Go Back   AVForums.com > Video Electronics > Televisions > LCD and LED LCD Televisions
Today's price checkPowered by
Panasonic Viera TX-L32X10
Samsung LE-32B450C4
Sony Bravia KDL-40W5500
Sony Bravia KDL-37W5500E
Samsung LE-32B450C4
LG 32LH2000
Samsung UE-40B7020
Panasonic Viera TX-L37G10E
Panasonic Viera TX-L32S10
LG 22LH2000
Panasonic TXL19X10
 More...Prices updated February 9th at 7:30pm and include delivery.
Thread Thread Starter Forum Replies Last Post
Sony X4500 Series RGB LED Backlight,1.100.000 Contrast,BE2 PRO,,Motionflow 100Hz Pro ChrisGgr LCD and LED LCD Televisions 984 11-12-2008 12:17 PM
difference between contrast and dynamic contrast? drew_3 LCD and LED LCD Televisions 4 28-02-2008 1:22 PM
Sony KDL W3000 dynamic contrast...dealbreaker? SuperSquash LCD and LED LCD Televisions 0 05-01-2008 3:52 PM
Contrast ratio and Dynamic Contrast seanwall LCD and LED LCD Televisions 1 28-12-2007 6:55 AM
Dynamic Contrast cronemeister LCD and LED LCD Televisions 0 11-07-2007 8:26 PM
Closed Thread
Old 17-11-2008, 11:06 AM   #3031 (permalink)
skyform's Avatar
Thanks: Gave 48, Got 99
Re: Sony W4500 Series 100Hz,50.000:1 Dynamic contrast,DLNA
Originally Posted by DVB TV View Post
HDTVtest have tested the Sony KDL-40W4500 today
Review
100Hz is the only advantage over the W4000 reviewed in May. Its even worser with the Undefeatable edge enhancement on 1080i/1080p over the sharpness.
Sony
Very strange, they still prise the TV so much even if it has the sharpness problem, i always thought Vincent and David dislike this very much and after reading most of their Sony reviews it sounds a bit like they are Sony fanboys especially Vincent.
Anyway Vincent is criticizing W4500 for not having White balance, well X4500 has it even in 40" but crap i still didnt find it nowhere in my country, i don't want top buy the W4500 and especially not Z4500 which is minimal better and way more expenisve, X4500 is the one to go, better procesing and more settings but damn Sony has to ruin everything and make it so hard to get this TV.
Philips 37PFL9604H | Philips 32PFL9632D | Monitor Audio Radius R270 HD10 | Yamaha RX-V1065 | PS3 Slim 120GB
skyform is offline
Old 17-11-2008, 12:00 PM   #3032 (permalink)
ChrisGgr's Avatar
Thanks: Gave 888, Got 1,605
sony made the right tv(40X4500) its a sony slovenia problem that they didnt release 40X4500 in slovenia...cant you get it from austria or a near country?
SONY KDL-32W4000,SONY PS3 160GB,SONY KV-32FQ85,SONY KV-29FX66,SONY RDR-GX210/S
CAR:Alfa Romeo 159 1.8 140PS progression
ChrisGgr is offline
Old 17-11-2008, 12:20 PM   #3033 (permalink)
Thanks: Gave 2, Got 10
Originally Posted by ernet View Post
Hi all,
Does anybody know how to get in to Service Menu ( with details where to go inside ) to find out/ check how many hours the TV has been working so far ?
Select Analog mode.
Switch off the TV using the Remote
Press I+ > 5 > Vol+
Switch on the TV using the Remote.
I don't remember the name of the submenu, but I believe it's the one containing all the software versions and firmware versions.
cvermeylen is offline
Old 17-11-2008, 12:29 PM   #3034 (permalink)
skyform's Avatar
There is no good offer yet in Austria, the cheapest is 1640€, imo a bit too expensive and it's too far to go, the most far i would go is Graz and the price i would pay is 1500€ no more.
