| Pioneer PDP 428XD
Following the excellent Dummies Guide to Calibration, and using the HCFR software and Eye One, I have managed to spend many hours of fun playing with the settings.....
I have a PS3 on HDMI input 4, and use the the DVE disc for initial Contrast/Brightness settings with the Pluge pattern, and then AVCHD disc for calibrating the 10-100% grayscale settings.
My results were great, with Gamma tracking 2.22 across the range, with Delta errors of less than 3 (10-100%) for the grayscale.
Even the 6500K chart was flat.
I then tried to calibrate the primaries and secondary's. This showed large Delta Errors in the Green primary (and magenta secondary).
The resultant change in the CMS settings to bring this in (Green towards yellow ~21!). I did this with changes for Magenta too.
On re-checking my greyscale, they were (expectedly) way off. In bringing this back in, I ended up with very "large" RHigh (+ve) and RLow )-ve) figures, and greater delta errors (with 0-20% being particular bad). Gamma tracking was also worse.
My questions are:
Should I leave my inaccurate Colour Calibration alone, and be happy with nr perfect grayscale?
Sacrifice Grayscale extremes for more accurate colour saturation?
I believe the PS3 input is going to be setup nicely for films, but the same settings for SKYHD, particularly for Sport, resulted in horrible colours, and luminous green grass (Colour Space 2 was better).
Also, I intended on allocating an input to a Pioneer Mode, (MOVIE=PS3, Standard = SKYHD box, USER = DVD), but can you answer if
these modes are all configurable this way, as with the same settings in each mode, the PS3 picture varied by mode.
Also, how do I calibrate SKYHD HDMI input1; Should I repeat above from PS3 but on HDMI input 1, or use an HD Test Card (if I can find one!)
I would have posted a few images, but not worked out to include them (yet).
Any help would be much appreciated,
Wayne
