iPhone 3G 3.0 Unlock/Jailbreak help!
Thread Closed
Old 06-11-2009, 9:20 PM   #1
irvin38a's Avatar
2,485, Level: 11
Points: 2,485, Level: 11 Points: 2,485, Level: 11 Points: 2,485, Level: 11
Thanks: Gave 21, Got 30
I have just bought an iPhone 3G 16GB from ebay which is locked to O2.
Can somebody help me. I need to know how to unlock it so I can use my vodafone contract sim in it. Also, does jailbreaking it unlock it for other sims too?
The firmware version is 3.0 (Build 7A341)
Also, can I update to a later version or is that not a possibility?
Oh and once unlocked, will my Vodafone 3G sim be ok for WiFi etc?
Thanks.
Old 06-11-2009, 9:22 PM   #2
kdc kdc is offline
kdc's Avatar
4,597, Level: 16
Points: 4,597, Level: 16 Points: 4,597, Level: 16 Points: 4,597, Level: 16
Thanks: Gave 96, Got 114
Re: iPhone 3G 3.0 Unlock/Jailbreak help!
http://www.avforums.com/forums/iphon...ation-faq.html
http://www.avforums.com/forums/iphon...nd-unlock.html
sigh... there's a search function for a reason
irvin38a (06-11-2009)
Old 06-11-2009, 9:32 PM   #3
irvin38a's Avatar
2,485, Level: 11
Originally Posted by kdc View Post
Thanks and Sorry!!!
Thought it'd be easier just to ask for specific model as I have been trawling through the forum for an hour trying to make head/tail of things!! lol
Just one more question Do I upgrade to firmware 3.1 before jailbreaking/unlocking or will it happen when i jailbreak when phone is still on 3.0?
*Runs to take cover*
Old 06-11-2009, 9:58 PM   #4
kdc kdc is offline
kdc's Avatar
4,597, Level: 16
depends whether you want to blackrain on windows or pwnage on mac.
blackrain you need to update to 3.1
pwnage you just use the pwnage tool and dont update.
p.s. wifi will work regardless of simlock (obviously with o2 you get access to btopenzone and cloud hotpsots which you wont get with voda)
Old 06-11-2009, 11:34 PM   #5
irvin38a's Avatar
2,485, Level: 11
So, you say update to 3.1 then? Which is the latest firmware that I can upgrade to and still both Jailbreak and Unlock the phone?
As far as I can see 3.1 cannot be jailbroken but can be unlocked. I need to do both. Sorry if I'm being a pain in the arse but I'm really confused! (I have an ipod touch which I jailbroke easy enough though! lol)
Old 06-11-2009, 11:38 PM   #6
kdc kdc is offline
kdc's Avatar
4,597, Level: 16
if you are using windows you can use blackra1n to jailbreak and blacksn0w to unlock, to do this you have to update to 3.1, have a readthrough phairplays blackrain thread and go to
http://iphonejtag.blogspot.com/
Old 06-11-2009, 11:57 PM   #7
irvin38a's Avatar
2,485, Level: 11
Is THIS the best way then?
Will updating to 3.1.2 via iTunes change my baseband from 04.26.08 to 05.11.07?
Old 07-11-2009, 3:10 AM   #8
hutch's Avatar
28,793, Level: 41
Points: 28,793, Level: 41 Points: 28,793, Level: 41 Points: 28,793, Level: 41
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 335, Got 689
Closing, we have a thread in place as has already been pointed out.
Thread Closed