I have contact some Slovenina stores if they can order it for me or if they will get it and none of them has any idea if they will get it
skyform is offline
Old 17-11-2008, 12:52 PM   #3035 (permalink)
Thanks: Gave 8, Got 1
I enquired about delivery times of the 52W4500 at my local Sony Centre this weekend. They said the first shipment will be on 10-Dec and that was Sony's official date for the UK. When I pointed out that many people on these forums have already got them he used the standard line that they were not yet available in the UK so must therefore be imports.
Is this true as I am still waiting for my 52W4500 that I ordered over 4 weeks ago.
Baz8755 is offline
Old 17-11-2008, 12:58 PM   #3036 (permalink)
Thanks: Gave 15, Got 42
It's probably more about to what degree does the sharpness issue effect the overall picture quality. And the reviewer has probably deemed that even though it's there, it doesnt take away the fact that the tv still has some of the best overall pictures of any lcd out there.
jpr141 is offline
Old 17-11-2008, 1:11 PM   #3037 (permalink)
Sony centre in Farnham said they could get them week before last so that doesn't tally with what you have been told. I got one from the Internet. It had a UK plug and just the UK manual. I've had grey imports before. You normally get a euro plug and a rainforest of instruction manuals.
Think you local sony centre are telling a few porkies
Valewood is offline
Old 17-11-2008, 1:25 PM   #3038 (permalink)
Thanks: Gave 4, Got 0
Hi guys, what would you recommend cleaning the screen with?
I've just noticed sticky baby hand prints on mine
Just wondering what is best to use
spaceshipmonkey is offline
Old 17-11-2008, 2:04 PM   #3039 (permalink)
Thanks: Gave 308, Got 157
Rub gently with soft cloth.You may use a slightly moistened cloth with a little mild washing up liquid.Do not use any type of abrasive.
BrianPK is offline
Old 17-11-2008, 2:27 PM   #3040 (permalink)
Thanks: Gave 207, Got 451
Most washing up liquids contain varying amounts of salt.
Just as you shouldn't use washing up liquid on car paint, I wouldn't use it on a TV screen.
I just use an e-cloth and water.
FZR400RRSP is offline
spaceshipmonkey (17-11-2008)
Old 17-11-2008, 2:46 PM   #3041 (permalink)
Nice one!
Would the glass cleaner cloth be ok to use or is there a more suitable one?
http://www.amazon.co.uk/Caraselle-E-Cloth-Glass-Cleaner/dp/B000LFE8PW/ref=sr_1_2?ie=UTF8&s=kitchen&qid=1226932911&sr=1-2
Old 17-11-2008, 2:56 PM   #3042 (permalink)
Thanks: Gave 13, Got 20
Review
Sony
lol did you even read the review you have just posted? the only advantage is 100Hz? Heres some other improvements over the W4000 incase you missed them
  • 100 Hz - best motionflow they have seen on any LCD
  • New Guide+
  • Better black Levels
  • Better colours
  • Increased viewing angle
  • DLNA
  • Game mode
  • Reduced input lag
Sony W4710
aidan is offline
Old 17-11-2008, 3:19 PM   #3043 (permalink)
I use a microfiber glove, I put a tiny amount of water on one side of the glove. I wipe the screen with the lightly wet side, then I wipe the screen with the dry side. This doesn't leave any traces or marks.
Old 17-11-2008, 4:00 PM   #3044 (permalink)
  • New Guide+
  • Better colours
  • DLNA
  • Game mode
  • Reduced input lag
Just to be precise the colours were given a very similar write up and rating and the w4500 had the same measured blacks as the w4000. Viewing angle was also measured the same.
jpr141 is offline
Old 17-11-2008, 4:29 PM   #3045 (permalink)
Manual clearly states that you may use a diluted mild detergent solution.Is Fairy liquid not a mild detergent?
BrianPK is offline
100hz, contrast, dlna, series, sony, w4500
Copyright © 2000-2010 M2N E. & O. E.
