Samsung LED tv: Firmware change 6000 in 7000 possible?
Old 17-09-2009, 6:25 PM   #1
4,165, Level: 15
Points: 4,165, Level: 15 Points: 4,165, Level: 15 Points: 4,165, Level: 15
Hey all,
Just received my Samsung ue32b6000 and already looking for ways to brick it
As I understand 6000 series can play movies from usb if one enables that in the service menu.
Also, newer firmwares (as in my tv) have that option unchangeable...
So I tried a bit: if you go into service menu -> option -> model and change it to UB7000 instead of UB6000....the WISELINK MOVIE option in the other menu will be 'ON' (and so will several other features that 6000 does not have and 7000 does).
So far I'm afraid to store this setting in order to not brick my tv...
Has anyone tried changing B6000 into B7000?
Will/did it work or not, or will it brick the tv?
Best regards,
Clouds
Old 19-09-2009, 12:31 PM   #2
1,431, Level: 8
Points: 1,431, Level: 8 Points: 1,431, Level: 8 Points: 1,431, Level: 8
Re: Samsung LED tv: Firmware change 6000 in 7000 possible?
I have Samsung ue46b6000 and already chanching the WISELINK MOVIE option into service menu, It work fine.
I didn't changing B6000 into B7000, but I now it's possible change in models B550 into B650, it work fine, try change and tell me your experience.
Sorry my English.
Best regards,
Paulo Silva
Old 21-09-2009, 12:37 PM   #3
4,165, Level: 15
Paulo, thanks for your reply.
I'll look into the effects of changing B550 into B650...
Does anyone know what might go wrong when changing UE B6000 firmware settings to model B7000?
Regards,
Clouds
Old 21-09-2009, 10:35 PM   #4
1,431, Level: 8
Clouds,
You can't change B550 in B650 in your LED TV!
I read it's possible change in samsung LCD firmware to LCD models B550 in B650.
SAMSUNG B550 - Enabling MKV & DIVX/XVID playback - part 1
Try change B6000 to B7000 because both are LED LCD, and have same specifications.
Best regards,
Paulo
Old 24-09-2009, 6:41 AM   #5
1,451, Level: 8
Points: 1,451, Level: 8 Points: 1,451, Level: 8 Points: 1,451, Level: 8
Thumbs up Re: Samsung LED tv: Firmware change 6000 in 7000 possible?
I've changed 40B6000 into 40B7000 and it's working fine (with usb video play).
But there isn't another 7 serie's functio (PIP, widget, etc...)
Now I'm asking: "If I'll put 7's firmware"?
Now I've this configuration on service menù:
Type: 40P1UF0E
Model: 40B7000
Instead of model, for Type there's many different series, did you now what change between 40P1UF0E and others?
Thanks!
Bye
Old 24-09-2009, 10:23 AM   #6
4,165, Level: 15
Hi electrobose,
Thanks for your reply and thanks for being my guinea pig
I was still afraid to make the change, but I'll try it now...
Did you just change B6000 into B7000?
Or did you also change some settings back to the B6000 values?
E.g. in menu 'control'->'sub option' is an item 'tools' that has value 11 for B6000, and 31 for B7000.
Any other changes to the tv, like slower starting or something like that?
Best regards,
Clouds
Old 24-09-2009, 10:28 AM   #7
1,451, Level: 8
Yes
No, I've no make changes in sub-menù, only model name.
No, fast as before, and no problems like reboot, flashing and similar.
Old 24-09-2009, 6:48 PM   #8
4,165, Level: 15
Ok so I changed the firmware setting from B6000 to B7000...
and now I can play movies from USB on my UE32B6000!
No problems found yet...
Very happy with that!!!
Best regards,
Clouds
Old 24-09-2009, 10:23 PM   #9
1,417, Level: 8
Points: 1,417, Level: 8 Points: 1,417, Level: 8 Points: 1,417, Level: 8
Just wanted to say thanks to electrobose and Clouds for daring to test this out for us.
