17-04-2007, 6:38 PM
#16 (permalink)
Thanks: Gave 853, Got 599
re: Samsung M86/M87 Discussion / Settings Thread
Thanks to Oli on the HDTVtest forum ..... here's some settings for connecting a PC via DVI:
http://forums.hdtvtest.co.uk/index.php?topic=18.0
17-04-2007, 7:55 PM
#17 (permalink)
Thanks: Gave 212, Got 392
Watching Sky Sports 1 football now and it's a great PQ using the settings I posted which I edited with reduced contrast to 70.
I think its spot on
17-04-2007, 10:43 PM
#18 (permalink)
Thanks: Gave 8, Got 30
I think its spot on
I just tried your settings and whilst watching War of Worlds on Sky Movies I noticed a lot of green breaking through especially on the smoke sections!
Have you noticed this ? And is there an adjustment we can make to stop it.
Craig
18-04-2007, 12:30 PM
#19 (permalink)
Hi All,
Here is the Calibration Settings thread from AVS Forums:
http://www.avsforum.com/avs-vb/showthread.php?t=828228
Please note: The 65 Series is the US version of the M86/M87, although the design is different in the US and has a few other different options, but in terms of Picture settings it is the same.
You can have a read through it and try the settings people have posted to see if any of them suit.
18-04-2007, 5:18 PM
#20 (permalink)
More SD Sky settings to Try:
Mode: Standard
Contrast: 70
Brightness: 44
Sharpness: 10
Cololur: 45
Colour Tone: Normal
Backlight: 4
Digital NR: Off
DNie: Off
Movie Plus: Off
Setup
Energy Saving: Medium
Everything else off here
They may be a little bit dull for some peoples taste, but it definitely helps with the pixelation problem on SD.
19-04-2007, 1:02 AM
#21 (permalink)
Ok, I think I have may unlocked the optimum settings for Sky SD via RGB Scart.
Now people may think I'm nuts, but it's something I'm sure all of us have avoided, and that is calibrating whilst in Dynamic Mode, yes you heard it correctly.... DYNAMIC
I find that it works wonders for SD material, so here you go:
Mode: Dynamic
Contrast: 65
Brightness: 57
Sharpness: 15
Colour: 50
Colour Tone: Normal
Backlight: 4
Digital NR: Off (You may need to adjust this depending on amount of noise seen when viewing certain channels)
Active Colour: On
DNie: On
Movie Plus: Off
Setup
Everything else Off here
Now if you still find things a little bright, turn off DNie and that will dim things a bit, or set Energy Saving to High.
Also, for channels with a poorer reception and greater pixelation, I would recommend setting Digital NR to High and Energy Saving to high. This helps greatly with the problem, although at the expense of a bit of colour and brightness.
You can play with the Digital NR anyway between low, medium, high and auto, depending on the amount of noise seen in the picture. It doesn't have to be set to high unless alot is seen.
For SD football, I recommend the settings as posted, but with Digital NR High and Movie Plus On.
I find the above settings to be my best yet for Sky SD.
Good Luck
19-04-2007, 9:46 AM
#22 (permalink)
Thanks: Gave 182, Got 426
Samsung LEM86/7 thread
PLEASE READ THE FAQ TO SEE IF YOUR QUESTION HAS BEEN ANSWERED ALREADY - UPDATED 15/03/08
The M86/7 is a very popular 1080p panel from Samsung, some of its key features are:
- Comes in 37, 40, 46 & 52 inch
- 1080p24Hz support (see FAQ)
- "Just Scan" for 1:1 pixel mapping on all HDMI ports
- 15,000:1 contrast ratio
- 3x HDMI 1.3 sockets
- Super Clear panel, glossy for extra black depths
- Freeview tuner
- 2x SCART (1 RGB)
- 8ms response time
Full specs here
HDTVTest review here
Manual can be downloaded here
Note: There is also a 100Hz 32" version of the M86. Obviously it is not 1080p but has pretty much the same features as the large varieties.
