Go Back   AVForums.com > Video Electronics > Televisions > LCD and LED LCD Televisions
Today's price checkPowered by
Panasonic Viera TX-L32X10
Samsung LE-32B450C4
Sony Bravia KDL-40W5500
Sony Bravia KDL-37W5500E
Samsung LE-32B450C4
LG 32LH2000
Samsung UE-40B7020
Panasonic Viera TX-L37G10E
Panasonic Viera TX-L32S10
LG 22LH2000
Panasonic TXL19X10
 More...Prices updated February 9th at 7:30pm and include delivery.
Thread Thread Starter Forum Replies Last Post
Philips 42PFL9703D / 9603 or Samsung LE40A856 or Sony 40W4500 / X3500 catcher Which TV Should I Buy? 15 27-01-2009 1:07 AM
Samsung LE40A856 and movie playing ability christhedon LCD and LED LCD Televisions 3 02-12-2008 10:57 PM
Samsung LE40A856 and sound output christhedon LCD and LED LCD Televisions 0 02-12-2008 10:14 PM
Toshiba Regza 40ZF355D or Samsung LE40A856 essexboy Which TV Should I Buy? 1 19-11-2008 10:45 PM
Toshiba Regza 40ZF355D or Samsung LE40A856 essexboy Which TV Should I Buy? 1 19-11-2008 9:08 PM
Old 10-12-2008, 10:26 AM   #1 (permalink)
Samsung le40a856 settings help
has anyone got any settings for a samsung le40a856. any help please. ive tried googling it but to no avail. please help.
shaqs77 is offline   Reply With Quote
Old 10-12-2008, 10:31 AM   #2 (permalink)
Conspicuous Member
Thanks: Gave 4, Got 1,214
Re: Samsung le40a856 settings help
Settings to what, what are you watching and from what source.
Andy98765 is offline   Reply With Quote
Old 10-12-2008, 10:34 AM   #3 (permalink)
Conspicuous Member
Just looked at at your other posts, if it is for a SKY+ box then check the picture settings in the SKY box are set to.
16:9 not 4:3 and RGB not PAL, use a quality Scart cable from the box to the TV and make sure it is plugged into a RGB Scart enabled socket as all sockets may not be RGB capable.
Old 10-12-2008, 11:02 AM   #4 (permalink)
the setting is available at hdtv test.
Samsung LE40A786 Review
You can use any series 7 setting, its great.
Garyghanniy is offline   Reply With Quote
Old 10-12-2008, 11:20 AM   #5 (permalink)
sjw
Thanks: Gave 22, Got 27
First you tell people to mount their TV to a bracket using the base screws and then say to use any 7 series settings for the 8 series... The 78X series is a totally different beast to the 75X series and has LED lighting which I would imagine would greatly change any calibrated settings between them.
sjw is offline   Reply With Quote
Old 10-12-2008, 12:12 PM   #6 (permalink)
my current setup is the le40a856. i got my 360 elite connected to it using composites (my qed reference hdmi cable is on order and on its way), and a standard def cable box connected using a medium quality scart which i intend to change to a qed scart. as soon as i can afford it i will be buyinga ps3, a dedicated blu-ray player and a home theatre system.
Old 10-12-2008, 4:47 PM   #7 (permalink)
Conspicuous Member
I think you can do all the adjustments you like but until you sort your cables out you may struggle to put everything back as it was.
As for the Cable box, can you select RGB and 16:9 at least?
Anything by composite will be shocking?
Old 23-01-2009, 6:25 PM   #8 (permalink)
my qed reference hdmi cable is fitted and a qed scart cable. ive calibrated it using a monster isf dvd but i reckon i can get it better. any suggestions????
Old 17-02-2009, 1:36 AM   #9 (permalink)
B8z
Yeh Im on it Shaqs, Hopefully I'm gona try get two different settings, one for lights on n one for lights off! But yeh your right, you can calibrate your tv loads with those dvds but depending on whether your using your xbox or blu ray you'll need to tweak it here and there! Bit annoyed though to find out the LE40A856 has about a 30-50ms input lag, ifya wana try it for yourself try guitar hero on the xbox and go to the video settings and calibrate the lag. Lowest result I had was 31ms and the Highest was 52ms. Not impressed!!
B8z is offline   Reply With Quote
samsung, settings
Copyright © 2000-2010 M2N E. & O. E.
