22-05-2009, 3:16 PM
#1 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Sony Bravia - Poor Picture Quality
Hi, my family just bought a new tv, Sony Bravia, well its massive lol. Im not familiar with TV Settings, the problem is that the picture is quite poor, before this we had a 26inch Sony CRT TV, and the picture was perfect. But its quite poor in this new Sony Bravia, does anyone know good settings so i could get better picture?
22-05-2009, 3:36 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 80, Got 210 | Re: Sony Bravia - Poor Picture Quality
Which model Bravia is it mate?
Paul
22-05-2009, 3:44 PM
#3 (permalink)
| | Member
Thanks: Gave 0, Got 1 | Re: Sony Bravia - Poor Picture Quality
CRTs are generally better for SD viewing as they do not need to "stretch" the picture
22-05-2009, 3:46 PM
#4 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: Sony Bravia - Poor Picture Quality
I think its Sony Bravia KDL-40V4000
22-05-2009, 3:51 PM
#5 (permalink)
| | Senior Member
You should be able to get a very good picture from that.
Have a look here: Clicky
There are some settings near the bottom of the page that should get you started. Try them and tweak to your tastes.
Paul Quote:
Originally Posted by h4mza I think its Sony Bravia KDL-40V4000 | |
22-05-2009, 3:53 PM
#6 (permalink)
| | Senior Member
Thanks: Gave 76, Got 170 | Re: Sony Bravia - Poor Picture Quality
What SD source is giving poor pictures? Inbuilt Freeview, Sky, Cable, Freeview PVR, DVD, or what?
Also look at the main threads for the 40V4000 and copy the settings used by other owners. Particularly reduce sharpness and turn off any noise reduction or picture "enhancement" settings
22-05-2009, 7:49 PM
#7 (permalink)
| | Distinguished Member
Thanks: Gave 108, Got 1,462 | Re: Sony Bravia - Poor Picture Quality
LCD's and Plasma's are going to enhance the anomalies and artifacts in SD sources making the picture look not as good as on a CRT TV. I have a 26" Sony CRT and SD looks far better on it then on my 26" Samsung LCD or 32" Sony LCD. It doesn't bother me as it's still respectable especially on the Sony LCD and it doesn't really bother me. It's a compromise I made in order to have HD for my game consoles and blu-ray's/HD-DVD's.
23-05-2009, 8:48 AM
#8 (permalink)
| | Senior Member
Join Date: Mar 2009 Location: In a cardboard recycling bin
Thanks: Gave 1,063, Got 194 | Re: Sony Bravia - Poor Picture Quality Quote:
Originally Posted by Moogle LCD's and Plasma's are going to enhance the anomalies and artifacts in SD sources making the picture look not as good as on a CRT TV. I have a 26" Sony CRT and SD looks far better on it then on my 26" Samsung LCD or 32" Sony LCD. | Aaaaargh!
So i'm going to have to cancel my X10 order
Not really
Why do they always look worse? CRT is an old technology and plasma lcd newer, so they should be better?
Even lcds look worse than their same size crt
23-05-2009, 9:59 AM
#9 (permalink)
Thanks: Gave 108, Got 1,462 | Re: Sony Bravia - Poor Picture Quality Quote:
Not really
Even lcds look worse than their same size crt | Plasma's handle SD source material pretty well but LCD's do not. LCD's and to an extent Plasma's are designed for HD source material and not SD. Because of the technology used and the fact that they are designed for HD primarily means that SD won't look as good.
Some Plasmas and LCDs are better then others depending on how well they scale the image. My Samsung is pretty poor with SD but my Sony is pretty good. Then again the Samsung is a 4 year old 26" model and the Sony is a brand new 32" model. At the end of the day don't expect SD quality as good as CRT on a Plasma or LCD especially on an LCD.
24-05-2009, 10:37 AM
#10 (permalink)
| | New Member
I only have Set Top Box and a DVD Player Connected to it, I change to AV1 Source to watch Set Top Box and, i have to press Power Button of my DVD Player to turn it On but it automatically shows up on TV. But i have a problem, i cannot see the Picture of DVD, there are two Scart Lead Port at the back of TV, so i have to Swap them around to watch DVD.
I have also bought this Scart Lead Extension, its like a 3 Scarts in One small Box, but when Turn on DVD, i see lines in the Screen
PS: Is there any way i can watch Set Top Box and TV in High Definition?
24-05-2009, 9:26 PM
#11 (permalink)
| | Senior Member
Thanks: Gave 76, Got 170 | Re: Sony Bravia - Poor Picture Quality Quote:
Originally Posted by Moogle Plasma's handle SD source material pretty well but LCD's do not. LCD's and to an extent Plasma's are designed for HD source material and not SD. Because of the technology used and the fact that they are designed for HD primarily means that SD won't look as good.
Some Plasmas and LCDs are better then others depending on how well they scale the image. My Samsung is pretty poor with SD but my Sony is pretty good. Then again the Samsung is a 4 year old 26" model and the Sony is a brand new 32" model. At the end of the day don't expect SD quality as good as CRT on a Plasma or LCD especially on an LCD. | Firstly I assume that you are posting not as a moderator as I do not wish to be pilloried for criticising a moderator of this forum.
I regret I disagree. There are several factors in how an LCD or Plasma will present an SD source. It is always said that plasmas are better at SD but IMHO this is due to a "soft" picture presentation which to me defeats the object.
The major factors in SD presentation are (in order) source bit-rate, capability of the upscaler and other picture enhancements. Given the right combination IMHO the LCD wins hands down as it will on any decent HD source.
24-05-2009, 9:33 PM
#12 (permalink)
| | Senior Member
Why can't i find the 40V4000 anywhere? Is it an old model? It can't be, the spec is very good etc |
24-05-2009, 10:48 PM
#13 (permalink)
| | Member
Thanks: Gave 2, Got 4 | Re: Sony Bravia - Poor Picture Quality
The Sony KDL-V4000 models have all been replaced. We have the KDL-40V4000 in the lounge and it's a very nice tv.
24-05-2009, 10:54 PM
#14 (permalink)
| | Senior Member
Originally Posted by Limerick The Sony KDL-V4000 models have all been replaced. We have the KDL-40V4000 in the lounge and it's a very nice tv. | I know. Saw the stylish 32" version. Why did sony replace these great sets with some new, very expensive ones that suffer from backlight bleed?
I'm going to buy a Panasonic TX-P42X10B soon, but spotted a new Sony S series for £100 more, but the spec was really
So have placed my order for x10 in the end  |
25-05-2009, 11:30 AM
#15 (permalink)
| | Prominent Member
Thanks: Gave 406, Got 742 | Re: Sony Bravia - Poor Picture Quality Quote:
Originally Posted by Boostrail Firstly I assume that you are posting not as a moderator as I do not wish to be pilloried for criticising a moderator of this forum. | Im sorry but I have to jump in when such a statement is made.
Moderators dont get any special leverage with their opinions over others' opinions. Its pretty unfair to the ethos of a forum to retract your (fair) criticism of a moderator's opinion just because they are a moderator.
Moderators (especially those posting within forum sections that they dont personally moderate themselves) are treated as any other member in board discussions.
Regards