FAQ
Q. What's the difference between the M86 & M87?
A. Purely cosmetic, see the Samsung website for pictures.
Q. On some sites I see the set referred to as a M87BD but on others it says M87BDX, is there a difference?
A. No, it's the same set.
Q. What issues currently exist on the newest sets?
A. Wavy lines present on SCART inputs (kind of looks like rippling water) though this has reportedly been fixed with firmware 2013.
Q. How do I tell my firmware version?
A. NOTE: Going into the service mode will reset all your picture settings, make a note of them before doing this. Put TV on standby, then press info, menu, mute, power. Below the menu options are 5 lines, the last 4 digits of the first line are your firmware version.
Q. What is currently the latest firmware version?
A. In the UK, 2013 is the latest firmware version. The freeview software can also be updated, the latest version is 1013.
Q. I have old firmware, how do I update?
A. Hassle Samsung until they do it. Contrary to what they might tell you, they ARE doing firmware fixes AND PCB replacements where necessary. If they tell you they can't fix it, just hang up and re-dial until you speak to someone more helpful. You can update the FREEVIEW (not firmware) software using the manual update option in the freeview menu.
Q. I can't seem to get 1080p over VGA, why is this?
A. Some of the cheaper VGA cables have pin 9 disabled, and thus will only support a max resolution of 1600x1200. So check your cable
Q. When watching the built-in freeview, the picture will judder sometimes, why is this?
A. This is a bug in the freeview software, updating to the latest version will fix it.
Q. Does the TV support 1080p24?
A. Yes, "auto detect" modes (like on PS3) will only work on sets with newer manufacturing dates, having the firmware updated will NOT make a difference. If you are stuck with an old version, fear not as most players (PS3 included) have a force 24Hz on mode. As is my understanding, it does not run at 24Hz (120Hz actual) natively but emulates it via processing.
Q. Does the glossy surface seem reflective under normal lighting?
A. The general consensus seems to be "no".
Q. Will my Xbox 360 get 1080p via VGA?
A. Some of the earlier sets had a problem with this; if the screen comes up for a second and then clicks off you need to ring Samsung up, explain the problem and they should arrange an on-site fix.
Q. Which is better for PC usage, DVI with HDMI adaptor, or VGA?
A. DVI.
Q. What are some recommended settings for this set?
A. Click here for the settings thread, or here for the HDTest professionally calibrated settings.
Q. M86s seem pretty hard to find, where can I get one?
A. Samsung currently have an exclusivity agreement with Dixons Group for the M86, you can only purchase one from Dixons or Currys for now or just get an M87 instead.
Q. How can I tell my panel's manufacturer?
A. Model sticker: What letter comes after [R] ?
That letter tells panel manufacturer: S = Samsung, A = AU Optronics, C = Chi Mei Optoelectronics
Thanks to KeanosMagicHat, brunocosta1975, greenman_uk for contributions.
