For those not reading the thread in the HD forum and to cut a long story short, I always said medium was best on the Thomson HD box, but when my system was calibrated, the low setting was used.
I have two displays connected via HDMI, a modest Panasonic TH-37PX80 in my office (not calibrated other than via Video Essentials) but in my main room a DVDO VP50Pro and Pioneer KRP-500M, both calibrated.
As Mr. Serpent has given me a bad case of paranoia, I've experimented today with both displays, with and without calibration enabled. If I make sure the contrast controls are low enough on both displays to avoid clipping, I can actually see some loss of highlight detail on the BBC preview loop with the HD box set to anything other than low, which is contrary to what I originally posted. The best example is some sort of comedy clip with John Thomson (the guy from Cold Feet) where almost the entire image is approaching peek white in some scenes. So I think, with and without calibration, low actually looks best to me.
If it helps at all, I can capture the component outputs of the box. Unfortunately I have no way to capture the HDMI outputs. Here's what I've got on that front - which may confuse things further and if anyone can offer better analysis, it would be appreciated.
This is from the BBC HD blog:
"What have I done and how useful is this version of the test card? First, white level has been reduced so the peak white box is not 100% (level 235 or 0.7v). The super white spot is now 100% and the linearity of the grey scale is now slightly inaccurate. [snip] The top white block has two spots. As I said earlier, usually the white block is peak white with the right spot higher (super white) and the left spot slightly lower. On our test card, the levels are slightly reduced."
Here are my captures:
BBC HD test card - low contrast.
In Photoshop, I measure the white block as 215 and the super white block at 220. That may (or may not) be consistent with the text from the BBC blog, because according to them, the level
shouldn't be 235. Either way, it would only take a small contrast adjustment at the display level to reach 235, which is what that site is recommending.
BBC HD test card - medium contrast.
I'm measuring the white block at 254 and the super white block at 255, which means it's most definitely clipped. Remember, according to the BBC the block(s) should be below 235.
BBC HD test card - high contrast.
Just for kicks. Ouch.
I was going to take a stab at grabbing the transport stream from the box, but my 1TB drive is 75% full of stuff we haven't watched and I don't fancy risking the SO's wrath if it goes walkabout. It would be really interesting though if anyone could access the TS via a PC.
