| Re: Migrating to iPod - Gapless issues?
As Sansa Clip is drag and drop, then your MP3s will play fine on the iPod. You'll have to use iTunes even if only as a glorified link to your iPod should you choose not to use it for playback on your PC, but all the same you should have no issues
As for gapless, that depends on how your MP3 files were ripped. MP3 is not a natively gapless codec and the short of it is some trickery is used to implement it. I rip my MP3s with EAC+Lame and my files are fine on my iPods. Reportedly it is why Sony have yet to be able to bring gapless back after they dropped it with the demise of Atrac because they could not get the coding right
You might be better off taking a portable hard drive or usb stick containing one or two of your albums and road testing an iPod at an Apple store. Don't worry, just explain you are seriously interested in buying and what you are doing. They do not really care what you do in there
