I have just bought an iPod Nano 8GB. Downloaded the latest version of iTunes and installed. Then as soon as plugged the USB cable into the PC it shut down instantly. I had to wait a good 5 minutes when before it would boot back up again. I have tried the front and rear USB port... but to no avail
I running Windows Vista and my PC spec is as follows:
AMD Athlon X2 4600 Dual Core
2GB Corsair RAM
256MB GeForce 7600GS
320GB SATA II HDD
MSI K8N Neo2 Platinum with Nvidia nForce 3 Ultra Chipset (motherboard)
The USB ports are all 2.0 compatible.
My PSU is 400W.
I have 3 USB devices plugged in the rear and nothing in the front. Devices connected are:
Keyboard
Printer
Scanner
I am sort of guessing the iPod USB cable is causing a surge of some sort, but I might be wrong.
Does anyone have any ideas as to what the problem might be... and how to fix it please?
Many thanks,
Gazza.
