Changing ipod owner
Old 29-10-2007, 2:16 PM   #1
Thanks: Gave 5, Got 1
Changing ipod owner
My Son has just bought one of these new ipod touch thingys and has kindly given his Dad his old ipod mini. I've installed itunes and everything is working fine but dak how to change the owners name? It's not very obvious from any of the menus so I'm a bit stuck.
Old 29-10-2007, 2:37 PM   #2
gilford's Avatar
Thanks: Gave 577, Got 830
Re: Changing ipod owner
Open iTunes and plug the iPod in, once it has recognised it, go to it in the left hand bar and click on restore. Here you will be able to re name it
longitude (29-10-2007)
Old 29-10-2007, 9:50 PM   #3
Thanks: Gave 70, Got 286
Or if you don't want to have to go through a full restore (which isn't too bad on a Nano, but you don't want to do on a classic unless you *really* have to...) - connect to iTunes, and when the iPod appears and has finished syncing, click twice on the name of the iPod in the left-hand column, as you would to rename a folder or file in Windows.
Old 30-10-2007, 4:52 PM   #4
Sadly neither way works. The resume option attempts to do a restore and then a window pops up saying it couldn't. The second method allowed me to rename and then a window popped up saying it couldn't find the folder "new name". I've got the latest itunes and ipod software running on a vista laptop if that helps.
Old 31-10-2007, 12:22 PM   #5
Limited Member
Thanks: Gave 54, Got 1,083
Have you looked at the iPod support pages on Apple.com? They are very good and you should find a fix there.
Old 31-10-2007, 2:10 PM   #6
spooney's Avatar
Thanks: Gave 53, Got 221
There is an article on the Apple support page (#60952)
- Select the Ipod on the right hand side
- Click the name again, it will be selected
- Enter the new name
- Press Enter
No need to reset or something.
