Killzone 2 - Stick Around Trophy Help
Old 11-03-2009, 11:45 AM   #1
3,179, Level: 13
Points: 3,179, Level: 13 Points: 3,179, Level: 13 Points: 3,179, Level: 13
Nail 20 Helghast to a wall using the Boltgun VC-21.
Has anyone managed to do this trophy yet. If so what is the best place to acheive this trophy.
cheers
Old 11-03-2009, 12:54 PM   #2
6,394, Level: 19
Points: 6,394, Level: 19 Points: 6,394, Level: 19 Points: 6,394, Level: 19
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 125, Got 464
Re: Killzone 2 - Stick Around Trophy Help
cheers
Yep - I got that. I think the bolt gun is only available in a couple of places - both in Suljeva Village? Anyway, one place you find it is in a room with some dead ISA soldiers. Pick up the boltgun and then the door opens with three Helghast on the other side. The main problem here is Rico taking them out before you can so try to stand in his way and nail them to the wall. Also make sure they're not standing in front of each other. Nailing one Helghast to another doesn't count. Now just go through the rest of that level nailing everyone you see.
Also - note thaty it does save your shots so you can do that bit of the level, get to the next checkpoint then reload the previous part to continue adding to your tally until you've got the trophy. Up to you if you consider that cheating or not, but the choice is there
Old 11-03-2009, 1:28 PM   #3
3,179, Level: 13
yeh i know the place i dont mind doing it that way. Only got that one to get and finish on elite and onto the nightmare of online trophies.
cheers for the advice.
Old 11-03-2009, 1:33 PM   #4
6,394, Level: 19
Activity: 3.4%
Good luck . I still need to do all levels without being killed, defeat Radec in under 20 mins (took me 21 mins grrr), collect all Intel and symbols and complete on Elite (not sure if I'l ever manage the last one). I've only been playing online recently but wll go back to finish off some of those trophies sometime.
Old 11-03-2009, 2:40 PM   #5
1,264, Level: 8
Points: 1,264, Level: 8 Points: 1,264, Level: 8 Points: 1,264, Level: 8
Apparently theres a hidden bolt gun on the train level. Was in one of the 'must do's' list. didn't find it when i did the level although i presume it would be quick funny to see someone get nail off the train. ha.
Old 12-03-2009, 10:52 AM   #6
Fifty's Avatar
4,495, Level: 15
Points: 4,495, Level: 15 Points: 4,495, Level: 15 Points: 4,495, Level: 15
Thanks: Gave 25, Got 58
I'm up to the last level scrap with Radec now - if I pick to do the Suljeva Village again now to get this trophy, can I still carry on from the last level using my save, or will I have to play through again to get back to Radec (if that makes sense)?
Old 12-03-2009, 11:00 PM   #7
2,252, Level: 11
Points: 2,252, Level: 11 Points: 2,252, Level: 11 Points: 2,252, Level: 11
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 1, Got 6
Argh
I just found out the hard way. I tried todo a different level as last bit with Radec was driving me mad. Tried to go back to radec and it just sent me back to the start of it, where your facing the first wave of troops after walking through the doors into the palace! How annoying is that?
Old 12-03-2009, 11:28 PM   #8
rbj rbj is offline
4,580, Level: 16
Points: 4,580, Level: 16 Points: 4,580, Level: 16 Points: 4,580, Level: 16
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 303, Got 59
cheers
On the Train level at the start to the left hand side is the boltgun, Best level to do it.
Old 17-03-2009, 1:19 PM   #9
3,321, Level: 13
Points: 3,321, Level: 13 Points: 3,321, Level: 13 Points: 3,321, Level: 13
Thanks: Gave 1, Got 9
On the safari trophy. I am missing one...