Reason: updates, amendments
3jane (09-10-2007), 681Charlie (21-05-2007), alchemistkevin (13-12-2007), allosunshine (29-08-2007), ambra (19-04-2007), Amir Mohebiّ (18-10-2007), andrewilley (19-04-2007), Anim (31-12-2007), anninan (06-11-2007), antsims (16-07-2007), Arthur Hucksake (18-01-2008), asarco (20-04-2007), atsoc15 (26-12-2007), avgo (07-06-2007), Barney. (18-03-2008), barnsley (12-10-2007), barnstormer (21-01-2008), Barzo (17-08-2007), Batman2 (16-08-2007), beaker656 (28-12-2007), beasty54 (15-02-2008), Bender (16-06-2007), BF1 (06-03-2008), bigredbucket (31-12-2007), blackburn_ (25-07-2007), Brood (11-03-2008), brunob (03-05-2007), c.jelly (01-02-2008), cantona.no7 (11-06-2007), carrera2005 (11-11-2007), CFS (30-10-2007), ChrisGgr (31-07-2007), Chrispyphillips (28-06-2007), Christofofofof (20-12-2007), cmc_ent (13-05-2008), cobue (30-05-2007), coendeurloo (20-06-2008), coke_dude (26-03-2008), Comedy Activist (14-05-2007), crackjiver (23-08-2007), crow (16-09-2007), CRROUSE0472 (28-12-2007), Cyprio (19-04-2007), Danieluwe (29-04-2007), DarkGashX (15-05-2007), dav155 (01-02-2008), Daverey2 (05-03-2008), devastator (27-06-2007), Devlin (12-09-2007), diandave (13-05-2007), digipoodle (23-08-2007), dmsims (10-02-2008), dpoulson (01-04-2008), Duncan G (10-12-2007), duncrieviedude (22-03-2008), Dwayne Dibley (13-03-2008), EDDS (27-04-2007), Edvuld (30-11-2007), Emiili (03-03-2008), eschen (30-10-2007), falkirkdaft (28-02-2008), FARJARDO (17-06-2007), fleagledog (17-10-2007), Foker (17-09-2007), Fordy (06-08-2007), foxyloxy (20-04-2007), FunkyMunkey (24-11-2007), gadgets (04-06-2007), gary-s (28-10-2007), gaspap (15-10-2007), gavsim (05-01-2008), Giblets2 (21-04-2007), glangri2 (26-06-2007), glazza (04-09-2007), Gordongpms (29-04-2007), gtv1 (28-09-2007), GunnersWharf (11-09-2007), Halifax50 (15-10-2007), Hamish2k (04-04-2008), HDlionel (08-05-2007), Hito-Shura (23-07-2007), hmsq (30-12-2007), Hockeynut (10-07-2007), holzer (20-04-2008), hoop (04-12-2007), i am giant (08-05-2007), iggy11 (22-11-2007), Incrediboy (07-06-2007), Invisible_Ben (24-10-2007), ismedsin (27-12-2007), JayEm (27-05-2007), JayValkyr1 (06-05-2007), Jeek (13-06-2007), jimihifi (19-07-2007), Jinglebens (11-11-2007), jiroczech (07-10-2007), jnmercury00 (08-05-2007), jommy999 (19-04-2007), Josku (17-09-2007), KeanosMagicHat (19-04-2007), kedge (10-07-2007), killabyte (07-09-2007), KingSkinTim (06-07-2008), Kiwi7 (17-08-2007), korayus (29-04-2007), kovacs (02-02-2008), kpfarmer1 (15-02-2008), kron (26-02-2008), labralabra (19-06-2007), lében (23-05-2007), Lee.Pie (01-04-2008), LEEROY_UK (21-12-2007), lisnalee (19-04-2007), lmc (13-07-2007), Lonefox (10-05-2007), Luciddestiny (02-03-2008), mad_allan (20-04-2007), Magic Morten (23-04-2007), magickangaroo (26-04-2007), Maharg (21-01-2008), maleas (30-08-2007), Mandy-Looo (05-04-2008), Manmc (24-04-2007), Manolis (07-06-2008), mark1000 (19-04-2007), markymark34 (02-05-2007), MartinCutts (15-08-2007), MIGHTYrog (02-12-2007), mike47 (04-10-2007), Miniholic (22-12-2007), Mirche (03-08-2007), MjWoNeR (27-01-2008), MMP (04-08-2007), Morrison (24-07-2007), Motion17 (14-06-2007), Mr Quint (20-04-2007), Mr.Nike (04-10-2007), MrLOL (23-04-2007), mwjdavies (19-04-2007), m_e_r_c (16-12-2007), NackNack (17-06-2007), ncsltd (19-08-2007), nikonkid (31-05-2007), nirmal (27-12-2007), Noorur (16-05-2007), Nor (07-12-2007), nthnmunky (17-07-2007), Nuwidol (08-08-2007), NymChimpsky (19-04-2007), operator170 (07-05-2007), Orwella (24-12-2007), otang (23-07-2007), Pabs (11-11-2007), panasonicman666 (13-01-2008), pannivas (23-10-2007), Peter Galbavy (23-07-2007), piratetigger (28-12-2007), podavies (29-08-2007), pords (27-09-2008), pretenderep (21-05-2007), psyche101 (02-04-2008), punkrjb (12-06-2008), py3m4n (01-11-2007), QBoy (03-05-2007), r2001uk (11-01-2008), r66bby (14-01-2008), rafrono (31-07-2007), rajivkotecha (07-05-2007), rbj (09-05-2007), rhem (04-09-2007), rhydal (21-10-2007), Riverpatrol (09-03-2008), robfjonesuk (19-04-2008), rondha (03-05-2007), Rork (17-08-2007), roryd (23-05-2007), rozas (06-05-2007), Ryan_is (20-02-2008), Saku (25-08-2007), Saviola (29-06-2007), Schumi 01 (28-05-2007), Schweino (11-12-2007), scorchio75 (20-01-2008), ScottC2105 (17-09-2007), Sculay (08-03-2008), set_my_path (11-07-2007), Shawn2000 (06-06-2007), sillysod123 (03-02-2008), silverpuma (31-10-2007), Simebaby (04-08-2007), sirnext (02-05-2007), slackbladder (25-10-2007), Slave.Of.Tommy (26-12-2007), snowey (22-10-2007), sohai1 (16-08-2007), spackhead (01-05-2007), Speedwolf (01-01-2008), Starks223 (26-04-2007), steve69 (28-06-2007), Steveedge (17-06-2007), Stew' (27-08-2007), stianfp (25-04-2007), stonkmeister (19-04-2007), Stormy78 (29-07-2007), suf (01-12-2007), SydneyBlue120d (10-12-2007), t1nt1n (21-05-2007), TeeDoubleUDee (25-02-2008), tef89 (23-12-2007), teggs (21-01-2008), The Bear (14-09-2007), theatre-aholic (21-12-2007), thelordmagus (29-05-2007), thepacifier (23-01-2008), thesaint111 (09-03-2008), tical (15-12-2007), Tieske (26-07-2007), Tigers (29-12-2007), toeryn (30-09-2007), tom1951 (04-02-2008), ToY_25 (09-02-2008), trinityblade (31-03-2008), truey2k (27-04-2007), vacalouca (21-04-2008), vowani (13-10-2007), vsimoes (11-05-2007), Vtec9k (22-03-2008), WebKnight (24-04-2007), Webneck Squelch (24-04-2007), whackydre (27-08-2007), Wikkus (19-12-2007), winning formula (17-02-2008), Winston Churchi (12-06-2007), Wonker (02-08-2007), Xabi17 (10-08-2007), xP I Deja Vu (21-08-2007), Yannis (19-04-2007), Yant0 (20-04-2007), zathan (19-04-2007), _Irv_ (26-08-2007) |
19-04-2007, 10:04 AM
#23 (permalink)
Re: Samsung LEM86/7 thread
The settings thread is located here:
For anyone who wants to add theirs or try any of what is posted.
19-04-2007, 10:17 AM
#24 (permalink)
Thanks: Gave 0, Got 13
Owned a M87 46inch for 1 week.
Fault you need to test for is night vision effect via HDMI @ 1080p from the PS3. The fault does exist on all sources but is very hard to detect. If you do not see the green haze you may see across the bottom of the screen a white burn. There is a handful of units in criculation that have this issue from other forums I have read.
My new replacement arrives Friday 20th so will post pictures of the faulty and non faulty units side by side to help you identify the issue if you have it.
My review:
With the exception of the fault and note that I am watching what is a defective picture. This TV is still mighty impressive. If my new set is better than what I have then I am in for yet more pleasure.