I just tried to change B6000 to B7000 on my 55UAB6000 and the movie playback works fine now.
Startup time is around the same as well.
Pity there's no "stretch" option as a lot of my videos are anamorphic 1440x1080 resolution so they look squashed on the tv. I'll probably stick to my ps3 for video playback.
Old 26-09-2009, 2:50 AM   #10
6,652, Level: 19
Points: 6,652, Level: 19 Points: 6,652, Level: 19 Points: 6,652, Level: 19
Thanks: Gave 0, Got 5
hmmm makes me wonder if after doing the change to model name
in the service menu, if you could also flash with 7000 firmware.
Unfortunately its too much money to risk bricking it.
Although it would be very nice if it enabled us to use the widgets
etc in conjunction with the samsung usb wireless adapter.
Not brave enough to try this myself and i very much doubt if it would
work.
Old 28-09-2009, 7:30 PM   #11
2,492, Level: 11
Points: 2,492, Level: 11 Points: 2,492, Level: 11 Points: 2,492, Level: 11
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 5, Got 2
Originally Posted by Clouds View Post
Hey all,
Clouds
classic... respect!!!
Anyway i think you've just talked me into buying one, a shocker if the only difference is the firmware??!! Does the B6000 also support Ethernet and wireless?
Old 28-09-2009, 7:35 PM   #12
4,165, Level: 15
Well the B6000 does not have an ethernet port...
As far as I understand all circuitry is there but they just didn't solder a port on the board....might try that in 2 years when the warranty is over (if I didn't void it already).
Don't know about the wireless though.....
Regards,
Clouds
Old 28-09-2009, 8:37 PM   #13
2,492, Level: 11
Activity: 0.7%
Have you connected yours to a pc at all, interested to see how it behaves as a monitor.
Old 29-09-2009, 3:04 PM   #14
1,398, Level: 8
Points: 1,398, Level: 8 Points: 1,398, Level: 8 Points: 1,398, Level: 8
first of all, sorry for my English because I´m Spanish and I don´t know a lot.
I have just bought a Samsung LED UE32B6000 and I´m very interested on upgrading the firmware from B6000 to B7000 but I don´t know from where do I have to donwload it. Where did you found the firmware B7000??
thanks a lot!
Old 29-09-2009, 8:20 PM   #15
1,400, Level: 8
Points: 1,400, Level: 8 Points: 1,400, Level: 8 Points: 1,400, Level: 8
Regards,
Clouds
it does have Ethernet port. source: I OWN 40b6000
Old 29-09-2009, 8:29 PM   #16
1,400, Level: 8
oh and about the wireless yes it does support wireless but it is not built in like the high end led models
you would need to buy the wifi dongle. samsung sells them.. ummm idk if you could use just any dongles beside the samsung
also can some one help me get into service menu. i tried what is said about turning off tv then pressing info menu mute then power on. but it hasnt worked for me can someone tell me what im doing wrong.
Old 13-10-2009, 5:17 PM   #17
1,451, Level: 8
Question Re: Samsung LED tv: Firmware change 6000 in 7000 possible?
News?
Anyone tried to install 7's FW into b6000 renamed in b7000?
Thanks!
Bye bye
Old 15-10-2009, 5:53 PM   #18
4,658, Level: 16
Points: 4,658, Level: 16 Points: 4,658, Level: 16 Points: 4,658, Level: 16
I done a factory reset before upgrading FW 2000 to 2007, then changed model to B7000 - video function is still working
Anyone tried changing model to b8000 - any benefits?
Old 10-11-2009, 6:50 AM   #19
keribre
Posts: n/a
I managed to put the firmware on the B7000 (T-CHU7DEUC-2009.0) in the B6000, download it from here
HTML Code:
http://www.samsung.com/es/support/download/supportDown.do?group=&type=televisores&subtype=televisoresled&model_nm=UE46B7020WW&disp_nm=UE46B7020W&language=&cate_type=all&dType=D&mType=FM&vType=&prd_ia_cd=02010300&model_cd=&menu=download
I had changed the model by 7000 and the type by 46A2UFOE, sorry for my english, i use a translator.
