Go Back   AVForums.com > Video Electronics > Televisions > LCD and LED LCD Televisions
Today's price checkPowered by
Panasonic Viera TX-L32X10
Samsung LE-32B450C4
Sony Bravia KDL-40W5500
Sony Bravia KDL-37W5500E
Samsung LE-32B450C4
Panasonic TXL19X10
LG 32LH2000
Panasonic Viera TX-L37G10E
Panasonic Viera TX-L32S10
Samsung UE-40B7020
LG 22LH2000
 More...Prices updated February 9th at 5:30pm and include delivery.
Thread Thread Starter Forum Replies Last Post
Pioneer 436XDE image retention. aandpwoodley Plasma Televisions 2 30-06-2007 7:40 PM
'Backlight bleed' thread...post problems/cures here leamspaceman LCD and LED LCD Televisions 2 07-05-2007 11:07 AM
Pioneer 506XDE image retention marklintonarnol Plasma Televisions 10 09-07-2006 4:57 PM
Pioneer 506 & 436XDE Image retention/burn IDkipper Plasma Televisions 5 05-01-2006 7:39 AM
Pioneer 436XDE & image retention blossom Plasma Televisions 14 25-10-2005 2:16 PM
Old 30-10-2008, 9:39 PM   #1 (permalink)
Thanks: Gave 1, Got 15
Problems with the Pioneer krl37v - Backlight bleed and image retention
Today I had a Pioneer krl37v delivered. I have been checking it out some more this evening and have the following problems to report. Firstly while there didn’t seem to be significant bleed on black scenes such as the one below….
....there does seem to be significant bleed when viewing something with a grey background. The example below is displaying the screen saver form my blu ray player. This should be a flat grey with the blu ray logo. As you can see the screen is much brighter everywhere other than the middle.
Refer to images dsc 36 or 43
This is even noticeable with the lights on as can be seen below.
Refer to dsc 45
Additionally there is a strange image retention problem that I have never seen before. When scrolling around the PS3 like menus of the blu ray player there is retention of previous images as can be seen below:
Refer to dsc 0053
If I switch away to another input and back then the image retention disappears as shown below. (So I do not think that this is banding.) See the vertical lighter stripes on the right hand side and the horizontal lighter bar around the "video settings" logo.
Refer to dsc 0055
To confirm that these were problems with the TV and not with the player I connected the bluray to my Sharp 26p50 and did not see either of the above issues
Overall this is one hell of a disappointment. I had seen a demo of the set but did not notice any of these problems. Tomorrow I will be calling Empire Direct to see what they can do. However, I am not sure whether I want to take a chance with another Pioneer or to switch to a completely different model. Perhaps I should just get my money back and try something else.
Problems with the Pioneer krl37v - Backlight bleed and image retention-dsc_0047.jpg   Problems with the Pioneer krl37v - Backlight bleed and image retention-dsc_0036.jpg   Problems with the Pioneer krl37v - Backlight bleed and image retention-dsc_0043.jpg   Problems with the Pioneer krl37v - Backlight bleed and image retention-dsc_0045.jpg   Problems with the Pioneer krl37v - Backlight bleed and image retention-dsc_0053.jpg
Problems with the Pioneer krl37v - Backlight bleed and image retention-dsc_0055.jpg
garydhooper is offline   Reply With Quote
hazzilee (11-12-2008)
Old 30-10-2008, 11:04 PM   #2 (permalink)
Thanks: Gave 12, Got 6
Re: Problems with the Pioneer krl37v - Backlight bleed and image retention
Bloody hell, that's pretty bad bleed. My instinct says that's a fault, because I've never seen such bad bleed on a Sharp TV, and these screens are very similar.
IanPM is offline   Reply With Quote
Old 31-10-2008, 8:11 AM   #3 (permalink)
I had left the brightness level on the same setting as it was on the set when it arrived as this seemed fine with normal TV. However, if I turn the brightness down from +10 to about -5 then both the backlight bleed and the image retention dissapear.
This brightness level (-5) does seem to be closer to reality as I think that the background on the screen saver should only be a few notches above black rather than the light grey that I was seeing. (The black level on my 4 yr old LCD that I was comparing it too is so bad that it can only do darkish grey so it is difficult to know.)
Perhaps that is why there was no bleed on pure black screens???
Much happier (or relieved) now but I am still concerned that I have to have the brightness so low - is my set faulty???
Old 31-10-2008, 8:42 AM   #4 (permalink)
audiphile76's Avatar
Thanks: Gave 34, Got 300
The general rule(irrespective of what technology the panel has) is to immediately change the settings away from default settings. Usually most of the complaints and painpoints from fresh owners is owing to this. Its best to change the settings and then check for flaws. As in this case, well done and enjoy your set
Panasonic 42PX80 | Sony 40V2000 | Sony PS3 80GB | Samsung Omnia 16 GB | Procaster 500GB | Iomega 500GB | iPOD 8 GB | Killzone 2
audiphile76 is offline   Reply With Quote
Old 31-10-2008, 4:25 PM   #5 (permalink)
I currently have the brightness turned down to -5 to eliminate backlight issues on dark grey screens. Initially the brightness was set at about +15 and this showed a dark grey screen as a lighter grey but with severe backlight bleed on the sides of the screen and image retention. Strangely there was no bleed on a black screen with this setting so I am not sure if this is a bleed issue or something else.
I have contacted Pioneer to ask them to have a look at the screen shots here.
Personally, I think that I will have to send the set back as I like to have the brightness around +10 to +15 for TV viewing and someone elses settings on the general Pioneer krl thread confirmed that I am not alone on this.
