Running Emule on T-Mobile Broadband
Old 01-01-2009, 3:25 PM   #1
Thanks: Gave 7, Got 4
Does anyone know if T-Mobile use port throttling on their mobile broadband service?
The port test fails on my Emule program and I'm unable to download anything.
Any advice would be much appreciated.
Thanks.
Old 01-01-2009, 3:36 PM   #2
13,312, Level: 27
Points: 13,312, Level: 27 Points: 13,312, Level: 27 Points: 13,312, Level: 27
Activity: 54.2%
Activity: 54.2% Activity: 54.2% Activity: 54.2%
Thanks: Gave 1, Got 523
Re: Running Emule on T-Mobile Broadband
Are you using a router? If so, you will need to set up port forwarding - this is more likely to be the issue than any ISP interference.
Steve
Old 01-01-2009, 3:51 PM   #3
Steve
I'm not using any kind of router, just a mobile broadband usb receiver thing.
Thanks for your reply.
Old 01-01-2009, 8:31 PM   #4
accyuklad's Avatar
5,570, Level: 17
Points: 5,570, Level: 17 Points: 5,570, Level: 17 Points: 5,570, Level: 17
Activity: 12.4%
Activity: 12.4% Activity: 12.4% Activity: 12.4%
Thanks: Gave 25, Got 276
they probly found your using a torrent or p2p to download and they could of banned it try changin the port number on emule
Old 04-01-2009, 2:51 AM   #5
3,484, Level: 13
Points: 3,484, Level: 13 Points: 3,484, Level: 13 Points: 3,484, Level: 13
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 13, Got 153
Yes its blocked, certain torrent trackers are also blocked.
