Iphone 3g Unlock or not
Old 24-10-2009, 6:43 PM   #1
970, Level: 7
Points: 970, Level: 7 Points: 970, Level: 7 Points: 970, Level: 7
Thanks: Gave 1, Got 1
Hi all, if your here thanks for taking the time to hopefully respond !
Not going to waste your time so here's the spec :
Ver 3.1.2(7d11)
Modem 05.11.07
no need to unlock just wanted to jailbreak to use tethering, just pisses me off they want more money to use a bigger screen & keypad
Well that's my rant after messing with ra1n all afternoon I'm guessing this ain't gonna happen for a while
Old 24-10-2009, 6:58 PM   #2
Desmo's Avatar
13,710, Level: 28
Points: 13,710, Level: 28 Points: 13,710, Level: 28 Points: 13,710, Level: 28
Activity: 37.8%
Activity: 37.8% Activity: 37.8% Activity: 37.8%
Thanks: Gave 366, Got 817
Re: Iphone 3g Unlock or not
Are you just asking if you can jailbreak v3.1.2? If so, yes you can. Take a look at the dev-team website for details or blackra1n. Loads of info in the 3.1 Jailbreak thread here.
Old 24-10-2009, 7:10 PM   #3
970, Level: 7
Hi, thanks for the fast response. I thought I had put more info already
I do just need a jailbreak, but I have been 'playing' with blackra1n and it will only goto the Itunes restore screen & not the author's pic
Also I'm running Vista but softy is in Xp mode
Old 24-10-2009, 7:45 PM   #4
Desmo's Avatar
13,710, Level: 28
Activity: 37.8%
Not sure what to suggest. I know other have had some problems also and needed to try it a number of times. I must have been lucky as mine just sailed through in about 30 seconds.
Old 24-10-2009, 7:58 PM   #5
Bennybeanbag's Avatar
2,703, Level: 12
Points: 2,703, Level: 12 Points: 2,703, Level: 12 Points: 2,703, Level: 12
Activity: 3.5%
Activity: 3.5% Activity: 3.5% Activity: 3.5%
Thanks: Gave 17, Got 60
I tried Jailbreaking with Blackra1n last night with the same speck iPhone as the OP and had the same problems.
Google results seem to suggest that Blackra1n is fine with a 3GS but with a 3G it tends to take many attempts. Some people have posted suggestions that make the software run but I gave up after having to do a full restore after the iPhone just stuck in recovery mode.
Try a Google search for 'Blackra1n fail' and see how you get on.
Old 24-10-2009, 8:12 PM   #6
970, Level: 7
Lol...2 recoverys so far, so there is hope
Old 24-10-2009, 8:36 PM   #7
2,703, Level: 12
Activity: 3.5%
OUCH!
The only reason I want to JB is to run the ifon software that gets rid of the Call Forward pop up when making a call. I have a factory unlocked 3G and am using a T-Mobile sim. I may just put up with the pop up message rather than waste more of my life on Blackra1n
Old 24-10-2009, 10:34 PM   #8
970, Level: 7
OUCH!
Yep I'm now in the same state of mind another 2 restore's, just cause I don't like defeat !
Gonna just put up with it till someone say's they got a defo fix
Cheers again all