What brightness settings do other krl owners have?
Old 03-11-2008, 7:56 AM   #6 (permalink)
My settings are as follows:
Picture: AV Standard
RLS: Off
Backlight: +1
Contrast: +29
Brightness: +6
Colour: 0
Tint: +1
Sharpness: +5
Pro Adjust:
Colour Temp: Mid-Low
100HZ: on
Pure Cinema: Standard
Activecontrast: off
Option:
DNR:low
Old 03-11-2008, 8:38 PM   #7 (permalink)
Had a reply email from Pioneer after they had a look at the pictures here on this thread. According to Pioneer the brighter light at the sides of the screen is normal for this model and simply due to the underlying backlight technology used in LCDs.
I went and had a look at another Pioneer krl37v in a shop and when displaying a dark grey background that set was exactly the same as mine.
I do not want to overstate the severity of this problem. I have only noticed it on dark grey backgrounds. Black and light grey is not a problem. The screen saver probably makes it look worse as it fades in and out.
Generally the PQ on normal (SD) TV from my Sky box and DVD is very good. Only ocassionally do I notice anything where I think that the sides of the TV look brighter than the rest of the screen.
Old 03-11-2008, 8:44 PM   #8 (permalink)
sjw
Thanks: Gave 22, Got 27
If those pics were from a Sony etc. they would be slated for it...
sjw is offline   Reply With Quote
Old 03-11-2008, 8:48 PM   #9 (permalink)
Thanks: Gave 155, Got 114
Backlight bleed to that extent is normal according to Pioneer? Wow, that's pretty bad - I noticed they stated "normal for that model" & not for LCD's in general - I would be annoyed as hell paying such huge a premium for a set that acted like this!
Suave!
Suave is offline   Reply With Quote
Old 04-11-2008, 9:30 AM   #10 (permalink)
But is this problem backlight bleed or something else?
I see no bleed on black backgrounds e.g. if watching a widescreen movie the black bars above and below the picture are pure black all the way up to the sides.
It is only on dark grey that the screen isn't uniformly bright. (e.g. on an Avia test disk it has grey screens going from 10 URE (or ORE cannot remember, whatever ORE/URE is??) which is almost black up to 100 URE (white or nearly white) in steps of 10 URE. Now that I have turned the brightness down from about +15 to +6 the problem is only really obvious on the 20 URE screen or on the Blu-Ray screen saver.
I tried the Avia test disk on a Pioneer krl37v at a shop and that seemed similar to my one at home (possibly a bit better but difficult to tell.) The player I tried it on was linked to a lot of LCDs and none of the others had such uniformity issues. Although it did show how bad some of the LCDs are at showing black.
Anyone out there with a Pioneer krl37v and a Sony bluray player that can test what the screen saver looks like on their set?
Old 25-11-2008, 10:55 AM   #11 (permalink)
I ended up returning this set so now I am looking for something else to replace it. (Possibly the Panasonic 37px80.)
Interestingly, given that this set uses a Sharp panel, the uneven backlighting on this set looks very similar to that seen on HDTVTest review for the Sharp LC42b20 here:
Sharp LC42B20E 42" Aquos Full HD 1080p LCD TV Review
Old 01-12-2008, 10:32 AM   #12 (permalink)
That Panasonic is a great TV, and it's a bargain. I really like their plasmas, even the cheap ones.
Old 01-12-2008, 3:10 PM   #13 (permalink)
I have ordered the Panasonic 37px80 for £577 inc 5yr guarantee. That means that it costs less than half as much as I paid for the Pioneer.
At that price I can view the panny as a temporary solution i.e. sell it on after a year or two if there is something better around.
Old 28-01-2009, 3:15 PM   #14 (permalink)
I purchased the KRL37v on saturday, and have the same issue with the uneven backlight
In fact it was the first thing I noticed once I'd switched it on.
Gutted, considering the amount of money it costs. (£899)Apart from the backlight issue, I can't fault the picture quality.....its stunning!
From an SD sourcse (Standard sky+) i'd give 8/10
From my BlueRay player, i'd give 10/10 !
Even the audio is pretty decent!
I bought it from Richer Sounds in the city, and the one in the shop was playing Ratatouille, and the blacks were miles better than every other LCD panel in the shop!
The sales guy insisted that this is the best 37" LCD in the world, and like I say, apart from the uneven backlight, I have to agree with him.
I phoned Pioneer Support today, to ask them definitively whether or not I just had a faulty TV, or if this was a known issue.....and the guy reassured me that I should NOT expect to see this uneven backlighting, and that I should return it back to Richer Sounds immediately to swap it for another one.
So that's what I'll be doing straight after work tonight.....hopefully its just a bad batch, because I really want to keep this model.....I can't fault anything else with it......it just looks and feels "high-end" and I really want to stick with it.
I'll let you all know how I get on with it
jpowell79 is offline   Reply With Quote
Old 28-01-2009, 5:36 PM   #15 (permalink)
Thanks: Gave 4, Got 5
Please do! I am keeping an eye on the KRL-37V at the moment.
Audio I Pioneer PD-S505 Precision I Rotel RA-971MkII I Quad 12L2 I BK Gemini II I
Visual I Pioneer Kuro KRL-37V I XBOX 360 HDMI I Toshiba SD-370 HDMI I
PC I abit IP35 I Intel E7300 @ 3600 Mhz I 4Gb OCZ Reaper X I ATI 3870 I Dell SP2208WFP I Cambridge Soundworks CSW 350 I
holiver is offline   Reply With Quote
backlight, bleed, image, krl37v, pioneer, problems, retention
Copyright © 2000-2010 M2N E. & O. E.
