Help Please Replacing Wireless Card In Dell XPS M1730
Old 16-09-2012, 12:10 PM   #1
Thanks: Gave 7, Got 0
Hi All,
I have just purchased a Dell XPS m1730 but have dicovered it only has a wireless G card installed
Can anybody offer any assistance how i can replace this with a N card and how easy will it be to fit.
Many Thanks in advance
Old 16-09-2012, 12:21 PM   #2
The Eggman72's Avatar
Thanks: Gave 175, Got 110
If its new & under warranty I wouldnt tinker internally voids warranty & if anything does fail you could edge into trouble trying to get them to do the repair...try one of these New usb wireless internet adapter dongle wifi 150Mbps | eBay ....
should do the job ........just be sure to disable the internal one within windows to avoid any conflicts..
Barnie66 (17-09-2012)
Old 16-09-2012, 12:25 PM   #3
Thanks for the input Eggman72, it is not under warranty so i thought if it was easy enough i would try and replace the unit, would prefer to keep it all internal if possible.
Old 16-09-2012, 12:33 PM   #4
most are located on the underneath but some under the keyboard which can be more tricky.just do a quick google search & you should be pointed in the right direction.....edit..found this it should help you...
http://www.ehow.com/how_7339819_inst...dell-1730.html
Old 16-09-2012, 12:44 PM   #5
maf1970's Avatar
Thanks: Gave 10, Got 244
Networking & Communication : Computer Components | Dell
The link will show you which cards are available to fit the machine and yes there are N ones. Best place to get one is off of EBay.
Old 17-09-2012, 10:46 AM   #6
Thanks maf1970 will take a look.
Got one from the bay for 9.99
