Computer
Click on Manage
Go to storage and disk management
I could see the USB drive but it had no drive letter and when I right clicked on it all the options (format, change drive letter and path, open, etc) were greyed out.
The only available option was delete... so I clicked on it.
This deleted the partition and the HDD disappeared from the list of drive letters, but was still available in the lower half of the Management interface where I could right click on it and create a new partition. I did this and windows reformatted it for me.
It all works fine in windows again now.
I should caveat this advice with the information that I am not overly tech savvy, and solved this by trial and error but it seems to work.
I hope it is ok to post a link to my thread with my problems as it is related to this one but I did not want to hijack.
Canon AVCHD (.mts) files on Panasonic TV
Old 10-02-2011, 6:41 PM   #63
Thanks: Gave 5, Got 8
Originally Posted by Ikki View Post
Even if you use the Panny tuners as a source, they will still lock out other activity while they are recording. You are far better with a separate PVR. I use the Panny TV PVR facility for HD recordings and my Topfield for SD recordings and watching if the Panny is recording. You can get good HD Freeview and Freesat recorders now from the likes of Humax and Topfield which is the way that I would go.
You can record onto the USB hard drive and then select an HDMI input to watch a DVD or BluRay at the same time.
You can schedule a recording to USB drive and then put the TV into standby. The recording will be done without you having to watch the TV at the same time.
Old 10-02-2011, 6:53 PM   #64
Originally Posted by John-W View Post
Current Panasonic Viera TVs support USB HDDs. I’ve just purchased a TX-L37V20B. However, I’m finding that some types of drive do not work. Panasonic provide no guarantee that all HDDs will work, referring to
TV | Digital AV | Consumer Products | Support | Panasonic Global for USB HDDs that have been tested. To date, only one type of drive is listed!
I use external HDD enclosures and docking stations. I tried a USB SATA dock with an integral USB hub – this would not work. The TV reported that the device is not directly connected to the TV. The Operating Instructions inform: 'Please do not connect the device via a USB HUB'. A standard IDE HDD enclosure with 80GB drive would not register. Fair enough: the Operating Instruction say drives must be between 160GB and 2TB. So I substituted a 320GB IDE drive in the enclosure. This registered successfully, but Rewind Live TV didn’t seem to work. One touch recording and timer recording did appear to record because the orange timer LED on the TV flashed and also the HDD activity light – but on trying to playback, no recording was listed in the Media Player!
Can anyone confirm types of external USB HDD that do work?
Only a USB HDD that has been ‘registered’ for use with the same TV may be accessed, ie. only video files recorded by the same TV may be played by Media Player. Using some form of protection/encryption, Panasonic has prevented interchange of USB HDDs between other Viera TVs and also PCs. (See also Panasonic Viera TV Media Player USB HDD Restriction ). Even worse, Panasonic declare that if the TV is repaired the registered USB HDD may not work with the repaired TV!
Has anyone successfully managed to access files via a PC on a USB HDD that has been registered for use by a Viera TV?
I have had no problem with an old WD passport 250Gb drive that I had spare.
It is a pity Panasonic make it so difficult to do anything useful with this disc. You can't read it on a PC or Apple or any other Panni TV. I suppose they don't want to bypass their own PVR market.
To the person trying the Vierra Link to watch films on their films on a file server. My advice is forget Vierra View as Panasonic have never delivered on their promise for this. Buy a Sony BluRay player, connect it to your network and you have access to your music, photos, films on your file server as well as iPlayer, I Love Film, Qriocity, Loads of other Internet stations. Works a treat.
Old 10-02-2011, 9:43 PM   #65
Ikki's Avatar
Thanks: Gave 38, Got 100
You have essentially made the same point that you have to get your programming from another source if the TV is doing USB HDD recording. This still leaves one TV tuner redundant during recording time.
Old 11-02-2011, 10:21 AM   #66
I suppose this is a complication Panasonic have created. The strange thing is that setting a reminder on the same page will allow you to change tuner or programme afterwards.
The same strange Panasonic rules apply to their PVR where you cannot preserve the wide-screen bit if you set high speed copy. There is no difference in the recorded file size so it seems to be an arbitrary "rule" created by Panasonic.
