3GS Jailbreak is Live
Old 04-07-2009, 9:28 PM   #61
kdc kdc is offline
kdc's Avatar
4,597, Level: 16
Points: 4,597, Level: 16 Points: 4,597, Level: 16 Points: 4,597, Level: 16
Thanks: Gave 96, Got 114
Re: 3GS Jailbreak is Live
Originally Posted by ClintBoon View Post
Ok no problem, so is Cydia worthwile having? What are the benefits of it please?
Sorry if im pishing people off by now.
Its just a different app resource, you'll find things on it that wont get approved by apple because they change the way the iphone functions..
Old 04-07-2009, 9:29 PM   #62
the porter's Avatar
13,457, Level: 27
Points: 13,457, Level: 27 Points: 13,457, Level: 27 Points: 13,457, Level: 27
Activity: 7.2%
Activity: 7.2% Activity: 7.2% Activity: 7.2%
Thanks: Gave 240, Got 304
if you need to unlock mate you need cydia so for you thats the biggest hurdle done
Old 04-07-2009, 9:31 PM   #63
2,809, Level: 12
Points: 2,809, Level: 12 Points: 2,809, Level: 12 Points: 2,809, Level: 12
i dont need to unlock, just need to jailbreak for apps. You still need Cydia right?
Old 04-07-2009, 9:33 PM   #64
the porter's Avatar
13,457, Level: 27
Activity: 7.2%
yes you need cydia for apps i thought you wanted to unlock ie ultrasnow!
Old 04-07-2009, 9:38 PM   #65
2,809, Level: 12
No its because i followed the steps on a site and it went through jailbreaking and then onto unlocking without me noticing.
Cydia doesn't look very good though...... is it?
Old 04-07-2009, 9:44 PM   #66
DarkEntity's Avatar
7,426, Level: 20
Points: 7,426, Level: 20 Points: 7,426, Level: 20 Points: 7,426, Level: 20
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 26, Got 128
yes
Old 04-07-2009, 9:46 PM   #67
2,809, Level: 12
Originally Posted by DarkEntity View Post
yes
Can you tell me some of the cool things you can download then ? Please.
Old 04-07-2009, 10:35 PM   #68
Zain's Avatar
3,333, Level: 13
Points: 3,333, Level: 13 Points: 3,333, Level: 13 Points: 3,333, Level: 13
Thanks: Gave 110, Got 47
just done mine with vista, very simple and quick.
Couple of questions. so no winterboard yet? in that case, how do I apply a theme?
Aslo, i had a quick toggle settings on my old 3G, SB settings?? there's so many different types?
Old 04-07-2009, 11:07 PM   #69
Zain's Avatar
3,333, Level: 13
SBsettings done! what a relief, much easier
Old 04-07-2009, 11:22 PM   #70
hutch's Avatar
28,758, Level: 41
Points: 28,758, Level: 41 Points: 28,758, Level: 41 Points: 28,758, Level: 41
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 335, Got 689
Please stop taking this thread off-topic, there is already a Cydia Apps thread which answers all your questions.
Old 04-07-2009, 11:24 PM   #71
hutch's Avatar
28,758, Level: 41
Activity: 3.4%
Sorry to type another message but how do you get all the free apps once all this **** is done? I expected to go to the app store and get stuff for free.
Be very careful here, discussion on how to obtain warez will earn you a holiday from the forum.
Old 04-07-2009, 11:35 PM   #72
2,809, Level: 12
What does this do? Got Cydia running fine now.
Old 05-07-2009, 8:51 AM   #73
3,335, Level: 13
Points: 3,335, Level: 13 Points: 3,335, Level: 13 Points: 3,335, Level: 13
Thanks: Gave 1, Got 0
Done the following
"1. Open iBEC and iBSS Grabber
2. Select Destination you want to save the files to
3. Click on Start Watching
4. While connected to itunes put the phone in DFU mode (hold power button and home button for 10sec. then release power button and keep holding home button until itunes finds the iphone if you have done this right the screen will stay black.)
5. Restore firmware 3.0
6. Wait until restore complete.
7. Check folder you saved you iBEC and iBSS files to (Per45C --- Firmware ---DFU)
8. Job done"
Are there a few files .img3 files? are they the correct ones? in an all flash folder?