Old 10-11-2009, 8:10 AM   #20
3,287, Level: 13
Points: 3,287, Level: 13 Points: 3,287, Level: 13 Points: 3,287, Level: 13
Thanks: Gave 1, Got 0
Originally Posted by UE32B6000 View Post
thanks a lot!
Check out Jonboys post and look at the attachment
Old 10-11-2009, 2:44 PM   #21
1,451, Level: 8
HTML Code:
So did you put 7's FW on B6000?
It's working correctly?
What's change (widget, content library)?
If it works we have to install a memory module and mount ethernet-rj45 jack.
Thanks!
Bye
Old 10-11-2009, 10:53 PM   #22
Bou Bou is offline
1,315, Level: 8
Points: 1,315, Level: 8 Points: 1,315, Level: 8 Points: 1,315, Level: 8
Following this thread, I entered the service menu of my Samsung ue32b6000 in order to activate usb media playing. Sadly, I mistakenly changed the "type" option and now I get a different volume OSD indicator. I also suspect the image looks different than it used to, although that could be just my perception.
Having changed it by mistake, I didn't get to notice what the default setting was. Could you guys tell me what the default "type" option is, so I can change back to it?
Thanks a lot in advance.
Old 10-11-2009, 11:59 PM   #23
Bou Bou is offline
1,315, Level: 8
I have also noticed that if I push the "info" button, the "led TV ←→ conventional TV" indicator no longer shows any kind of power saving.
Old 17-11-2009, 3:52 PM   #24
nkh nkh is offline
1,325, Level: 8
Points: 1,325, Level: 8 Points: 1,325, Level: 8 Points: 1,325, Level: 8
HTML Code:
I have a UE32B6050 (Type: 32P1UF0E, Model: UB6000) I tried changing the model to UB7000 which gives me video playback from USB, I then tried changing the type to 40A2UF0E which had no effect and it wouldn't let med install the B7000 firmware.
The reason I'd like to run the UB7000 firmware is that I'd like to access the network functions (with the USB WiFi dongle).
Anyways, now I'm back to a 32P1UF0E/UB7000 setup but interestingly I now have a different volume display, it's a vertical bar rather than the original circle and all the menus have a light blue highlight instead of the normal red
Old 17-11-2009, 4:07 PM   #25
nkh nkh is offline
1,325, Level: 8
Okay, I put the TV back in UB6000 mode, went back to the "alternative software" version (aka. the default firmware), upgraded to the latest firmware again (normal B6000 version), and then set it to UB7000 mode again...
Now all the menus are their original black and red and the volume OSD is normal and round again.
Still looking for a way to open up the networking functions though There is the network settings in the menu, but it won't let me set anything. In the "Media Play" section it says "(USB & DLNA)", so it looks like the TV thinks it should have networking capabilities.. Plugging in the WiFi dongle doesn't change anything though.
Old 17-11-2009, 5:05 PM   #26
1,451, Level: 8
Maybe you have to change the network type in service menu --> subcontrol (select wireless).
Old 17-11-2009, 5:40 PM   #27
nkh nkh is offline
1,325, Level: 8
Hmm, interesting, it was already set to wireless (I assume this is the place you referred to? I couldn't find any other obvious network options):
But in [Menu] -> "Setup" -> "Network", the Network Type is greyed out and can't be changed and I can't access the "Network Setup" option (nothing happens when I try to choose it):
Old 18-11-2009, 8:55 PM   #28
1,315, Level: 8
So do I, and mine does not. At least not the physical connector. How many usb ports do you have?
Dag B
Old 18-11-2009, 9:10 PM   #29
1,315, Level: 8
In your pictures, the service menu states 'wireless', while the GUI says 'cabled'....?
Old 18-11-2009, 9:16 PM   #30
nkh nkh is offline
1,325, Level: 8
Yes, I don't get it either...
