Originally Posted by bbandzz HI, all
I just activated my 42lh30 to play movie, but I could not get the subtitle to work. Also, my tv can not recognize mkv file. All mkv files are missing from the file list. Only ts and avi files are showed up. Can anybody help me with that?
TIA! |
Is there anyone knows how to active/enable the USB port of
LG 42LH30 which is originally for service only to play JPEG/MP3 files? Thanks!
BTW, the following way doesn't work at all.
1. Press the enter(OK) both on the remote and the TV at the same time...hold for about 5 seconds
2. Password - 0000
3. Go to tool option 3
4. Change Jpeg to 1
5. Change Divx to SD or HD
6. Exit and try it out.
You will notice that now there are 8 inputs in the option list instead of 6 - Including a USB input.
