Isf callibration Panasonic G10
Old 18-07-2009, 4:31 PM   #1
Conspicuous Member
tele1962's Avatar
35,458, Level: 46
Points: 35,458, Level: 46 Points: 35,458, Level: 46 Points: 35,458, Level: 46
Activity: 54.7%
Activity: 54.7% Activity: 54.7% Activity: 54.7%
Thanks: Gave 4,047, Got 1,848
Hi everyone,
Just thinking about getting my 42" Panny G10 calibrated,just a couple of questions though,firstly my tv is only seven weeks old will it void my waranty and secondly if my tv developes a fault and needs to be replaced within the waranty does the person callibrating it tell you the settings they have used so as to apply them to the replacement.or will you have to get the replacement calibrated Many thanks.
Old 18-07-2009, 4:44 PM   #2
Illustrious Member
Badger0-0's Avatar
43,318, Level: 50
Points: 43,318, Level: 50 Points: 43,318, Level: 50 Points: 43,318, Level: 50
Activity: 85.5%
Activity: 85.5% Activity: 85.5% Activity: 85.5%
Thanks: Gave 467, Got 1,881
Re: Isf callibration Panasonic G10
I can't see it voiding the warranty if done by an ISF person.
Each telly has it's own variations, so the new one would have to be done too.
ISF people recommend waiting a few weeks, because most tellies tend to fail early.
tele1962 (18-07-2009)
Old 19-07-2009, 11:05 AM   #3
2,335, Level: 11
Points: 2,335, Level: 11 Points: 2,335, Level: 11 Points: 2,335, Level: 11
Thanks: Gave 7, Got 4
out of interest, so how does one get to the calibration menu's??
i have had my Panny G10 2 weeks and i'm currently running it, but once this has been completed i will be looking to get an ISF certified person out to do their magic... can anyone let me know how will i know the TV has been run in?
Old 19-07-2009, 11:24 AM   #4
Gordon @ Convergent AV's Avatar
41,380, Level: 49
Points: 41,380, Level: 49 Points: 41,380, Level: 49 Points: 41,380, Level: 49
Activity: 4.7%
Activity: 4.7% Activity: 4.7% Activity: 4.7%
Thanks: Gave 984, Got 1,706
Just try to keep a tallyof how long it's been used for...around 150 +hrs should be fine for your set I'd think
Old 22-07-2009, 4:21 PM   #5
Conspicuous Member
tele1962's Avatar
35,458, Level: 46
Activity: 54.7%
When the Panny 42" G10 is calibrated how do you know in the user menu which one is calibrated ie.is it cinema,normal,etc.sorry if it seems like a daft question.
Old 22-07-2009, 4:38 PM   #6
Illustrious Member
Badger0-0's Avatar
43,318, Level: 50
Activity: 85.5%
I would imagine it will be the mode that is nearest to correct in the first place.
That's usually "cinema".
I'd have thought they'd explain everything to you when they do it
tele1962 (22-07-2009)
Old 23-07-2009, 5:15 PM   #7
Iain Gibson's Avatar
2,254, Level: 11
Points: 2,254, Level: 11 Points: 2,254, Level: 11 Points: 2,254, Level: 11
Thanks: Gave 56, Got 51
Yep, Cinema mode on Pannys is generally the best one to calibrate for reference viewing. The other memories can be useful for less critical situations e.g. broadcast tv during the day. And yes, we calibrators are usually more than happy to explain stuff as we go along
Cheers,
Iain
Badger0-0 (23-07-2009), tele1962 (23-07-2009)
Old 23-07-2009, 6:29 PM   #8
wiz wiz is offline
6,854, Level: 19
Points: 6,854, Level: 19 Points: 6,854, Level: 19 Points: 6,854, Level: 19
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 101, Got 67
Can anyone who has had there Panny calibrated tell is it worth it? I ask because the Panny's don't have the tweaks other sets do (Service menu)
Old 26-07-2009, 3:28 PM   #9
4,445, Level: 15
Points: 4,445, Level: 15 Points: 4,445, Level: 15 Points: 4,445, Level: 15
Thanks: Gave 201, Got 252
If you want a more accurate image then only you can decide mate. But it will be better
Old 26-07-2009, 5:52 PM   #10
Conspicuous Member
tele1962's Avatar
35,458, Level: 46
Activity: 54.7%
Some people are saying the picture tweaks on the G10 are limited even in the service menu,so can colour be calibrated as well as greyscale and have any ISF calibrators done the Panny.G10
Old 26-07-2009, 6:11 PM   #11
41,380, Level: 49
Activity: 4.7%
The adjustments on Vierra's have always been limited....but then Pioneers have lots of adjustments...many of which don't work as advertised.....you work with what you have...the question is can you improve the image. The answer is yes. The methods used to do it are pretty irrelevant imho
I think I've done a couple of G10's. Will need to go searching to see if I can find customer names.
tele1962 (26-07-2009)
Old 29-07-2009, 11:51 AM   #12
Conspicuous Member
gizlaroc's Avatar
20,250, Level: 34
Points: 20,250, Level: 34 Points: 20,250, Level: 34 Points: 20,250, Level: 34
Activity: 16.3%
Activity: 16.3% Activity: 16.3% Activity: 16.3%
Thanks: Gave 109, Got 391
I think getting a G10 done is worth it for decent gamma alone, this makes a hell of a difference to the overall depth of an image.
tele1962 (29-07-2009)
Old 29-07-2009, 1:58 PM   #13
Conspicuous Member
tele1962's Avatar
35,458, Level: 46
Activity: 54.7%
Can this be calibrated on the G10.
Old 29-07-2009, 2:15 PM   #14
AVF Hardware Reviewer/News
Mark Hodgkinson's Avatar
34,934, Level: 45
Points: 34,934, Level: 45 Points: 34,934, Level: 45 Points: 34,934, Level: 45
Activity: 40.9%
Activity: 40.9% Activity: 40.9% Activity: 40.9%
Thanks: Gave 1,452, Got 2,054
Not individually but check out this thread to see what effect calibrating the greyscale can have on gamma. This chap's went from around 1.9 up to @ 2.2 after calibration
Old 31-07-2009, 6:33 PM   #15
Conspicuous Member
tele1962's Avatar
35,458, Level: 46
Activity: 54.7%
Many thanks to Iain at Illuninant tv for a great calibration.
Iain Gibson (03-08-2009)