Old 14-02-2011, 10:10 PM   #67
freebsd
Regarding the freebsd issue, I've been playing with a harddisk and the data recorded. Although I managed to access the files I only managed to mount the system in Read-only mode (I used ubuntu btw)
I've been playing with several FreeBSD virtual machines (Vmware) to try to mount the disk in read-write mode. No success. I tried versions 8.1, 7.3, 6.4 and 6.0.
On the other hand I have found that tts stands for "timestamped transport stream", as defined in "DLNA Interoperability Guidelines v1.0" (search the pdf with google).
I suppose too that the .aid and .vid files are time guides for audio (.aid) and video (.vod) since looking at them with an hex editor reveals a continuos time sequence...
The mime-type is explained here:
http://www.iana.org/assignments/medi....dlna.mpeg-tts
and says that tts is basically an MPEG-2 stream with 4 overhead packets for networking use... however I cannot see any relationship between the USB HDD recorded data and the network :P
Regards.
Old 20-02-2011, 11:26 PM   #68
panasonic uhm any other options
hi good thread of information so thanks to all. I have just purchased my panasonic tx-p46vt20b and panasonic blu ray BTT350 hoping to have the full suite of internet connectivity and great HD TV. However I want to do the following: use iplayer (I dont want to use freesat as no dish and great signal on freeview and broadband), use native internet like google, record on the USB HDD and watch another channel (without buying external tuners or boxes), stream movies from my IMAC (running MACOSX) presumably I need to run DLNS?), have access to lovefilm etc on my new tv (vieracast seems to be very limited). Reading between the lines on this forum it seems you cannot do any of these things without more devices and I thought I bought this panasonic TV and BR to give all this functionality. If my assumption is right ? Is there an alternative to panasonic - should I be buying Sony instead ? Any views great fully received
Old 21-02-2011, 10:02 AM   #69
Thanks: Gave 43, Got 48
Hi Gavin
Welcome to AV.
I think buying any other TV with Ad-Hoc recording will be the same as the Pannies.
It is a shame you cannot use the Sat tuner independent of the Freeview tuner and I assume there is a technical reason for their train of thought on this.
I very rarely use my TV for recording but then I do have two PVR’s, Freesat HD and Freeview HD and IMO is the best way to go for recording one or even two channels while viewing live. Although of course you don’t need to buy into both systems.
TV internet I find a bit off a pain to be honest and don’t normally use this although I do have a bridge connecting my 4 pieces of equipment I have under the TV.
Chris
Old 23-02-2011, 11:39 PM   #70
Hi.
I've a 500 Gb 2,5" HD plugged to my 42G20 and disk is having problems. I did a surface test and seems the disk to have broken sectors .
I could mount it in Ubuntu (thanks this thread help) and download all my recordings to my desktop PC but now I'm not able to upload to my new disk (already formated/initialized in the TV) as I can't mount it in R/W mode; just in read only mode.
Can anybody help me to mount new disk in R/W in order to upload old recordings?
Best regards.
Old 24-02-2011, 9:00 PM   #71
Thanks: Gave 2, Got 2
Ubuntu mount command
It's not really as easy as that. I mounted the USB HDD in Ubuntu Linux and pulled the files off. Each recording is made up of a set of four files. To take the first recording (Gardeners World in HD) as an example:
0.dat 452 bytes
0_00.aid 15.3 kb
0_00.tts 865.5 MB
0_00.vid 15.3 kb
the 0_00.tts file is the actual recording and is in a format called timestamp transport stream (tts). It could be in mpeg-2 or H264. Here I have come to a halt for the moment as I have not found anything that can play or transcode this format. It's a start though.
Ikki - can you tell me please what you are doing to read this USB disk
Based on past posts, I have download and installed on a PC FreeBSD 8.1, I can see the USB connection message come up and it identifies the disk as /dev/da0 ... and I can see it has data on the 1st partition.
From what I have read on the net, I have tried all variations of the mount command (tho a total amateur using anything looking like linux), such as
mount -t ufs -o ro /dev/da0 /mnt/colin
mount -t ufs -o ro /dev/da0s1 /mnt/colin
mount -t ufs2 -o ro /dev/da0s1 /mnt/colin
mount -t extfs2 -o ro /dev/da0s1 /mnt/colin
I believe the s1 on the end of the /dev/da0 is the "slice number" and I can see a da0s1 in the /dev directory.
