2nd request: Quickest way to upgrade 2g JB to 3.1.2
Old 18-11-2009, 12:38 AM   #1
16,062, Level: 30
Points: 16,062, Level: 30 Points: 16,062, Level: 30 Points: 16,062, Level: 30
Activity: 4.4%
Activity: 4.4% Activity: 4.4% Activity: 4.4%
Thanks: Gave 214, Got 235
As my last thread was closed as Hutch deemed it was a classified advert rather than a request for assistance, does anyone know where I can get software to allow, in the simplest way, to upgrade a JB/unlocked 2g from 2.2.1 to 3.1.2? I dont have a Mac but am looking for a simple method as phones aren't my forte.
Old 18-11-2009, 1:33 AM   #2
jerryq7777's Avatar
8,836, Level: 22
Points: 8,836, Level: 22 Points: 8,836, Level: 22 Points: 8,836, Level: 22
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 93, Got 256
Re: 2nd request: Quickest way to upgrade 2g JB to 3.1.2
I did my 3G from 3.0 to 3.12 with these custom firmware.
Download Custom Firmware ipsw files for iPhone 2G, 3G 3.1 [Windows/Mac] , Error 1600 Solution Updated | iLikeMyiPhone
You will need the iPhone 2G 3.1 Custom Firmware Activated for Other Carriers Part 1 and Part 2 and the tool to join them.Its easier than it looks and all the instructions are there to walk you through the process just in case you dont find anyone local and want to give it a go yourself.
Old 18-11-2009, 8:30 AM   #3
16,062, Level: 30
Activity: 4.4%
Thanks mate I'm off for 2 days so gonna have a bash I think. If it all goes wrong it'll give me an excuse to buy a new phone
Old 19-11-2009, 6:09 PM   #4
16,062, Level: 30
Activity: 4.4%
All done Thanks to those that gave me guidance
Old 04-12-2009, 10:46 PM   #5
1,947, Level: 10
Points: 1,947, Level: 10 Points: 1,947, Level: 10 Points: 1,947, Level: 10
Thanks: Gave 1, Got 0
Just wanted to add quickest way for me was to update then run blackra1n
but after bootneuter was run i had to install the patched lockdown file otherwise i could not use any other sim.
anybody who gets the sim card invalid message
just holla if you want the info
i thought 2G to be easiest jailbreak & unlock Iphone3G is the easiet since Blackra1n came on the scene
Old 07-12-2009, 11:37 AM   #6
7,462, Level: 20
Points: 7,462, Level: 20 Points: 7,462, Level: 20 Points: 7,462, Level: 20
Thanks: Gave 4, Got 5
I could use some info on the patch