Form factor: This set is very aesthetically pleasing to the eye. It gives a sense of 21st century marvel whilst not looking like a toff. Its a must for finding the perfect partner for your newly purchased PS3. The smooth glossy black surround is almost identical to the PS3. Across the bottom the chrome strip makes you think your Playstation is actually a Samsung Playstation 3 rather than a sony. Got sky HD? your HD box has curves in its design. Its sky plus circular display in the centre fits in well with the samsung On/off button. All you need to finish this flower bed of harmony is a black glossy Yamaha dolby surround.
(Watch this space for the pics - can you guess what sound system I have?)
The LCD: Despite the fault I have to say that in simple terms Black is Black, the image is crisp, almost smooth due to fault. Even with the fault its very impressive. The menu is in my view very slugish but you will be that excited with your new LCD you wont care. There are lots of options in the menu set-up and I have to say I have no idea what is the best way to configure it? So a post with suggested settings would be greatly appreciated. The PS3 in 1080p once in a game (GT HD) is superb. You will struggle to tell the difference between reality and computer generated at times. Blue Ray @ 1080p is just stunning. I am really going to strugle to watch DVD's on my projector upstairs now having seen what movies should look like. Stand aside HD-DVD and let Blue-ray win the race this time.
My pre-replacement summary:
On the basis that I have just been unlucky and that my replacement will be better than what I have now then apart from a little inconvenience I am still at this stage happy  I spent alot of time researching the market for the correct TV and have waited months before making that purchase. The samsung represents the best value for money for what could be considered the best of the best in todays market.
"Dont think about it go buy one" Next day delivery for a before 15:00 order at Beyond television.
Watch this space for my updates and photos
ambra (19-04-2007), barnstormer (21-01-2008), diandave (13-05-2007), FARJARDO (17-06-2007), garage (19-04-2007), Giblets2 (21-04-2007), Gordongpms (29-04-2007), Hamish2k (04-04-2008), jommy999 (19-04-2007), KeanosMagicHat (19-04-2007), lewis4lcfc (04-05-2007), stonkmeister (19-04-2007), Yant0 (20-04-2007) |
19-04-2007, 10:51 AM
#26 (permalink)
Thanks: Gave 24, Got 13
anyone had any probs with DTV?
i scanned channels yesterday morning, and it picked up a few..
went to view last night, and it had "NO SIGNAL", so i tried to re-scan, and it wouldn't pick up anything - asking me to "CHECK AERIAL".
Of course, the aerial was plugged in and regular terrestrial was working fine.
BTW, BeyondTelevision delivered me the 46" M87 instead of the 40".. i would of been happy to keep it if it were not for the lack of space.. lol.. 40" is perfect, but 46 makes quite a bit of difference.
Wii over componnent was good too.. a friend is going to bring their xbox over next week to test.. not sure about PS3 tho.. doubt any of my mates will let me borrow theirs.. lol!!
My 40" that I ordered gets delivered Saturday morning, and the 46" goes back to Beyond TV..
First impressions:
Me: Wow.. nice look and modern..
Wife: I don't like black, do they do silver?
LOL!!
19-04-2007, 11:00 AM
#27 (permalink)
First impressions:
LOL!!
I don't use DTV, I use Sky only.
Have a look in the manual. It goes through each section in detail so ther may some info there to help you out.
19-04-2007, 11:26 AM
#28 (permalink)
Yeah, hope it's not another bug.
19-04-2007, 11:45 AM
#29 (permalink)
Thanks: Gave 2, Got 0
mine just arrived! started to plug and play now and gonna collaborate
just need to get a PS3 hooked up to check whether i have the HDMI 'night vision' problems...
if anyone know how else you can check this without HDMI devices then let me know
19-04-2007, 12:00 PM
#30 (permalink)
Thanks: Gave 152, Got 109
LOL!!
Press the DTV button while you're in freeview, you should get the option to check your signal strength.
I would have swapped my 40 for your 46  (and thrown in a six-pack, stella not cheap crap!!)
