Sony Vaio not capable of 1080p over HDMI?
Old 13-02-2010, 12:28 PM   #1
Thanks: Gave 129, Got 144
I recently purchased a Sony Vaio NW20SF laptop to use with my 1080p Samsung TV.
I have now set it up, and it will not output 1080p. I have connected it to the TV via an amp and it immediately directed me to the 'Vaio Control Center' to adjust the HDMI output settings.
There are three options - 720, 768 & 1080. The problem is that 768 and 1080 are greyed out. 720 looks ok, and almost fills the whole screen, but does not look as good as laptops I have tried with this screen before that displayed at 1080.
In the 'Display Settings' tab, the resolution keeps defaulting to 1184 x 666, even when I try to increase it to the maximum allowed of 1366 x 768.
I realise that the laptop's own display is lower than 1080p, but does this mean it will not be able to output to my TV at that resolution?
Old 13-02-2010, 12:33 PM   #2
brookheather's Avatar
Thanks: Gave 45, Got 870
Have you got the TV setup as a secondary display rather than a clone of the primary display. You should be able to set the resolution of the second display independently of the primary display.
- Simon.
Old 13-02-2010, 1:38 PM   #3
- Simon.
Yes, I have tried it both ways. In the advanced settings, it correctly recognises the 'Digital Television' as my primary display, and allows my to select resolutions upto 1366 x 768 regardless of how the laptop's own display is setup.
The problem is that whatever resolution I apply, it always automatically reverts back to 1184 x 666.
Old 13-02-2010, 5:17 PM   #4
marchudman's Avatar
Thanks: Gave 27, Got 76
Re: Sony Vaio not capable of 1080p over HDMI?
I'd check the manual to make sure the gpu can output that resolution to begin with.
Old 14-02-2010, 2:18 PM   #5
I have managed to make some progress - not quite sure what I did.
I can now set the resolution to 1920 x 1080, and my Samsung TV recognises it correctly.
The only problem that I have is that the edges of the screen are cut-off. I am sure I saw an option to correct that before, but can't find it now!
Old 14-02-2010, 3:21 PM   #6
There is normally an "overscan" option on the TV menu - turn it off.
Old 14-02-2010, 10:13 PM   #7
houly's Avatar
Thanks: Gave 4, Got 5
how did you get on mate ?
Old 15-02-2010, 10:41 AM   #8
I have taken the resolution down one step from 1920 x 1080. This means that I get an image that almost fills my screen - looks great too.
I cannot find an overscan option on my Samsung TV, but I am not sure if this would work anyway because all of my HDMI devices are switched into one input on the TV, so I wouldn't want to adjust the settings and mess up my Blu Ray or Xobx picture!
I need to find the option on the laptop to adjust this - it is annoying as it was there earlier in the set up process!
Old 18-03-2010, 7:00 PM   #9
Thanks: Gave 3, Got 2
Hey,
Do you have any idea how to managed to set the resolution to 1920 x 1080?
I have the exact same problem you had and can't figure it out
Thanks!
Old 19-03-2010, 4:24 PM   #10
Originally Posted by jhynds View Post
Hey,
Thanks!
What laptop/graphics card are you using.
My Sony Vaio only has integrated intel graphics, but there wss an option in that menu to fit to the screen size. I am not sure if this is the correct way to do it, but it fills the full screen and the Samsung TV recognises the signal as 1920 x 1080.
It makes the 24" monitor on my iMac feel small!
