Go Back   AVForums.com > Computers > Computer Systems > Laptops and Netbooks
Today's price checkPowered by
Acer Aspire 5532 AMD Athlon X2 Dual-Core L310 1.2GHz / 4GB / 500GB / TFT15.6 / DVDRW / Win 7 Home Premium
Dell Inspiron Mini 10v (for home) Intel Atom 1.60GHz / 1024MB / 8GB / 10.1 / /
Acer Aspire One D250 Intel Atom N270 1.6GHz / 1GB / 160GB / TFT10.1 / WinXP Home
Sony Vaio VGN-NW20EF/S
Acer Aspire 5532 AMD Athlon X2 Dual-C...
Dell Inspiron Mini 10v (for home) Int...
Acer Aspire One D250 Intel Atom N270 ...
Dell Inspiron 1545 (for home) Celeron...
Samsung N130 Intel Atom N270 1.6GHz /...
Apple MacBook Pro Intel Core 2 Duo 2....
Sony Vaio VGN-NW20SF/P
Sony Vaio VGN-FW48E/H
Toshiba NB200-11L Intel Atom N270 1.6...
 More...Prices updated February 9th at 8:30pm and include delivery.
Thread Thread Starter Forum Replies Last Post
Help, my laptop display looks like this...... stevem999 Laptops and Netbooks 5 29-06-2009 3:26 PM
Oppo BDP83 / Denon A1Se - HD Audio Disappointment Griffith400 Blu-ray Players 19 29-06-2009 7:44 AM
Which Laptops can do BBC Iplayer HD WITHOUT JERKINESS (smoothly) from WIFI Live_Steam_Mad Laptops and Netbooks 26 27-06-2009 1:00 PM
£100 budget, closed back headphones to use with digital piano rooob2001 Headphones and Headphone Amps 18 27-06-2009 11:02 AM
Digital TV with no aerial? antknee Freeview 12 27-06-2009 10:55 AM
Old 26-06-2009, 11:42 PM   #1 (permalink)
Thanks: Gave 8, Got 13
HP Pavilion Laptop - Digital Audio Out - Solved!
Hi all,
I've been struggling the past few weeks to hook up my laptop to my receiver (Yamaha 861) for multi-channel audio. I have two HP laptops, the older one has an SPDIF out (which I assume is a mini toslink) and a newer one with a Blu-Ray ROM, HDMI out and dual headphone jacks (Pavilion dv6920ea).
When I set the default audio device as the Digital output in the control panel, as expected, the analog sound cuts out. Since the neither of the ports was marked as SPDIF, I assumed it would send out multi-channel digital audio via coax.
Experimented by connecting a stereo to RCA cable to the coax input of the amp - no luck. Got onto Google and started reading. Most people suggested that it could be mini toslink but I didn't have a cable handy and I wanted to be absolutely sure before purchasing one.
More research, more confusion. Many others seemed to believe that HDMI would only send out video signals. I decided to give it a try. Lo and behold! When I plugged a HDMI cable into my receiver, I was getting multi-channel digital audio!
I set the Realtek Digital Output device as my default audio device and played a DVD using Windows Media Player (the laptop has Vista Home Premium 32-bit installed) and the amp received a perfect 5.1 digital sound signal. Very pleased
I don't have any Blu-Ray discs handy so does anyone have experience playing blu-rays through such a setup? Would this laptop send audio through HDMI for Blu-Ray discs the same way it did for DVDs? Would I have the ability to decode the new Dolby TrueHD or DTS-HD formats on my laptop and send them via HDMI to my receiver (the Yamaha 861 cannot decode these formats)?
Any suggestions welcome.
HighPriest
highpriest is offline   Reply With Quote
Old 27-06-2009, 8:30 AM   #2 (permalink)
Thanks: Gave 1, Got 57
Re: HP Pavilion Laptop - Digital Audio Out - Solved!
When you have an HDMI socket fitted on a laptop it tends to grab the digital audio and switch off the digital audio out from the sound sockets. I'm not sure why they do this, but when I questioned Alienware on this behaviour I was told it's a fundamental motherboard thing, and not something they could fix with updated drivers. It's bizarre if you ask me. Why they think anyone would want the mini-toslink switched off just because the HDMI is in use I don't know. Sony have managed to achieve this with their Playstation 3, but no laptop I know of has. Weird, and not to say bloody annoying.
Regards
Mark
Mark_a is offline   Reply With Quote
Old 27-06-2009, 9:42 AM   #3 (permalink)
I suspect there's more to it. This laptop, I'm sure, does not have a mini toslink port. Both headphone outputs at the front at just plain old analog headphone outs. My older laptop has one port clearly marked SPDIF and when I shine a light into the port and look carefully, I can see that it's different on the inside.
So manufacturers have saved a couple of quid by leaving out the optical connector on laptops that have HDMI. What's more annoying is the complete lack of documentation about any of this on the HP website/manuals. Would it kill them to tell us?
Thanks for reading.
HighPriest
Old 27-06-2009, 9:44 AM   #4 (permalink)
Oh, and any ideas on decoding the latest HD Audio formats on this machine? I'm trying to save some money by not investing in a PS3 or Blu-Ray player if I can make this thing work properly.
HighPriest
Old 27-06-2009, 10:30 AM   #5 (permalink)
Well, my Alienware m15x has got fully programmable 3.5mm sound sockets that can be either inputs or outputs, analog or digital. If I connect up a mini-toslink cable to my AV amp and just play a DTS Sound sampler DVD for example (or even a CD) I get full digital output from the audio socket. The moment I activate the HDMI output by plugging it into my display then the digital sound is cut off from the audio port and re-routed to the HDMI lead. Analog stereo is still fed independently to the audio socket. There's no switch settings that will put digital sound back to the audio port when the HDMI is active, either in Windows or the BIOS.
Like I said, Alienware say that's how it is and there's nothing can be done about it. The answer to the 'problem', as far as they're concerned, is to get an AV amp with full HDMI inputs (not just video only as some are), and hard luck if you don't have one.
Regards
Mark
audio, digital, laptop, pavilion, solved
Copyright © 2000-2010 M2N E. & O. E.
