AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration > ISF Calibration
LinkBack Thread Tools Display Modes
Old 19-09-2007, 11:07 AM   #1 (permalink)
Thanks: Gave 7, Got 5
Calibrating Freeview?
This might be a daft question but here it goes
I can understand different inputs being calibrated as they can have a source connected to them , but how can you calibrate a internal freeview tuner or an analog tuner for that matter as there is no way to play the calibration disc on them?
Same for SKY HD , or do you substitute the box with a DVD player, would this then be correct as it would not be the true source?
Apologies if this is a dumb question
Regards
A G Morrison
Lesmor is offline
Old 19-09-2007, 11:30 AM   #2 (permalink)
961
Thanks: Gave 33, Got 79
Re: Calibrating Freeview?
Originally Posted by Lesmor View Post
Regards
A G Morrison
So far as Sky HD is concerned, Sky does transmit a test card from time to time, usually overnight, that you can record for use later
A freeview tuner can often be adjusted to ensure it is exactly tuned. This is usually called fine tuning in the manual
The actual tv settings can be adjusted visually, as you say, by introducing a dvd player into the system and playing a tuning disc available from Amazon or elsewhere
961 is offline
Old 24-09-2007, 3:01 PM   #3 (permalink)
Gordon @ Convergent AV's Avatar
Thanks: Gave 467, Got 959
You can also use certain types of programme material in order to accurately set up internal tuners.
Gordon
Work: http://convergent-av.co.uk/about.html
My Photos: Flickr
My Blog:Do I know you?
Gordon @ Convergent AV is offline
Old 25-09-2007, 10:53 AM   #4 (permalink)
Gordon
Thanks Gordon
Can you perhaps give some examples of ones you had in mind?
Also would the calibration requirements be different for a HD source compared to a Standard PAL broadcast?
Also thanks to all who have replied as I am new to calibration and only have the DVE disc at the moment although have been considering SPYDER TV but unfortunately it does not cover greyscale.
Can anyone recommend a beginners guide to start me off with research
Lesmor is offline
Old 25-09-2007, 11:47 AM   #5 (permalink)
The most important thing when setting up, imho, is to set black level and white level correctly. This shouldn't change for SD and HD. To set them you look for something that definately has BLACK in the image and for contrast you look for something that has bright white detail. As has been said there are test patterns at times on SkyHD I believe.
Gordon
My Photos: Flickr
Lesmor (25-09-2007)
calibrating, freeview
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
