Can a VGA connection display HD format?
Old 23-09-2008, 10:07 PM   #1
Thanks: Gave 96, Got 24
Was thinking of using the laptop connected to my tv to play downloaded HD videos. Is it possible with a vga cable?
I know i wound get sound, thats easily sorted.
Old 23-09-2008, 11:04 PM   #2
2010's Avatar
Thanks: Gave 74, Got 56
Re: Can a VGA connection display HD format?
Yes, provided your display is high definition (I presume it is because it has a VGA input).
Old 23-09-2008, 11:16 PM   #3
yeah the tv has vga input, had a play before. Just didnt know if i could syill hed a HD picture over it. The TV's max resolution is 1366 x 768.
What would i need to set the pc resolution to, to make best use of the tv?
Old 24-09-2008, 10:03 AM   #4
awoodhall2003's Avatar
Thanks: Gave 57, Got 68
you would need to plug in the TV and then your laptop should register dual screen and you should get an image on each one, then goto display properties and change the resolution to 1,366x768, however if i remember correctly your probably have to set it to 1,280x720 as thats 720p, and more likely for your laptop to display.
If you cant select either of these get powerstrip and you will be able to.
ScouserAndy (24-09-2008)
Old 24-09-2008, 10:29 AM   #5
Any tips for making smooth playback over the TV, i dont need to fiddle with other settings or anything. Laptop is fairly powerful, Tosh satellite pro, dual core 1.6ghz, 2gb ram, vista ultimate.
Old 24-09-2008, 10:34 AM   #6
to be honest the only major factor of smooth playback is what is playing it back so as long as your laptop plays it back fine you shouldnt have a problem, unless you got a crappy vga port on your tv you might see a small bit of tearing/motion blur, but if not should be perfect.
I connected my tv like that for about a week but i changed to dvi>HDMI lead and was better, plus ive got a cheap tv set thus the vga port isnt excellent.
Good luck and enjot :D
