AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration > ISF Calibration
LinkBack Thread Tools Display Modes
Old 23-05-2007, 1:56 PM   #1 (permalink)
Can I be done
I have just been introduced to this forum through an email by AV Forums. I have never heard of thisa and would like to ask what maybe obvious to you, but.
Can I be ISF calibrated if I have a CRT. I have a LOEWE Aconda, 5 years old. If so is it worth it because of it's age, can I do it myself if not what would it cost?
BTW I live in UK, Essex.
caveman38 is offline
Old 23-05-2007, 2:10 PM   #2 (permalink)
scouse258's Avatar
Thanks: Gave 1, Got 5
Re: Can I be done
given your equipment i wouldnt bother mate - save your cash to invest in some new gear.
You can get decent results by using the THX optimiser set ups on the Star Wars discs etc or, if you want to push the boat out a little further then invest in the Digital Video Essential's DVD (commonly referred to as the DVE disc) which will set you back £20 or so
scouse258 is offline
Old 23-05-2007, 6:02 PM   #3 (permalink)
Gordon @ Convergent AV's Avatar
Thanks: Gave 467, Got 959
Re: Can I be done
Great TV. I have done a few of them in the dim and distant past. It is massively off standard out the box. The last one I measured had a hugely blue greyscale...in fact it was the worst greyscale I ever measured on a display. However, once they are done they can be pretty good.
If you are planning on sitcking with it for a significant while then it may be worth having it done. If you plan on swapping it out for a new flat panel display then just hold off until then.
All the best
Gordon
Work: http://convergent-av.co.uk/about.html
My Photos: Flickr
My Blog:Do I know you?
Gordon @ Convergent AV is offline
Old 23-05-2007, 9:26 PM   #4 (permalink)
Re: Can I be done
Gordon
Just wondering if you are still planning a trip to Northern Ireland in Aug. I have a Sony 32v2000 which needs calibrating. Also could you give me a rough idea of cost
andyjkmak is offline
Old 24-05-2007, 10:19 AM   #5 (permalink)
AVF Content Manager
Phil Hinton's Avatar
Thanks: Gave 343, Got 1,044
Re: Can I be done
Originally Posted by andyjkmak View Post
Gordon
Due to rule 7, Gordon will be unable to answer your queries directly on the forums. This area is for asking questions relating to ISF calibration, but not a sales area for calibrators. HTH.
Editorial Content Manager
Hardware Reviewer/ISF Certified
AVForums TV
My personal opinions are not those of the AV Forums or any other related website.
Phil Hinton is offline
Old 01-08-2007, 7:58 PM   #6 (permalink)
Assured Advertiser
Thanks: Gave 77, Got 698
Re: Can I be done
Hello all
In case you've missed it Gordon (Convergent-AV) is on his way over to Ireland and taking bookings for ISF Calibrations (North & South).
See ISF in Ireland?
Joe
The Media Factory - Install, Connect and Control.
Joe Fernand is offline
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
