3GS jailbroken on 3.1 - is it safe to use backgrounder?
Old 22-10-2009, 5:15 PM   #1
11,492, Level: 25
Points: 11,492, Level: 25 Points: 11,492, Level: 25 Points: 11,492, Level: 25
Activity: 5.3%
Activity: 5.3% Activity: 5.3% Activity: 5.3%
Thanks: Gave 12, Got 21
have heard some people say it messes up your iphone so just wanted to make sure it was ok to use. There are also apparently other apps which do exactly the same thing....would they be a better option?
thanks
Old 22-10-2009, 5:40 PM   #2
UEF UEF is offline
7,132, Level: 20
Points: 7,132, Level: 20 Points: 7,132, Level: 20 Points: 7,132, Level: 20
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 26, Got 228
Re: 3GS jailbroken on 3.1 - is it safe to use backgrounder?
It works fine.
Go into the options and turn the badge on (and use the extra setting to turn the badge off for official apps that have background support - iPod, safari etc.)
