Go Back   AVForums.com > Computers > Computer Systems > Laptops and Mini PCs
Today's price checkPowered by
Dell Inspiron 1545 (for home) Celeron M 2.20GHz / 1024MB / 160GB / TFT15.6 / Combo /
Sony Vaio VPCW11S1E/W
Toshiba NB200-10G Intel Atom N270 1.6GHz / 1GB / 160GB / TFT10.1 / WinXP Home
Acer Aspire One 751h-52BR Intel Atom Z520 1.33GHz / 1GB / 160GB / TFT11.6 / WinXP Home
Dell Inspiron 1545 (for home) Celeron...
Toshiba NB200-10G Intel Atom N270 1.6...
Acer Aspire One 751h-52BR Intel Atom ...
Acer
Dell
Acer AS6935G-944G32Bn Intel Core 2 Du...
Apple MacBook Pro Intel Core 2 Duo 2....
Samsung NC10 Intel Atom N270 1.6GHz /...
Acer Aspire One D250 Intel Atom N270 ...
 More...Prices updated November 21st at 11:30am and include delivery.
Gears Of War 2 is about to become awesome JusR23 Gears of War Xbox 360 116 09-02-2009 4:47 PM
Getting HD, is my Sky+ mine to keep? Frying Tonight Sky HD 8 07-01-2009 7:02 PM
Help please! This is driving me nuts!! Tosh 32AV554DB and Sony davdz260 AL-CATRAZ1 All-in-one Systems 11 07-01-2009 11:27 AM
Which 42inch 1080p LCD TV to Buy ? Biffal Which LCD TV Should I Buy? 1 06-01-2009 12:42 PM
Old 06-01-2009, 12:47 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Connecting a Sony Vaio laptop to a tv
I need to (try to) connect my girlfriends Sony Vaio NR38E/S laptop to her old Toshiba 28Z44B TV.
I have read various posts from people who have seen VGA to s-video cables on eBay and replies from people saying they won't work... obviously that doesn't really help much as I don't know who to trust.
If these types of cables don't work is there are alternative means of connecting the two together?
Surely people selling cables that don't work would be left loads of negative feedback from angry buyers?
Thanks.
Nathaniel22 is offline   Reply With Quote
Old 06-01-2009, 1:08 PM   #2 (permalink)
Thanks: Gave 1, Got 54
Re: Connecting a Sony Vaio laptop to a tv
I've come across this problem with a colleague at work. A quick google explained the situation. The standard VGA port on a lot of laptops, meant for connecting to an external monitor, carries some pins that aren't used. So some enterprising board/chip maker came up with the idea of having a graphics chips that could output S-Vid, as well as RGB for the screen, but instead of bringing that out to a seperate s-vid socket, they saved some money by making use of the redundant pins on the VGA port. So now you can get pretty cheap specialist cables with a VGA plug on one end and an S-Vid plug on the other which just makes use of the s-vid and ignores the RGB pins.
Obviously this will only work if your lappy manufacturer has the right graphics chip, has wired the motherboard to output this non-standard s-vid to the VGA port, and has seen fit to enable it all at the BIOS or Windows driver level.
If none of the above is true then these VGA to S-Vid cables will not work, so it comes down to either, find out from the lappy manufacturer's literature, or borrow one and try it. Also don't forget that it won't carry any sound, only video.
It turned out my colleague's laptop had the right graphics chip but the maker had seen fit to not enable it as a way of differentiating between cheaper and more expensive models in its range. In the end he changed his TV to one with a VGA port on it to solve the problem.
Oh, and an alternative, if expensive, way to do it go to Maplins, or the like, who'll sell you an external VGA to composite/s-vid converter box.
Regards
Mark
Mark_a is offline   Reply With Quote
Nathaniel22 (06-01-2009)
Old 06-01-2009, 1:13 PM   #3 (permalink)
Great info!
Thanks!!
connecting, laptop, sony, vaio