If I remember reightly, when I bought the TV I think I had tried thiis kind of mount command with Ubuntu as well.... al without any success....
Can you advise what version you are running... and the mount command used and anything else that may be needed please?
Thank you & regards
Colin
Old 26-02-2011, 10:57 PM   #72
Thanks: Gave 1, Got 6
I have just purchased a Verbatim 320GB Store & Go USB Hard Drive for my 32G20 and after a bit of trial and error it works!
However, I noticed that despite the manual saying I could use either the side USB or rear USB, it only actually worked on the rear USB - it fact on the rear of the TV, the rear USB socket had HDD marked against it! Hopefully, if I get the Netgear dongle, the dongle will work in the side USB!
I agree the recording is limited but I am still learning and I think I can put up with it. I do have 2 questions though
1. is it right that you have to pick either instant recording or rewind live TV - still don't fully understand rewind live tv though
2. My HDD is usb powered only, so if I put the TV into standby, as I see it, the TV will still record. If I power off the TV, presumably no recordings will take place?
Old 27-02-2011, 11:04 AM   #73
Ikki's Avatar
Thank you & regards
Colin
I am running Ubuntu 10.04LTS.
Here is how to access the UFS disk:
1. Find the location of the disk partition when it is attached to the computer. You can easily get this information from System - Administration - Disk Utility
My disk partition was attached on /dev/sdd1
2. In terminal type the following:
sudo mkdir /mnt/ufsdisk
sudo mount -t ufs -r -o ufstype=ufs2 /dev/sdd1 /mnt/ufsdisk
Replace /dev/sdd1 with wherever your disk is attached.
3. You will find the ufsdisk folder located at /mnt/ufsdisk in your filesystem. Open that and all the recorder files are there.
I hope that this helps.
Old 01-03-2011, 6:34 AM   #74
0.dat 452 bytes
0_00.aid 15.3 kb
0_00.tts 865.5 MB
0_00.vid 15.3 kb
I wonder why anybody would bother getting around this for illegal purposes as it is so lame anyway. That said, discovering the format because you can sounds like a good idea to me!
According to Wikipedia, the MPEG-2 TS should have a Sync byte of 0x47 at the beginning of each packet. If the coding is a simple byte based conversion, discard the 4 byte time stamp at the beginning of the 0_00.tts file, and find what transform makes the next byte into 0x47. If correct, this should be repeated every 192 bytes. Not the answer, but a starting point anyway. If someone can post a link to a sample file, I would be interested to have a look.
chrisburns (11-01-2012)
Old 01-03-2011, 8:20 PM   #75
Ikki's Avatar
It's not a question of getting around something illegal. Recording TV to any media for personal use at a later date is legal in the UK. This is no different to recording to VHS or DVD for later use. Many PVRs provide the ability to extract the recordings from the HDD, there is no legal reason why the Panny does not AFAIK. It is just a very useful facility to have.
Old 01-03-2011, 11:09 PM   #76
Totally agree Ikki - Sometimes it might be nice to save it on PC for later viewing, or even put it on USB pen drive/cd/dvd to pass it on toe friends etc, i.e giving you a portabillity option, which it certainly isn't at the moment... plus...
BLAIR - for the record, I have now had to wipe my disk (SAMSUNG_S2) clean now, due to
1) the TV registering a phantom 2nd disk, which did not link back to my connected Samsung disk, thereby making it useless until I deleted the entries in the menu and re-registered it _ I lost about 150gb of recording in doing so.
2) for some reson the TV was locking up when changing channels... and when I disconnect the USB disk, all worked fine - and strangely (at this same time), the record STOP button refused to stop the recoding activity after recording for more than a couple of minutes - the only way I could get the recording to stop, was to power the tv off at the wall socket, which then led to a recording suddenly being zapped to 5 minutes length.
SO, cracking the recording and getting a hard copy on your pc (or wherever), is very much worth looking into.
Ikki - Also thanks for the Ubuntu solutiom for getting at the files - I'm a total Linux/Ubuntu novice, but I/.T literate, so will try and persevere a final solution.
bbuchy - thanks for your comments on the disk you use, your USB of choice made me sit up and think that was a damm good point, but I only have the 2 side USB slots on my P42G20B, so I don't have any option but to use them - I did eventually find the supported drives for my model, which constitutes all of one make/model, which is
Maker
Model Number
Buffalo
JustStore Desktop HD-EU2-UK Series
Thanks & Regards for your updates...
