Originally Posted by Vexxmania There's an Audio In (RGB/DVI) plug at the back of the TV, this is where you can hook your PC's sound card to the TV - if you're hooking the TV up through VGA or through HDMI 2. As for the picture (I'm assuming your PC doesn't have an HDMI-out port), you'd have to use a DVI to HDMI adapter to be able to connect the TV to the PC through an HDMI cable. Note that when you connect an HDMI cable through HDMI 1, the TV cuts the sound to the Audio In plug, because the TV assumes the sound will be coming in through HDMI cable. You'd have to use HDMI 2 in order to avoid this. Once everything is set, change the aspect ratio on your TV to Just Scan mode and you're good to go.
As for your Turtle Beach, there's a headphone plug directly below HDMI 2 on the side of the TV  |
The headphone jack is for a standard headphone plug. The Turtle Beach X31's RF receiver uses RCA plugs, not a headphone jack.
My pc does not have an audio out besides the RCA jack in the back . Not that I am aware of anyways.
It has a CRT,S video, and a DVI plug attached directly to the gpu, but as far as I know, the sound card does not have any kind of external port.
I could be wrong. I don't know very much about computers.
Thanks for the reply though .
I am probably just going to go out and get an a/v receiver in a little bit and route my XBOX and pc sound through that.
I want to get a pair of TB X41's which come with an optical digital input , but I don't know if this tv will allow me to get sound from all the input devices on just that one output.
I somehow doubt it since they split all the input ports into their own separate signals.
I really should have spent a couple hundred more dollars and bought a better tv .
