128kb/s on 8 meg line, help!
Old 26-07-2008, 4:31 PM   #1
ELV ELV is offline
Thanks: Gave 7, Got 12
Hello all iv'e just been reconnected to pipex after a very drawn out affair,my line was dissconnected 2 months ago after a problem with my card, anyhow before the cut off i used to get around 2/2.5 mb connection speed.I now have been reconnected but have a totally new account, different passwords etc but i'm only getting aroud 106kb/s download speed. Nothing has changed at my end and Pipex can't do anything to request bt look at it until the 9 day settling period is over. Has anyone any ideas what could be wrong, the status windown on my Netgear dg834 says there's 32db of noise on the line but it sound fine.Swapped and checked everything else all is ok. Pipexdid say that bt had been doing something in the exchange hence the drawn out timescale but any ideas would be appreciated, Cheers.
Old 26-07-2008, 5:17 PM   #2
Re: 128kb/s on 8 meg line, help!
If you mean that the S/N ratio is 32dB then you have a very good Signal to Noise ratio. The higher the better. You can get away with 3dB, better 6dB. It's a logarithmic scale so 32 is fantastic!
Old 26-07-2008, 5:33 PM   #3
Thanks: Gave 0, Got 7
Your problem is likely your isp
And also dont forget the school holidays have just started so all the kiddies will be on for hours each day on msn or online games leeching the bandwith away.
But you have one of the worst isps in the uk
Public Notice of Infraction for the Previous Post
Issued: 27-07-2008 at 11:28 AM
unhelpful post containing unqualified criticism
Old 27-07-2008, 9:54 AM   #4
ELV ELV is offline
This is what i get up in the connection status,
Connection Speed 128 kbps 64 kbps
Line Attenuation 7 db 1.5 db
Noise Margin 31 db 31 db ,
I know what you saying about the hollidays etc but i did have a steady 2 meg before and my house is only 100 yards from the exchange. Pipex were great for years btbh you only ever find out what cs is like when you need them, i ended up emailing the ceo of Pipex a letter ever since iv'e had contact with high level complains who sorted it preety swiftly,i'm waiting on bt now though .
Old 27-07-2008, 10:27 AM   #5
Thanks: Gave 228, Got 371
Have you tried this in the test socket? (do you have a test socket?) This is definitely a line fault, but could in fact still be at your end... There is a very good chance however that it's a fault at the exchange, the line card being faulty or not set up properly on your port. Can you try going to www.speedtester.bt.com and putting your number in, see what happens, for one thing.
Old 27-07-2008, 10:30 AM   #6
But not in relation to his sync speed. It's a very stable, very very slow line.
Which ISP do you use??? You can rarely get away with less than 5 with any level of stability on ADSL Max.
Old 27-07-2008, 10:32 AM   #7
It very likely isn't, if he's not on LLU. His problem is something to do with his line.
Can you qualify this statement in any way whatsoever? You're obviously an expert, as this is your first post in the ISPs forum on this site. So libel is obviously the way forward....
Old 27-07-2008, 5:09 PM   #8
ELV ELV is offline
The isp is Pipex, but i have a feeling as it's owned by Tascali, i may be on thier servers etc which i think could be LLU although i wasn't before. As i said i was happy with my speeds before re connection it's only since re connection iv'e had the slow speeds. Apparently bt had done something in the exchange and was part of the problem with getting re connected.
Iv'e tried the master socket but it's the same, i don't have anything other that a cordless phone connected any how and unplugging it didn't make any difference.Looks like i'll have to wait to the 9 days is up and give them a bell.
What difference does llu make?
Edit Bt speedtester says i should get 2000kb/s , actual 70 !!!
Cheers Elv.
Old 27-07-2008, 6:53 PM   #9
If you try the speedtester that I linked to, it'll tell you if you're on LLU
Old 27-07-2008, 7:23 PM   #10
So as its my first time on the isp forum I know nothing
I have had PLENTY of experience with Pipex my parents had it and lost connection for weeks at a time despite having great connection with other isps, I had it and was lucky to get 256kbs on a 8 meg line, switched to another isp full 8 meg.
They get bad customer reviews on sites like Thinkbroadband.
I assume you were the one that marked me for moderation.
Nice attitude you have.
Old 27-07-2008, 10:28 PM   #11
In the job that I have just left I could get disciplined, fined and ultimately sacked for publically slagging off another service provider, even if it was justified to do so.
I have never marked anyone for moderation, it's the moderators job to moderate and ultimately decide whether to issue an infraction for something.
My attitude doesn't seem to be a problem to most on here, hence the "thanks" figures...
Old 28-07-2008, 9:30 AM   #12
kav kav is offline
Illustrious Member
kav's Avatar
Thanks: Gave 4,856, Got 6,791
The matter has been discussed and resolved, so let's leave it at that and keep this thread on topic, thanks.