Old 05-03-2011, 9:56 PM   #77
Hi, Blair:
I had the same idea you had, since I saw the .tts files have a size which is a multiple on 192 bytes. I even made a short C program to remove these 4 bytes in each 192-byte block/packet..... but no luck. The result is not a clear MPEG-2 scream. I recorded a few seconds with a DVB-stick in my PC and all packets (188-byte MPE-2 packets) start with the 0x47 mark.
The problem now with the files is - I suppose - to guess how to obtain an MPEG-2 stream from the set of three files (.aid, .vid, .tts)
As to link a file so you can check it, I don't know how could I do it.
Old 02-04-2011, 4:05 PM   #78
Originally Posted by pasko View Post
Hi, Blair:
I love that there is someone working on this. I managed to get the files off my hard drive using Ubuntu, but have had problems reading the files under Windows and Ubuntu.
Has there been any progress? Or has anyone found any software that encode this or transcode to MPEG (evaluation versions or free)?
If needed I'm happy to upload a 100mb file or so onto my website if anyone wants a sample.
Thanks very much
Andy
Old 03-04-2011, 1:05 AM   #79
Thanks: Gave 0, Got 2
Panasonic TX-42D25L
Rather than buying a USB HDD that might end up as an expensive door stopper, I followed Panasonic's recommendation & opted for the suggested Buffalo 2TB HDD. Works a dream, the unit will record all DVB-T & DVB-S programming including Ch 4hd. Besides "one touch recording" or timed entries it also allows "time shift" or pause live TV in glorious high definition. There are issues though:
  • As the TV manual says broadcasts recorded on the USB HDD can only be payed back on the unit from which they were recorded & nothing else
  • To use the USB HDD on any other device the unit must first be reformatted, loosing any saved programs
  • There is then no option to save or transfer any recordings to disc as formatting must be carried out first, thereby loosing saved data before a transfer can be made
My third point is a real bummer, as I have some saved transmissions from BBC HD such as "Wonders of the Universe" in HD, these would be a shame to loose.
Any suggestions on how this can be overcome would be very welcome.
Old 03-04-2011, 2:52 PM   #80
Originally Posted by Gooner View Post
Panasonic TX-42D25L
Any suggestions on this can be overcome would be very welcome.
I use a cheap 320Gb 2.5in SATA HDD in a cheap enclosure. Total cost about 35GBP. The statement that recordings can only be played back on the unit they were originally recorded is indicative of an encryption key hardwired into the TV. It is going to take someone way, way further up the skills ladder than me to crack this one. With the price of Freeview PVRs being pretty cheap, I have gone this route for anything I want to keep or transfer to my laptop.
I is a pity, however, that Panasonic have been so unnecessarily restrictive. With the Freesat and Freeview HD tuners in my TX-P42G20B, they could have also allowed us to record and watch different programs. Maybe the next generation ...
Other than the above, I am pleased with my TV.
Something I have been meaning to experiment with is recording via the HDMI output. Many laptops/PC have this interface so may be a possibility to record HD media for future use. Has anyone tried this?
Answered my own question - no this won't work as the HDMI spec prevents copying. Would have to use the Scart output which probably means no HD.
Slightly off topic, many BBC programs can be downloaded using "get_iplayer" including HD media. The advantage being you can play them back after the normal 30 days have elapsed. In fact anything playable in the BBC's iPlayer can be downloaded this way though how long this useful option will last I just don't know.
Simon
TX-P42G20B
Old 12-04-2011, 11:27 AM   #81
Thanks: Gave 0, Got 3
Partitioning Drive for Panasonic TV & PC Use
I have a 400gb Freecom Hard Drive, which I Partitioned into two, both of equal size.
The idea was to use one Partition with my Panasonic G20 TV for recording, freezing Life TV, and the other Partition for PC usage and for viewing JPGs, MP3s, Video Files.
When I conect the drive (partitioned) to the TV, and register it, it formats it back into a single partition (which cannot be use on a PC).
