where are 'sounds' stored?
Old 04-11-2009, 1:11 AM   #1
pez_555's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 108, Got 48
I downloaded some gears of war sounds off Cydia under themes (sounds), however i am unable to locate where they are stored on the phone? i have checked sounds under the settings tab but nothing is there apart from the default sounds that are shipped with the phone.
help?!
thanks!
Old 04-11-2009, 7:02 AM   #2
Pug72's Avatar
7,028, Level: 19
Points: 7,028, Level: 19 Points: 7,028, Level: 19 Points: 7,028, Level: 19
Activity: 1.3%
Activity: 1.3% Activity: 1.3% Activity: 1.3%
Thanks: Gave 68, Got 145
Re: where are 'sounds' stored?
Are they turned on via Winterboard?
Old 04-11-2009, 8:28 AM   #3
pez_555's Avatar
5,121, Level: 16
Activity: 0.8%
yes
Old 04-11-2009, 9:07 AM   #4
4,649, Level: 16
Points: 4,649, Level: 16 Points: 4,649, Level: 16 Points: 4,649, Level: 16
Thanks: Gave 33, Got 93
They won't change the name of the default sounds as they appear in the SMS tones list (for example) - they will simply be used instead of the defaults when the particular sound theme is turned on in winterboard. If you have iPhonebrowser (or equivalent) you can browse to the Library/Themes folder and see what the theme includes - sounds will be in a folder called UIsounds I think (going from memory here as I'm at work at the moment).
Old 04-11-2009, 9:33 AM   #5
pez_555's Avatar
5,121, Level: 16
Activity: 0.8%
ah i see, but on my phone the default sounds are still the same? ive activated it on winterboard, the names and sounds are still the same.
thanks for the reply also!
Old 04-11-2009, 3:43 PM   #6
pez_555's Avatar
5,121, Level: 16
Activity: 0.8%
anybody ?