All help be great
Matt
Old 05-07-2009, 9:19 AM   #74
Conspicuous Member
chelsea.tone's Avatar
18,823, Level: 33
Points: 18,823, Level: 33 Points: 18,823, Level: 33 Points: 18,823, Level: 33
Thanks: Gave 792, Got 982
Personally, i'll be waiting for the Dev Team JB
Old 05-07-2009, 1:18 PM   #75
4,247, Level: 15
Points: 4,247, Level: 15 Points: 4,247, Level: 15 Points: 4,247, Level: 15
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 1, Got 6
Originally Posted by fairlysteady View Post
Done the following
8. Job done"
All help be great
Matt
The iBSS and iBEC are in the DFU folder they should be around 100-104kb
Old 06-07-2009, 8:13 AM   #76
9,835, Level: 23
Points: 9,835, Level: 23 Points: 9,835, Level: 23 Points: 9,835, Level: 23
Activity: 36.2%
Activity: 36.2% Activity: 36.2% Activity: 36.2%
Thanks: Gave 2,229, Got 1,309
You will still need to do the above and backup the ibec files in preparation for the JB.
Old 06-07-2009, 8:51 AM   #77
4,896, Level: 16
Points: 4,896, Level: 16 Points: 4,896, Level: 16 Points: 4,896, Level: 16
Thanks: Gave 7, Got 4
what are you ibss and iec files for?
Old 06-07-2009, 8:57 AM   #78
9,835, Level: 23
Activity: 36.2%
For restoring your phone to 3.0 state after 3.1 update from itunes.
Otherwise dev JB won't work after 3.1.
Old 06-07-2009, 2:09 PM   #79
3,335, Level: 13
"The iBSS and iBEC are in the DFU folder they should be around 100-104kb"
Tried this a few times now and not having much joy, it creates three folders 1,2 and 3 and in 2 and 3 theres a dfu folder and both of them have a iBEC file 103kbs which do i need or both? where is the iBSS file?
All help would be great
Old 06-07-2009, 2:42 PM   #80
2,725, Level: 12
Points: 2,725, Level: 12 Points: 2,725, Level: 12 Points: 2,725, Level: 12
Thanks: Gave 43, Got 87
This whole iBSS and iBEC stuff is confusing me
What do we need the Purplera1nyday file for?
Old 06-07-2009, 2:53 PM   #81
UEF UEF is offline
7,132, Level: 20
Points: 7,132, Level: 20 Points: 7,132, Level: 20 Points: 7,132, Level: 20
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 26, Got 228
They're all basically theoretical files that might be required for a jailbreak from the dev-team.
I don't think people need to get them ASAP as is being suggested though
Old 06-07-2009, 2:56 PM   #82
3,335, Level: 13
anyone else struggling to get both files? done it both ways now and can only get the ibec file
Old 06-07-2009, 5:08 PM   #83
2,725, Level: 12
I got both files with the phone in DFU mode.
So now I have the iBSS, iBEC and purplera1nyday file - Is that everything?
Old 06-07-2009, 5:30 PM   #84
UEF UEF is offline
7,132, Level: 20
Activity: 2.7%
Yeah. You can now run Purplera1n's Windows or Mac tool and realise you probably don't need any of it
Old 06-07-2009, 5:38 PM   #85
2,725, Level: 12
Yep, it does make me wonder
I'll wait for the dev team to release their JB tools, unless the Purplera1n JB works with winterboard now?
Old 06-07-2009, 5:43 PM   #86
UEF UEF is offline
7,132, Level: 20
Activity: 2.7%
I think its more of a case of WinterBoard not working with the 3GS.
The 3GS is a new phone and as such needs some changes to WinterBoard to make it work.
So you may as well go for PurpleRa1n now and wait for the new WinterBoard to arrive seperately. In the meantime, you'll get everything you previously got from Cydia.
Or alternatively, you can just sit there
Old 06-07-2009, 6:18 PM   #87
4,134, Level: 15
Points: 4,134, Level: 15 Points: 4,134, Level: 15 Points: 4,134, Level: 15
Thanks: Gave 54, Got 48
YouTube - How to Capture Your iPhone 3GS iBEC and iBSS Windows
the instructions here is posted very clearly and it worked flawlessly. if anyone is having trouble they must remember TIMING is crucial and that the 10 seconds he wants you to count while going into dfu mode is an actual 10 f-king seconds.
Old 06-07-2009, 10:14 PM   #88
2,706, Level: 12
Points: 2,706, Level: 12 Points: 2,706, Level: 12 Points: 2,706, Level: 12
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 3, Got 1
Had trouble myself capturing these files myself. This grabber program worked a treat.
ECID Grabber & iBEC and iBSS Grabber | iPhone News, Help and Guides
Old 07-07-2009, 10:25 AM   #89
UEF UEF is offline
7,132, Level: 20
Activity: 2.7%
Compatible WinterBoard is out
The Iphone Spot » Blog Archive » Winterboard, MobileSubtrate 3G S Compatible Update
Old 07-07-2009, 11:46 AM   #90
kdc kdc is offline
kdc's Avatar
4,597, Level: 16
so has anyone had any problems with their 3gs since jailbreaking?