Is there a way to retain the second partition for PC usage ?
Old 12-04-2011, 1:16 PM   #82
Short answer is I don't know though someone else might. However from other posts, it seems that the TV formats as a Linux partition. It could be worth using a Linux box to split the partition then reformat one part as a Windows partition, FAT32 or NTFS. You never know, it might work.
However I am not too sure why you would want to do this. External 2.5 in HD and enclosures are extremely cheap, you can get a 250Gb external HD for about £30 see Ebay or Ebuyer. Bigger drives are not much more expensive. Will save you having to unplug the TV hdd assuming the formatting works.
Simon
Old 12-04-2011, 6:47 PM   #83
As the previous poster said, this is pretty pointless. But there are loads of pieces of partition software in Windows you can use like Partition Magic or use gparted in linux. You can download a bootable Ubuntu CD that will have it on there and choose to resize the larger partition on the drive (it makes a few). I would do this before filling it with recordings etc just in case there are any issues.
Old 27-04-2011, 7:31 PM   #84
Well, mine is even more strange....
P42G20B
Had it just over four months, lots of niggling problems (intermittent type things, nothing I can actually point at the Plasma itself or the cables or the Bluray, so inconclusive)...
Anyway,
Western Digital 2TB USB HDD - formats fine under Panasonic and registers fine.
Using the bottom of the remote (slide switch set to TV) it records anything that is currently running perfectly, SD, HD, Freeview, FreeSat, whatever. Orange LED flashes whilst recording and once recorded it all comes up on "Media player" and plays perfectly.
But use the top right "direct TV rec" button and I get the error message "starting up" then "invalid operation". Nothing then, no change of LED from green. (setup menu is set corectly for "live TV" or whatever they call it).
Now use the programme guide and set to record for a future programme, all seems well, LED changes to orange at the appropriate time, if I try to watch anything else it prevents me as tuner is in use, but when it's finished recording, Media player says the HDD is empty.....
So why was the orange LED flashing all that time ???
I don't think there is anything wrong with the USB/HDD but there seems to be something very wrong with Panasonic's firmware (or possibly hardware in my case).
4 months old and it was bought from Amazon.... the ultimate nightmare for getting it replaced....
Thoughts ???
Old 27-04-2011, 7:46 PM   #85
Kinda tried to hijack the thread here with a separate issue mate! I think you're more likely to get a useful response by starting a new one with an appropriate title.
Old 27-04-2011, 8:05 PM   #86
You could be right but it all seems to come back to the way Panasonic interface with the USB HDDs and this was the most appropriate thread I found where other people have had problems with this interface
There are a fair few posts in here about some HDDs working and some not, but not the way my one works in one mode but not in the other.....
I'll wait a day and see, and if there are no helpful responses I'll start a new thread.
Old 28-04-2011, 1:12 AM   #87
Curly99's Avatar
Thanks: Gave 772, Got 1,887
While I agree with the above, to be fair to the OP a new thread should have been started, thanks for pointing this out SANGERA2 but can you leave moding decisions to the Mods please.
Curly
Old 10-08-2011, 1:52 AM   #88
Limited Member
Thanks: Gave 4, Got 0
WD My Book Essential 3.0 2 TB External Hard Drive
GOT THE DRIVE TODAY MY TV DOES NOT HAVE USB SLOT SO PLAYED THROUGH MY PANA DMP-BD45 BLU-RAY PLAYER.
GOT MESSAGE SAYING NOT COMPATIBLE.
IS THERE ANYTHING THAT CAN BE DONE OR ARE THERE OTHER COMPATIBLE DRIVES.
I HAVE A 8GB STICK WHICH PLAYS THROUGH MY BLU-RAY USB.
Old 10-08-2011, 3:49 AM   #89
Curly99's Avatar
don't post in capitals it is classed as shouting and bad nettiquette
Curly
Old 10-08-2011, 6:56 PM   #90
Limited Member
i did not mean to shout.
got drive today. my tv tx-p42s20b does not have a usb port so played through my pana dmp-bd45 b-ray player. my tv is .
got message saying not compatible. then pressed function menu on b-ray remote got message saying unformatted, how do you format it. on this forum i have heard if you format drive it may not work with pc.
is there another portable drive that is compatible and will play through my blu-ray palyer?
