If this has been brought up before I'm sorry but I did a quick search which didn't return any specific answers to my questions.
So, I’ve read a handful of guides and a very detained on HCFR and have to say I think I’m ready! I've managed to source an i1 off a very good friend of mine so really I’m all set!
I want to calibrate a 37" Panasonic LCD which has an Xbox 360, DVD Player & Sky+ SD box connected to it. The screen in question has a Normal, Dynamic, Cinema and Game mode.
My main questions go kind of hand in hand:-
- Should I calibrate against more than one source?
- Which source should I calibrate from?
My DVD player does reasonable up-scaleing to 1080p and is connected to the screen with a decent HDMI cable so I was considering using that. My Xbox 360 is connected via component outputting at 1080i question is which is the better bet?
I understand I’m going to have to access service menus and alter RGBGain etc but the question is does this generally change for just the one 'mode' or is it a global setting? If you suggest calibrating from more than one source should I use different 'modes' or not and how do you find the balance between sources?
Thanks for any information