Old 28-07-2008, 9:20 PM   #13
Thanks: Gave 19, Got 147
where are you getting the 70kb/s value from?? go to speedtest.net and click on the server nearest to your location (it should automatically be highlited as a "yellow" pyramid) and let us know what speed test is reporting. and i agree with seanT, he has been very helpfull and proven his knowlege in many threads in many sections. "pointing fingers" is not going to help anyone, if anything it will just get the moderators on your tail even more..... ive been picked up by one of the moderators for "circumventing the swearing filter" once when i was in a rage with an isp and my communication with the moderator was quite pleasent. right back on topic (sorry for getting side tracked there kavanf1)
has your speed picked up any ELV??? or is it still low? as you say its possibly something that has been done in the exchange and if nothing has changed regarding your physical line or pc's and phones in your house then its not your fault, if you get a continued slow speed than all you can really do is carry on at your isp to get it sorted. have a look at speedtest.net and see what it says as your modem may just be reporting wrong settings. im assuming your getting your connection speed from your modem status page?
Old 29-07-2008, 4:10 PM   #14
ELV ELV is offline
I got my speed from from the linked site, a few others gives the same speeds.
I realy is painfully slow, you can virtually make a coffee between pages.
It's still as slow, nothings changed. I was talking to Tiscali today who seem to think it's a problem in the exchange possibly with the ports, but who knows.So here's hoping!
Cheers Elv
Old 30-07-2008, 11:00 AM   #15
Unhappy Re: 128kb/s on 8 meg line, help!
it may possibly be a fault with the exchange in which case there isnt much you can do
Old 30-07-2008, 11:12 AM   #16
Did you try the BT speedtester and find out if you're on LLU or not yet? Or, what exchange are you on? www.samknows.co.uk
Old 30-07-2008, 9:41 PM   #17
ELV ELV is offline
Here's my exchange,
mation
Exchange name: Harrington
Exchange code: LCHAR
Postcode: CA145NZ
Maps: Our map|Multimap|Streetmap
Serves (approx): 3,534 residential premises
69 non-residential premises.
Broadband availability overview
ADSL: Yes
SDSL: No
LLU services: No
Cable: No
Wireless: No
BT Wholesale information
ADSL status: Enabled as of 22/10/2003
ADSL Max status: Enabled as of 31/03/2006
SDSL status: Not available
21CN WBC status: Not available
21CN PSTN switchover target: Q1 2010
Wireless broadband availability
LTT Broadband: Not available
Now Wireless: Not available
OnLincolnshire: Not available
Urban Wimax: Not available
Kijoma: Not available
EMNET Notts: Not available
Orbital / VFast: Not available
Cable broadband availability
Virgin Media: Not available
Smallworld Media: Not available
» Who are all these providers?
» Spotted an error? Let us know
LLU operator presence What is this?
AOL: Not available
O2 / Be: Not available
C&W / Bulldog: Not available
Edge Telecom: Not available
Entanet: Not available
Lumison: Not available
NewNet: Not available
Node4: Not available
Orange: Not available
Pipex: Not available
Sky / Easynet: Not available
Smallworld: Not available
TalkTalk (CPW): Not available
Tiscali: Not available
Tiscali TV: Not available
Updata: Not available
WB Internet: Not available
Zen Internet: Not available
Ofcom Classification What's this?
Market 1This exchange has BT Wholesale as the sole provider of broadband services.Exchange HistorySubscribe to RSS Feed
19/10/2006 BT have set a target date of Q1 2010 for the switch to 21CN for the Harrington exchange
Email notifications of changes to:
It says it's not enabled for LLU so hopefully that's not the problem.Pipex are going to report the fault on Friday, it is Tiscali and i have read that they are LLU, is it possible t be on LLU in a non LLu exchange, perhaps resulting in dail up speeds?
Elv
Old 30-07-2008, 10:42 PM   #18
Try plugging and unplugging the adsl (RJ11) cable to your router at least ten times within the space of a few minutes to make the kit on the other end think there is a problem and hopefully reprofile your line. Also try leaving the router off overnight and switching it back on the following day / evening.
Chances are it's a fault in the exchange, something is configured wrong, so it'll be a BT wholesale fault. See if your ISP will give you the BT fault reference (VOL) number for the actual fault so you can get progress direct from BT.
And as it's a BT wholesale circuit, please use the speedtester at speedtester.bt.com as it'll tell us a teeny bit more, and the BT faults teams can see the results of these tests when you do them, so it actually helps them diagnose the fault quickly and effectively.
Old 31-07-2008, 10:39 PM   #19
ELV ELV is offline
Iv'e used the bt speed tester a couple of times although i can never get it to
work by changing the login details.
Cheers.
